| 1 |
.EQ
| 2 |
delim @@
| 3 |
.EN
| 4 |
.SH 1
| 5 |
\f[BI]Radiance\f[B] File Formats
| 6 |
.pdfhref O 1 "Radiance File Formats"
| 7 |
.pdfhref M "radiance-file-formats"
| 8 |
.LP
| 9 |
This chapter discusses the standard file formats specific to
| 10 |
\f[I]Radiance\f[R], and gives their internal structure, with pointers to
| 11 |
routines for reading and writing them.
| 12 |
The following file formats (listed with their conventional suffixes) are
| 13 |
covered:
| 14 |
.IP "\f[B]Scene Description (.rad suffix)\f[R]" 3
| 15 |
This is the main input file type, describing materials and geometry for
| 16 |
the rendering programs, and must be compiled into an octree by oconv
| 17 |
prior to ray-tracing.
| 18 |
It is an ASCII text format, and is often translated from a CAD
| 19 |
description, but may be created or edited by a text editor as well.
| 20 |
.RS 3
| 21 |
.RE
| 22 |
.IP "\f[B]Function File (.cal suffix)\f[R]" 3
| 23 |
Also a text format, these files describe mathematical patterns,
| 24 |
textures, and surface shapes.
| 25 |
In the case of patterns and textures, the functions serve as input
| 26 |
directly to the rendering programs.
| 27 |
In the case of surfaces, the functions serve as input to one of the
| 28 |
generator programs, \f[B]gensurf\f[R], \f[B]genrev\f[R] or
| 29 |
\f[B]genworm\f[R].
| 30 |
Additionally, \f[B]pcomb\f[R] may be used to perform math on
| 31 |
\f[I]Radiance\f[R] pictures and the \f[B]rcalc\f[R] utility may be used
| 32 |
in creative ways to manipulate data for scene generation and data
| 33 |
analysis.
| 34 |
.RS 3
| 35 |
.RE
| 36 |
.IP "\f[B]Data File (.dat suffix)\f[R]" 3
| 37 |
Another ASCII format, data files are used directly by the rendering
| 38 |
programs to interpolate values for luminaire photometry, among other
| 39 |
things.
| 40 |
.RS 3
| 41 |
.RE
| 42 |
.IP "\f[B]Font File (.fnt suffix)\f[R]" 3
| 43 |
A simple, polygonal font representation for rendering text patterns.
| 44 |
This ASCII format describes each character \[lq]glyph\[rq] as a sequence
| 45 |
of vertices in rectangular, integer coordinates ranging from 0 to 255.
| 46 |
.RS 3
| 47 |
.RE
| 48 |
.IP "\f[B]Octree (.oct suffix)\f[R]" 3
| 49 |
A binary data structure computed from one or more scene description
| 50 |
files by the oconv program.
| 51 |
It may contain frozen scene data in binary form, or merely references to
| 52 |
the original scene files.
| 53 |
.RS 3
| 54 |
.RE
| 55 |
.IP "\f[B]Picture (.hdr suffix)\f[R]" 3
| 56 |
A binary image file containing calibrated, real radiance values at each
| 57 |
pixel.
| 58 |
\f[I]Radiance\f[R] pictures may be displayed, analyzed, and converted to
| 59 |
other image formats.
| 60 |
.RS 3
| 61 |
.RE
| 62 |
.IP "\f[B]Z-buffer (.zbf suffix)\f[R]" 3
| 63 |
A binary file with the distances to each pixel in a corresponding
| 64 |
picture.
| 65 |
.RS 3
| 66 |
.RE
| 67 |
.IP "\f[B]Ambient File (.amb suffix)\f[R]" 3
| 68 |
A binary file used to store diffuse interreflection values, which are
| 69 |
shared between cooperating rendering processes running sequentially or
| 70 |
in parallel.
| 71 |
Since these values are view-independent, sharing this information across
| 72 |
multiple runs is highly economical.
| 73 |
.RS 3
| 74 |
.RE
| 75 |
.LP
| 76 |
We will discuss each of these formats in turn, giving examples and
| 77 |
pointers to routines in the source code for reading and writing them,
| 78 |
and the programs that use them.
| 79 |
In general, the ASCII text formats have no standard routines for writing
| 80 |
them, since they generally originate outside of \f[I]Radiance\f[R] or
| 81 |
are created with simple \f[I]printf(3)\f[R] statements.
| 82 |
Most binary file formats are machine and system independent, meaning
| 83 |
they can be moved safely from one place to another and
| 84 |
\f[I]Radiance\f[R] will still understand them (provided no unintentional
| 85 |
character translation takes place along the way)\**.
| 86 |
.FS
| 87 |
The single exception to this rule is the Z-buffer file, whose contents
| 88 |
are dictated by the floating point representation and byte order of the
| 89 |
originating machine.
| 90 |
This choice was made for economic reasons, and is rarely a problem.
| 91 |
.FE
| 92 |
Most binary files also include a standard ASCII header at their
| 93 |
beginning that may be read by the \f[B]getinfo\f[R] program.
| 94 |
This offers a convenient method for identifying the file contents when
| 95 |
the file name is ambiguous.
| 96 |
.SH 2
| 97 |
Scene Description Format (.rad suffix)
| 98 |
.pdfhref O 2 "Scene Description Format \(.rad suffix\)"
| 99 |
.pdfhref M "scene-description-format-.rad-suffix"
| 100 |
.LP
| 101 |
The semantics of the \f[I]Radiance\f[R] scene description format are
| 102 |
covered in the Reference Manual.
| 103 |
We will therefore focus on the file syntax and structure, which are
| 104 |
simple and straightforward.
| 105 |
In fact, some would say that the \f[I]Radiance\f[R] scene description
| 106 |
format is brain-dead, in the sense that it offers few language amenities
| 107 |
and requires the awkward counting of string and real arguments (not to
| 108 |
mention those non-existent integer arguments).
| 109 |
We have little to offer in its defense.
| 110 |
.PP
| 111 |
The truth is, the scene format was designed to grow with
| 112 |
\f[I]Radiance\f[R], and we wanted to keep it as simple as possible so as
| 113 |
to encourage others to write translators to and from it.
| 114 |
Specifically, we wanted to be able to read files using the
| 115 |
\f[I]scanf(3)\f[R] library function and write files using
| 116 |
\f[I]printf(3)\f[R].
| 117 |
Furthermore, we wanted everyone\[cq]s parsers to be stable over time,
| 118 |
which meant no primitive-specific syntax.
| 119 |
We also decided that a flat file structure was most practical, since
| 120 |
hierarchies are typically lost on the first translation, and sufficient
| 121 |
structure could be provided by the file system itself.
| 122 |
Since we did not intend text editing to be the primary input method, we
| 123 |
felt the effects of these programming decisions on the human readability
| 124 |
and writability of the format were less important.
| 125 |
.PP
| 126 |
Even so, the format is relatively easy to read and write once you get
| 127 |
used to it, and with the \f[I]Radiance\f[R] generator programs and
| 128 |
in-line command expansion, the text editor becomes a powerful modeling
| 129 |
tool in the hands of an experienced user.
| 130 |
Together with the need for editing material descriptions, our assumption
| 131 |
that users would rarely edit these files turned out to be mistaken.
| 132 |
Consequently, it is a good idea for all users to familiarize themselves
| 133 |
with the scene description format, awkward or not.
| 134 |
.SH 3
| 135 |
Basic File Structure
| 136 |
.pdfhref O 3 "Basic File Structure"
| 137 |
.pdfhref M "basic-file-structure"
| 138 |
.LP
| 139 |
There are four statement types in a scene description file: comments,
| 140 |
commands, primitives and aliases.
| 141 |
These may be interspersed in the file, and the only structural
| 142 |
requirement is that modifiers precede the primitives they modify.
| 143 |
.SH 4
| 144 |
Comments
| 145 |
.pdfhref O 4 "Comments"
| 146 |
.pdfhref M "comments"
| 147 |
.LP
| 148 |
The simplest statement type is a comment statement begins with a pound
| 149 |
sign (`#') and continues to the end of line:
| 150 |
.IP
| 151 |
.nf
| 152 |
\f[C]
| 153 |
# This is a comment.
| 154 |
\f[]
| 155 |
.fi
| 156 |
.SH 4
| 157 |
Commands
| 158 |
.pdfhref O 4 "Commands"
| 159 |
.pdfhref M "commands"
| 160 |
.LP
| 161 |
An in-line command, which begins with an exclamation mark (`!') and
| 162 |
| 163 |
.IP
| 164 |
.nf
| 165 |
\f[C]
| 166 |
!xform -n chair1 -t 10 5 8 chair.rad
| 167 |
\f[]
| 168 |
.fi
| 169 |
.LP
| 170 |
The command is executed during file parsing, and its output is read as
| 171 |
more input.
| 172 |
Long commands may be continued on multiple lines by escaping the newline
| 173 |
character with a backslash (`\[rs]'):
| 174 |
.IP
| 175 |
.nf
| 176 |
\f[C]
| 177 |
!gensurf marble sink \[aq]15.5+x(theta(s),phi(t))\[aq] \[rs]
| 178 |
\[aq]10.5+y(theta(s),phi(t))\[aq] \[rs]
| 179 |
\[aq]30.75+z(theta(s),phi(t))\[aq] \[rs]
| 180 |
8 29 -f basin.cal -s
| 181 |
\f[]
| 182 |
.fi
| 183 |
.LP
| 184 |
Since the command is executed by the shell, pipes and other facilities
| 185 |
are available as well.
| 186 |
The following command creates a counter with a precisely cut hole for
| 187 |
the sink basin just given:
| 188 |
.IP
| 189 |
.nf
| 190 |
\f[C]
| 191 |
!( echo marble polygon sink_top 0 0 108 31 \[rs]
| 192 |
10.5 30.75 31 22 30.75 0 22 30.75 0 0 \[rs]
| 193 |
30.75 31 0 30.75 31 10.5 30.75 ; \[rs]
| 194 |
cnt 30 | rcalc \[rs]
| 195 |
-e \[aq]$1=15.5+x(theta(0),phi(1-$1/29))\[aq] \[rs]
| 196 |
-e \[aq]$2=10.5+y(theta(0),phi(1-$1/29))\[aq] \[rs]
| 197 |
-e \[aq]$3=30.75\[aq] -f basin.cal )
| 198 |
\f[]
| 199 |
.fi
| 200 |
.LP
| 201 |
Note in the above example that two commands are executed in sequence.
| 202 |
The first creates the counter perimeter, and the second cuts the hole.
| 203 |
The two commands are enclosed in parentheses, so if a final
| 204 |
transformation is added by \f[B]xform\f[R] with the \f[B]-c\f[R] option,
| 205 |
it will be applied to both commands, not just the last one.
| 206 |
.SH 4
| 207 |
Primitives
| 208 |
.pdfhref O 4 "Primitives"
| 209 |
.pdfhref M "primitives"
| 210 |
.LP
| 211 |
A primitive can be thought of as an indivisible unit of scene
| 212 |
information.
| 213 |
It can be a surface, material, pattern, texture or mixture.
| 214 |
The basic structure of a primitive is as follows:
| 215 |
.IP
| 216 |
.nf
| 217 |
\f[C]
| 218 |
modifier type identifier
| 219 |
n S1 S2 S3 ..Sn
| 220 |
0
| 221 |
m R1 R2 R3 ..Rm
| 222 |
\f[]
| 223 |
.fi
| 224 |
.LP
| 225 |
The \f[C]modifier\f[R] is the \f[C]identifier\f[R] of a previously
| 226 |
defined primitive, or \f[C]void\f[R] if no modifier is appropriate.
| 227 |
The type is one of the supported \f[I]Radiance\f[R] primitive keywords,
| 228 |
such as \f[I]polygon\f[R] or \f[I]plastic\f[R].
| 229 |
Following the \f[C]modifier\f[R], type and identifier are the string
| 230 |
arguments, preceded by the number of string arguments and separated by
| 231 |
white space.
| 232 |
If there are no string arguments, then 0 should be given for
| 233 |
\f[C]n\f[R].
| 234 |
The string arguments are followed by the integer arguments in the same
| 235 |
fashion.
| 236 |
(Since there are no \f[I]Radiance\f[R] primitives currently using
| 237 |
integer arguments, the count is always 0.)
| 238 |
Finally, the number of real arguments is given, followed by the real
| 239 |
arguments.
| 240 |
.PP
| 241 |
The location of the primitive in the scene description has no
| 242 |
importance, except that its modifier refers to the most recently defined
| 243 |
primitive with that identifier.
| 244 |
If no such modifier was defined, an error results.
| 245 |
In fact, \[lq]undefined modifier\[rq] is the most frequently reported
| 246 |
error when parsing an invalid scene description, since any random bit of
| 247 |
junk encountered where a statement is expected will be interpreted as a
| 248 |
modifier.
| 249 |
One final note about modifiers \[em] since surfaces never modify
| 250 |
anything, their identifiers are neither stored nor referenced in the
| 251 |
parser\[cq]s modifier list, and serve only for debugging purposes during
| 252 |
editing and rendering.
| 253 |
.PP
| 254 |
Within a primitive, white space serves only to separate words, and
| 255 |
multiple spaces, tabs, form feeds, returns, and newlines are all
| 256 |
considered as one separator.
| 257 |
Consequently, it is not possible for a string argument to contain any
| 258 |
white space, which is OK because no \f[I]Radiance\f[R] primitive needs
| 259 |
this.
| 260 |
.SH 4
| 261 |
Aliases
| 262 |
.pdfhref O 4 "Aliases"
| 263 |
.pdfhref M "aliases"
| 264 |
.LP
| 265 |
An alias simply associates a new modifier and identifier with a
| 266 |
previously defined primitive.
| 267 |
The syntax is as follows:
| 268 |
.IP
| 269 |
.nf
| 270 |
\f[C]
| 271 |
modifier alias new_identifier old_identifier
| 272 |
\f[]
| 273 |
.fi
| 274 |
.LP
| 275 |
The \f[C]old_identifier\f[R] should be associated with some modifier
| 276 |
primitive (i.e., non-surface) given earlier.
| 277 |
The \f[C]modifier\f[R], if different from the original, will be used
| 278 |
instead in later applications of \f[C]new_identifier\f[R].
| 279 |
.PP
| 280 |
Aliases are most often used to give new names to previously defined
| 281 |
materials.
| 282 |
They may also be used to associate different patterns or textures with
| 283 |
the same material.
| 284 |
.SH 3
| 285 |
Scene Hierarchy
| 286 |
.pdfhref O 3 "Scene Hierarchy"
| 287 |
.pdfhref M "scene-hierarchy"
| 288 |
.LP
| 289 |
Hierarchical scene descriptions are achieved through expansion of
| 290 |
in-line \f[B]xform\f[R] commands.
| 291 |
The \f[B]xform\f[R] command is used to read and place other
| 292 |
\f[I]Radiance\f[R] scene description files in the calling file, and
| 293 |
these other descriptions may in turn read others, and so on down the
| 294 |
tree.
| 295 |
No check is made to assure that none of the calling files is called
| 296 |
again, even by itself.
| 297 |
If this happens, commands open commands until the system runs out of
| 298 |
processes, which is a very nasty business and to be avoided.
| 299 |
.SH 3
| 300 |
\f[BI]Radiance\f[B] Programs
| 301 |
.pdfhref O 3 "Radiance Programs"
| 302 |
.pdfhref M "radiance-programs"
| 303 |
.LP
| 304 |
The following table shows programs in the main \f[I]Radiance\f[R]
| 305 |
distribution that read and write scene description files.
| 306 |
Additionally, there are other translators that write scene files, which
| 307 |
are available separately as free contributions or as part of other (CAD)
| 308 |
programs.
| 309 |
.PP
| 310 |
.na
| 311 |
.TS
| 312 |
delim(@@) tab( );
| 313 |
l l l l.
| 314 |
T{
| 315 |
Program
| 316 |
T} T{
| 317 |
Read
| 318 |
T} T{
| 319 |
Write
| 320 |
T} T{
| 321 |
Function
| 322 |
T}
| 323 |
_
| 324 |
T{
| 325 |
\f[B]arch2rad\f[R]
| 326 |
T} T{
| 327 |
T} T{
| 328 |
X
| 329 |
T} T{
| 330 |
Convert Architrion text file to \f[I]Radiance\f[R]
| 331 |
T}
| 332 |
T{
| 333 |
\f[B]genblinds\f[R]
| 334 |
T} T{
| 335 |
T} T{
| 336 |
X
| 337 |
T} T{
| 338 |
Generate curved venetian blinds
| 339 |
T}
| 340 |
T{
| 341 |
\f[B]genbox\f[R]
| 342 |
T} T{
| 343 |
T} T{
| 344 |
X
| 345 |
T} T{
| 346 |
Generate parallelepiped
| 347 |
T}
| 348 |
T{
| 349 |
\f[B]genclock\f[R]
| 350 |
T} T{
| 351 |
T} T{
| 352 |
X
| 353 |
T} T{
| 354 |
Generate analog clock
| 355 |
T}
| 356 |
T{
| 357 |
\f[B]genprism\f[R]
| 358 |
T} T{
| 359 |
T} T{
| 360 |
X
| 361 |
T} T{
| 362 |
Generate extruded polygon
| 363 |
T}
| 364 |
T{
| 365 |
\f[B]genrev\f[R]
| 366 |
T} T{
| 367 |
T} T{
| 368 |
X
| 369 |
T} T{
| 370 |
Generate surface of revolution
| 371 |
T}
| 372 |
T{
| 373 |
\f[B]gensky\f[R]
| 374 |
T} T{
| 375 |
T} T{
| 376 |
X
| 377 |
T} T{
| 378 |
Generate CIE sky distribution
| 379 |
T}
| 380 |
T{
| 381 |
\f[B]gensurf\f[R]
| 382 |
T} T{
| 383 |
T} T{
| 384 |
X
| 385 |
T} T{
| 386 |
Generate arbitrary surface patch
| 387 |
T}
| 388 |
T{
| 389 |
\f[B]genworm\f[R]
| 390 |
T} T{
| 391 |
T} T{
| 392 |
X
| 393 |
T} T{
| 394 |
Generate varying diameter curved path
| 395 |
T}
| 396 |
T{
| 397 |
\f[B]ies2rad\f[R]
| 398 |
T} T{
| 399 |
T} T{
| 400 |
X
| 401 |
T} T{
| 402 |
Convert IES luminaire file to \f[I]Radiance\f[R]
| 403 |
T}
| 404 |
T{
| 405 |
\f[B]mgf2rad\f[R]
| 406 |
T} T{
| 407 |
T} T{
| 408 |
X
| 409 |
T} T{
| 410 |
Convert MGF file to \f[I]Radiance\f[R]
| 411 |
T}
| 412 |
T{
| 413 |
\f[B]mkillum\f[R]
| 414 |
T} T{
| 415 |
X
| 416 |
T} T{
| 417 |
X
| 418 |
T} T{
| 419 |
Compute \f[I]illum\f[R] secondary sources
| 420 |
T}
| 421 |
T{
| 422 |
\f[B]nff2rad\f[R]
| 423 |
T} T{
| 424 |
T} T{
| 425 |
X
| 426 |
T} T{
| 427 |
Convert NFF file to \f[I]Radiance\f[R]
| 428 |
T}
| 429 |
T{
| 430 |
\f[B]objline\f[R]
| 431 |
T} T{
| 432 |
T} T{
| 433 |
X
| 434 |
T} T{
| 435 |
Generate line drawing of \f[I]Radiance\f[R] file
| 436 |
T}
| 437 |
T{
| 438 |
\f[B]objview\f[R]
| 439 |
T} T{
| 440 |
T} T{
| 441 |
X
| 442 |
T} T{
| 443 |
Quick view of \f[I]Radiance\f[R] object
| 444 |
T}
| 445 |
T{
| 446 |
\f[B]oconv\f[R]
| 447 |
T} T{
| 448 |
T} T{
| 449 |
X
| 450 |
T} T{
| 451 |
Compile \f[I]Radiance\f[R] scene description
| 452 |
T}
| 453 |
T{
| 454 |
\f[B]obj2rad\f[R]
| 455 |
T} T{
| 456 |
T} T{
| 457 |
X
| 458 |
T} T{
| 459 |
Convert Wavefront .OBJ file to \f[I]Radiance\f[R]
| 460 |
T}
| 461 |
T{
| 462 |
\f[B]rad\f[R]
| 463 |
T} T{
| 464 |
X
| 465 |
T} T{
| 466 |
T} T{
| 467 |
Render \f[I]Radiance\f[R] scene
| 468 |
T}
| 469 |
T{
| 470 |
\f[B]rad2mgf\f[R]
| 471 |
T} T{
| 472 |
X
| 473 |
T} T{
| 474 |
T} T{
| 475 |
Convert \f[I]Radiance\f[R] file to MGF
| 476 |
T}
| 477 |
T{
| 478 |
\f[B]raddepend\f[R]
| 479 |
T} T{
| 480 |
X
| 481 |
T} T{
| 482 |
T} T{
| 483 |
Determine scene file dependencies
| 484 |
T}
| 485 |
T{
| 486 |
\f[B]replmarks\f[R]
| 487 |
T} T{
| 488 |
X
| 489 |
T} T{
| 490 |
X
| 491 |
T} T{
| 492 |
Replace triangular markers with objects
| 493 |
T}
| 494 |
T{
| 495 |
\f[B]rpict\f[R]
| 496 |
T} T{
| 497 |
X
| 498 |
T} T{
| 499 |
T} T{
| 500 |
Batch rendering program
| 501 |
T}
| 502 |
T{
| 503 |
\f[B]rtrace\f[R]
| 504 |
T} T{
| 505 |
X
| 506 |
T} T{
| 507 |
T} T{
| 508 |
Customizable ray-tracer
| 509 |
T}
| 510 |
T{
| 511 |
\f[B]rview\f[R]
| 512 |
T} T{
| 513 |
X
| 514 |
T} T{
| 515 |
T} T{
| 516 |
Interactive renderer
| 517 |
T}
| 518 |
T{
| 519 |
\f[B]thf2rad\f[R]
| 520 |
T} T{
| 521 |
T} T{
| 522 |
X
| 523 |
T} T{
| 524 |
Convert GDS things file to \f[I]Radiance\f[R]
| 525 |
T}
| 526 |
T{
| 527 |
\f[B]tmesh2rad\f[R]
| 528 |
T} T{
| 529 |
T} T{
| 530 |
X
| 531 |
T} T{
| 532 |
Convert triangle mesh file to \f[I]Radiance\f[R]
| 533 |
T}
| 534 |
T{
| 535 |
\f[B]xform\f[R]
| 536 |
T} T{
| 537 |
X
| 538 |
T} T{
| 539 |
X
| 540 |
T} T{
| 541 |
Transform Radiance objects
| 542 |
T}
| 543 |
.TE
| 544 |
.ad
| 545 |
.LP
| 546 |
\f[B]Table 1.\f[R] Radiance programs that read and write scene
| 547 |
descriptions.
| 548 |
.SH 3
| 549 |
\f[BI]Radiance\f[B] C Library
| 550 |
.pdfhref O 3 "Radiance C Library"
| 551 |
.pdfhref M "radiance-c-library"
| 552 |
.LP
| 553 |
The principal library function for reading scene description files is
| 554 |
\f[C]readobj(inpspec)\f[R], defined in \f[C]src/common/readobj.c\f[R].
| 555 |
This routine takes the name of a file, or command beginning with `!', or
| 556 |
\f[C]NULL\f[R] if standard input is to be read, and loads the
| 557 |
\f[I]Radiance\f[R] data structures defined in
| 558 |
\f[C]src/common/object.h\f[R].
| 559 |
If loading \f[I]Radiance\f[R] data structures is not the action desired,
| 560 |
then a more custom approach is necessary, such as that used in
| 561 |
\f[C]src/gen/xform.c\f[R].
| 562 |
If using \f[I]Radiance\f[R] data structures is acceptable, but the data
| 563 |
need not remain resident in memory, then follow the lead in
| 564 |
\f[C]src/ot/getbbox.c\f[R] and use \f[C]src/ot/readobj2.c\f[R] instead.
| 565 |
In any case, the list of defined primitive types in
| 566 |
\f[C]src/common/otypes.h\f[R] is crucial.
| 567 |
.SH 2
| 568 |
Function File Format (.cal suffix)
| 569 |
.pdfhref O 2 "Function File Format \(.cal suffix\)"
| 570 |
.pdfhref M "function-file-format-.cal-suffix"
| 571 |
.LP
| 572 |
Function files are used throughout \f[I]Radiance\f[R] to specify
| 573 |
mathematical formulas and relations for procedural textures, patterns
| 574 |
and surfaces.
| 575 |
They are also used by filter programs such as rcalc to manipulate data,
| 576 |
and pcomb to manipulate pictures.
| 577 |
.PP
| 578 |
Function file syntax is simple and should be familiar to most
| 579 |
programmers, as it is based on fairly standard algebraic expressions.
| 580 |
Here is an example, which corresponds to the in-line commands given in
| 581 |
the previous section:
| 582 |
.IP
| 583 |
.nf
| 584 |
\f[C]
| 585 |
| 586 |
basin.cal - calculate coordinates for basin sink.
| 587 |
| 588 |
| 589 |
theta(s) = PI*(0.5+0.5*s);
| 590 |
phi(t) = 2*PI*t;
| 591 |
| 592 |
R(th,p) = 5 + ( 3.25*cos(p)\[ha]2 +
| 593 |
1.75*sin(p)\[ha]2 ) * sin(th)\[ha]2;
| 594 |
| 595 |
x(th,p) = R(th,p)*sin(th)*cos(p);
| 596 |
y(th,p) = R(th,p)*sin(th)*sin(p);
| 597 |
z(th,p) = R(th,p)*cos(th);
| 598 |
\f[]
| 599 |
.fi
| 600 |
.LP
| 601 |
In contrast to the usual semantics in programs where each statement
| 602 |
corresponds to an evaluation, statements in function files correspond to
| 603 |
\f[I]definitions\f[R].
| 604 |
Once a function or variable has been defined, it may be used in later
| 605 |
definitions, along with predefined functions such as \f[C]sin(x)\f[R]
| 606 |
and \f[C]cos(x)\f[R] and constants such as PI \**.
| 607 |
.FS
| 608 |
TBD - There once was a footnote here
| 609 |
.FE
| 610 |
(All math functions use standard C conventions, hence trigonometry is
| 611 |
done in radians rather than degrees.)
| 612 |
.PP
| 613 |
Evaluation order (operator precedence) follows standard rules of
| 614 |
algebra.
| 615 |
Exponentiation is performed first \f[C](x\[ha]y)\f[R], followed by
| 616 |
multiplication and division \f[C](x*y, x/y)\f[R], then addition and
| 617 |
subtraction \f[C](x+y, x-y)\f[R].
| 618 |
Unary minus is most tightly associated \f[C](-x)\f[R], and parentheses
| 619 |
override operator precedence in the usual way.
| 620 |
Semicolons separate statements, and white space is generally ignored.
| 621 |
Comments are enclosed by curly braces, which may be nested.
| 622 |
.PP
| 623 |
The above file does not actually \f[I]do\f[R] anything, it merely
| 624 |
defines functions that are useful by a program that does.
| 625 |
Taking our \f[B]gensurf\f[R] example from the previous section:
| 626 |
.IP
| 627 |
.nf
| 628 |
\f[C]
| 629 |
| 630 |
| 631 |
| 632 |
| 633 |
\f[]
| 634 |
.fi
| 635 |
.LP
| 636 |
The \f[B]-f\f[R] option loads in our file, which is then used to
| 637 |
evaluate expressions such as \f[C]15.5+x(theta(s),phi(t))\f[R] for
| 638 |
specific values of \f[C]s\f[R] and \f[C]t\f[R].
| 639 |
These variables range from 0 to 1 over the surface patch in increments
| 640 |
of @1 / 8@ and @1 / 29@, respectively.
| 641 |
(See the \f[B]gensurf\f[R] manual page for details.)
| 642 |
The entire expression for each evaluation could have been written in the
| 643 |
command line, but it is much more convenient to create a function file.
| 644 |
.SH 3
| 645 |
Language Features
| 646 |
.pdfhref O 3 "Language Features"
| 647 |
.pdfhref M "language-features"
| 648 |
.LP
| 649 |
Subtle features of the functional language provide much greater power
| 650 |
than first meets the eye.
| 651 |
One of these is the ability to define recursive functions.
| 652 |
The following example defines the factorial function (\f[I]n!\f[R]):
| 653 |
.IP
| 654 |
.nf
| 655 |
\f[C]
| 656 |
fact(n) : if(n-1.5, n*fact(n-1), 1);
| 657 |
\f[]
| 658 |
.fi
| 659 |
.LP
| 660 |
This uses the library function \f[C]if(cond,e1,e0)\f[R], which returns
| 661 |
\f[C]e1\f[R] if cond is greater than zero, and \f[C]e0\f[R] otherwise.
| 662 |
Since only one of these expressions is evaluated, \f[C]fact(n)\f[R] will
| 663 |
call itself until \f[C]n\f[R] is less than 2, when the \f[C]if\f[R]
| 664 |
expression returns 1\**.
| 665 |
.FS
| 666 |
Note that we compare \f[C]n\f[R] to 1.5, so as to avoid any round-off
| 667 |
problems caused by floating point math.
| 668 |
Caution is advised because all expressions are evaluated as
| 669 |
double-precision real, and comparisons to zero are unreliable.
| 670 |
.FE
| 671 |
The colon (`:') is used in place of the usual equals assignment (`=')
| 672 |
because we want this function to have the constant attribute, which
| 673 |
means any later appearance in an expression of \f[C]fact(ce)\f[R] where
| 674 |
ce is also a constant expression will be replaced by its value.
| 675 |
This can be an important savings in cases where an expression or
| 676 |
subexpression is expensive to evaluate, and only needs to be computed
| 677 |
once.
| 678 |
All of the standard library functions have the constant attribute.
| 679 |
(See the following section for a complete list.)
| 680 |
.PP
| 681 |
Another handy language feature is the ability to pass function names as
| 682 |
arguments.
| 683 |
A simple example of this is the following function, which computes the
| 684 |
numerical derivative of a function given as its first argument:
| 685 |
.IP
| 686 |
.nf
| 687 |
\f[C]
| 688 |
FTINY : 1e-7;
| 689 |
d1(f,x) = (f(x+FTINY)-f(x-FTINY))/FTINY/2;
| 690 |
\f[]
| 691 |
.fi
| 692 |
.LP
| 693 |
Evaluating \f[C]d1(sin,1.1)\f[R] using this formula yields 0.4536, which
| 694 |
is fairly close to the true derivative, which is \f[C]cos(1.1)\f[R].
| 695 |
.PP
| 696 |
A third language feature, which is normally transparent to the user, is
| 697 |
the notion of \f[I]contexts\f[R].
| 698 |
Identifiers may be composed of parts, starting with a name and
| 699 |
continuing with one or more context names.
| 700 |
Each name is delimited by a back-quote (`\[ga]').
| 701 |
Names themselves begin with a letter and continue with any sequence of
| 702 |
letters, digits, underscores and decimal points.
| 703 |
The following are examples of valid identifiers:
| 704 |
.IP
| 705 |
.nf
| 706 |
\f[C]
| 707 |
v1, V.W, x_rand\[ga]local, \[ga]A_, Qa_5\[ga]
| 708 |
\f[]
| 709 |
.fi
| 710 |
.LP
| 711 |
If a context mark appears at the beginning of the identifier, then its
| 712 |
reference must be local.
| 713 |
If it appears at the end, then its reference must be global.
| 714 |
A local reference must be resolved in the local context, i.e., no
| 715 |
contexts above this one will be searched.
| 716 |
A global reference must correspond to the original context, ignoring any
| 717 |
local redefinitions.
| 718 |
.PP
| 719 |
The reason that contexts are normally transparent is that they are
| 720 |
controlled by the calling program \[em] there are no explicit language
| 721 |
features for establishing contexts.
| 722 |
A new context is established automatically for each function file loaded
| 723 |
by the rendering programs.
| 724 |
That way, it is safe to reuse variable names that have been used in
| 725 |
other files, and even in the main initialization file,
| 726 |
\f[C]rayinit.cal\f[R].
| 727 |
.PP
| 728 |
Although not strictly necessary, there are two good reasons to define
| 729 |
variables and functions before referencing them in a function file.
| 730 |
One is related to contexts.
| 731 |
If a previous definition of a variable name is given in an enclosing
| 732 |
context (e.g., \f[C]rayinit.cal\f[R]), then that reference will be used
| 733 |
rather than a later one in the current context, unless the reference is
| 734 |
made explicitly local by starting the identifier with a context mark.
| 735 |
The second reason for defining before referencing is constant
| 736 |
expressions.
| 737 |
If a variable or function has the constant attribute (i.e., defined with
| 738 |
`:' instead of `='), then a later subexpression referencing it can be
| 739 |
replaced by its evaluated result during compilation.
| 740 |
If the constant is not defined until after it is referenced, it remains
| 741 |
as a reference, which takes time to evaluate each time.
| 742 |
.PP
| 743 |
Other features of the language are truly transparent, but knowledge of
| 744 |
them can help one to write more efficient function files:
| 745 |
.IP \[bu] 3
| 746 |
Once a variable has been evaluated, the result is cached and it is not
| 747 |
reevaluated unless the client program changes an internal counter
| 748 |
(\f[C]eclock\f[R]), which indicates that something has changed.
| 749 |
This means that using variables to hold frequently used values will not
| 750 |
only simplify the function file, it will save time during evaluation.
| 751 |
.IP \[bu] 3
| 752 |
An argument passed in a function call is not evaluated until the
| 753 |
function calls for it specifically, and the result is also cached to
| 754 |
avoid redundant calculation.
| 755 |
The conditional evaluation feature is actually a requirement for
| 756 |
recursive functions to work, but caching is not.
| 757 |
Argument value caching means it is more efficient to pass an
| 758 |
expensive-to-compute expression than to have the function compute it
| 759 |
internally if it appears more than once in the function definition.
| 760 |
This is especially true for recursive functions with deep call trees.
| 761 |
.SH 3
| 762 |
Standard Definitions (Library)
| 763 |
.pdfhref O 3 "Standard Definitions \(Library\)"
| 764 |
.pdfhref M "standard-definitions-library"
| 765 |
.LP
| 766 |
The following are always defined:
| 767 |
.IP "\f[B]\f[CB]if(a, b, c)\f[B]\f[R]" 3
| 768 |
Conditional expression.
| 769 |
If a is positive, return b, else return c.
| 770 |
.RS 3
| 771 |
.RE
| 772 |
.IP "\f[B]\f[CB]select(N, a1, a2, ..)\f[B]\f[R]" 3
| 773 |
Return Nth argument.
| 774 |
If N is 0, then return the count of arguments excluding the first.
| 775 |
This provides basic array functionality.
| 776 |
.RS 3
| 777 |
.RE
| 778 |
.IP "\f[B]\f[CB]sqrt(x)\f[B]\f[R]" 3
| 779 |
Return square root of \f[C]x\f[R], where \f[C]x >= 0\f[R].
| 780 |
.RS 3
| 781 |
.RE
| 782 |
.IP "\f[B]\f[CB]sin(x), cos(x), tan(x), asin(x), acos(x), atan(x), atan2(y,x)\f[B]\f[R]" 3
| 783 |
Standard trigonometry functions.
| 784 |
.RS 3
| 785 |
.RE
| 786 |
.IP "\f[B]\f[CB]floor(x), ceil(x)\f[B]\f[R]" 3
| 787 |
Greatest lower bound and least upper bound (integer).
| 788 |
.RS 3
| 789 |
.RE
| 790 |
.IP "\f[B]\f[CB]exp(x), log(x), log10(x)\f[B]\f[R]" 3
| 791 |
Exponent and logarithm functions.
| 792 |
.RS 3
| 793 |
.RE
| 794 |
.IP "\f[B]\f[CB]rand(x)\f[B]\f[R]" 3
| 795 |
Return pseudo-random number in the range [0,1) for any argument x.
| 796 |
The same return value is guaranteed for the same argument.
| 797 |
.RS 3
| 798 |
.RE
| 799 |
.LP
| 800 |
The following are sometimes defined, depending on the program:
| 801 |
.IP "\f[B]PI\f[R]" 3
| 802 |
The ratio of a circle\[cq]s circumference to its diameter.
| 803 |
.RS 3
| 804 |
.RE
| 805 |
.IP "\f[B]\f[CB]erf(z), erfc(z)\f[B]\f[R]" 3
| 806 |
Error function and complimentary error function.
| 807 |
.RS 3
| 808 |
.RE
| 809 |
.IP "\f[B]\f[CB]j0(x), j1(x), jn(n,x), y0(x), y1(x), yn(n,x)\f[B]\f[R]" 3
| 810 |
Bessel functions.
| 811 |
.RS 3
| 812 |
.RE
| 813 |
.IP "\f[B]\f[CB]hermite(p0,p1,r0,r1,t)\f[B]\f[R]" 3
| 814 |
One-dimensional Hermite polynomial.
| 815 |
.RS 3
| 816 |
.RE
| 817 |
.LP
| 818 |
The rendering programs also define the following noise functions:
| 819 |
.IP "\f[B]\f[CB]noise3(x,y,z), noise3x(x,y,z), noise3y(x,y,z), noise3z(x,y,z)\f[B]\f[R]" 3
| 820 |
Perlin noise function and its gradient [Perlin85][Arvo91,p.396].
| 821 |
.RS 3
| 822 |
.RE
| 823 |
.IP "\f[B]\f[CB]fnoise3(x,y,z)\f[B]\f[R]" 3
| 824 |
Fractal noise function, ranging from -1 to 1.
| 825 |
.RS 3
| 826 |
.RE
| 827 |
.LP
| 828 |
Interaction with the renderer is achieved via special purpose variables
| 829 |
and functions whose values correspond to the current ray intersection
| 830 |
and the calling primitive.
| 831 |
Unlike the above functions, none of these have the constant attribute
| 832 |
since their values change from one ray to the next:
| 833 |
.IP "\f[B]\f[CB]Dx, Dy, Dz\f[B]\f[R]" 3
| 834 |
ray direction
| 835 |
.RS 3
| 836 |
.RE
| 837 |
.IP "\f[B]\f[CB]Nx, Ny, Nz\f[B]\f[R]" 3
| 838 |
surface normal
| 839 |
.RS 3
| 840 |
.RE
| 841 |
.LP
| 842 |
\f[C]Px, Py, Pz\f[R] :intersection point
| 843 |
.IP "\f[B]\f[CB]T\f[B]\f[R]" 3
| 844 |
distance from start
| 845 |
.RS 3
| 846 |
.RE
| 847 |
.IP "\f[B]\f[CB]Ts\f[B]\f[R]" 3
| 848 |
single ray (shadow) distance
| 849 |
.RS 3
| 850 |
.RE
| 851 |
.IP "\f[B]\f[CB]Rdot\f[B]\f[R]" 3
| 852 |
ray dot product
| 853 |
.RS 3
| 854 |
.RE
| 855 |
.IP "\f[B]\f[CB]S\f[B]\f[R]" 3
| 856 |
world scale
| 857 |
.RS 3
| 858 |
.RE
| 859 |
.IP "\f[B]\f[CB]Tx, Ty, Tz\f[B]\f[R]" 3
| 860 |
world origin
| 861 |
.RS 3
| 862 |
.RE
| 863 |
.IP "\f[B]\f[CB]Ix, Iy, Iz\f[B]\f[R]" 3
| 864 |
world i unit vector
| 865 |
.RS 3
| 866 |
.RE
| 867 |
.IP "\f[B]\f[CB]Jx, Jy, Jz\f[B]\f[R]" 3
| 868 |
world j unit vector
| 869 |
.RS 3
| 870 |
.RE
| 871 |
.IP "\f[B]\f[CB]Kx, Ky, Kz\f[B]\f[R]" 3
| 872 |
world k unit vector
| 873 |
.RS 3
| 874 |
.RE
| 875 |
.IP "\f[B]\f[CB]arg(n)\f[B]\f[R]" 3
| 876 |
real arguments, arg(0) is count
| 877 |
.RS 3
| 878 |
.RE
| 879 |
.LP
| 880 |
For BRDF primitives, the following variables are also available:
| 881 |
.IP "\f[B]\f[CB]NxP, NyP, NzP\f[B]\f[R]" 3
| 882 |
perturbed surface normal
| 883 |
.RS 3
| 884 |
.RE
| 885 |
.IP "\f[B]\f[CB]RdotP\f[B]\f[R]" 3
| 886 |
perturbed ray dot product
| 887 |
.RS 3
| 888 |
.RE
| 889 |
.IP "\f[B]\f[CB]CrP, CgP, CbP\f[B]\f[R]" 3
| 890 |
perturbed material color
| 891 |
.RS 3
| 892 |
.RE
| 893 |
.LP
| 894 |
For prism1 and prism2 primitives, the following are available:
| 895 |
.IP "\f[B]\f[CB]DxA, DyA, DzA\f[B]\f[R]" 3
| 896 |
direction to target light source
| 897 |
.RS 3
| 898 |
.RE
| 899 |
.LP
| 900 |
Other functions, variables and constants are defined as well in the file
| 901 |
\f[C]src/rt/rayinit.cal\f[R], which gets installed in the standard
| 902 |
\f[I]Radiance\f[R] library directory and can be modified or appended as
| 903 |
desired\**.
| 904 |
.FS
| 905 |
It is usually a good idea to store any such customized files in a
| 906 |
personal library location and set the \f[C]RAYPATH\f[R] environment
| 907 |
variable to search there first.
| 908 |
This way, it does not affect other users or get overwritten during the
| 909 |
next system installation.
| 910 |
.FE
| 911 |
.SH 3
| 912 |
| 913 |
| 914 |
.pdfhref M "radiance-programs-1"
| 915 |
.LP
| 916 |
Table 2 shows \f[I]Radiance\f[R] programs that read and write function
| 917 |
files.
| 918 |
.PP
| 919 |
.na
| 920 |
.TS
| 921 |
delim(@@) tab( );
| 922 |
l l l l.
| 923 |
T{
| 924 |
Program
| 925 |
T} T{
| 926 |
Read
| 927 |
T} T{
| 928 |
Write
| 929 |
T} T{
| 930 |
Function
| 931 |
T}
| 932 |
_
| 933 |
T{
| 934 |
\f[B]calc\f[R]
| 935 |
T} T{
| 936 |
X
| 937 |
T} T{
| 938 |
X
| 939 |
T} T{
| 940 |
Interactive calculator
| 941 |
T}
| 942 |
T{
| 943 |
\f[B]genrev\f[R]
| 944 |
T} T{
| 945 |
X
| 946 |
T} T{
| 947 |
T} T{
| 948 |
| 949 |
T}
| 950 |
T{
| 951 |
\f[B]gensurf\f[R]
| 952 |
T} T{
| 953 |
X
| 954 |
T} T{
| 955 |
T} T{
| 956 |
| 957 |
T}
| 958 |
T{
| 959 |
\f[B]genworm\f[R]
| 960 |
T} T{
| 961 |
X
| 962 |
T} T{
| 963 |
T} T{
| 964 |
| 965 |
T}
| 966 |
T{
| 967 |
\f[B]macbethcal\f[R]
| 968 |
T} T{
| 969 |
T} T{
| 970 |
X
| 971 |
T} T{
| 972 |
Compute image color & contrast correction
| 973 |
T}
| 974 |
T{
| 975 |
\f[B]pcomb\f[R]
| 976 |
T} T{
| 977 |
X
| 978 |
T} T{
| 979 |
T} T{
| 980 |
Perform arbitrary math on picture(s)
| 981 |
T}
| 982 |
T{
| 983 |
\f[B]rcalc\f[R]
| 984 |
T} T{
| 985 |
X
| 986 |
T} T{
| 987 |
T} T{
| 988 |
Record stream calculator
| 989 |
T}
| 990 |
T{
| 991 |
\f[B]rpict\f[R]
| 992 |
T} T{
| 993 |
X
| 994 |
T} T{
| 995 |
T} T{
| 996 |
| 997 |
T}
| 998 |
T{
| 999 |
\f[B]rtrace\f[R]
| 1000 |
T} T{
| 1001 |
X
| 1002 |
T} T{
| 1003 |
T} T{
| 1004 |
| 1005 |
T}
| 1006 |
T{
| 1007 |
\f[B]rview\f[R]
| 1008 |
T} T{
| 1009 |
X
| 1010 |
T} T{
| 1011 |
T} T{
| 1012 |
| 1013 |
T}
| 1014 |
T{
| 1015 |
\f[B]tabfunc\f[R]
| 1016 |
T} T{
| 1017 |
T} T{
| 1018 |
X
| 1019 |
T} T{
| 1020 |
Create function file from tabulated data
| 1021 |
T}
| 1022 |
.TE
| 1023 |
.ad
| 1024 |
.LP
| 1025 |
\f[B]Table 2.\f[R] Programs in the \f[I]Radiance\f[R] distribution that
| 1026 |
read and write function files.
| 1027 |
.PP
| 1028 |
In addition, the program \f[B]ev\f[R] evaluates expressions given as
| 1029 |
command line arguments, though it does not handle function files or
| 1030 |
definitions.
| 1031 |
There are also a number of 2-d plotting routines that use a slightly
| 1032 |
modified statement syntax, called \f[B]bgraph\f[R], \f[B]dgraph\f[R],
| 1033 |
\f[B]gcomp\f[R], and \f[B]igraph\f[R].
| 1034 |
Additional utility programs are useful in combination with rcalc for
| 1035 |
data analysis and scene generation.
| 1036 |
The program \f[B]cnt\f[R] generates simple records to drive
| 1037 |
\f[B]rcalc\f[R], and the \f[B]total\f[R] program is handy for adding up
| 1038 |
results.
| 1039 |
The \f[B]histo\f[R] program computes histograms needed for certain types
| 1040 |
of statistical analysis.
| 1041 |
The \f[B]lam\f[R] program concatenates columns from multiple input
| 1042 |
files, and \f[B]neat\f[R] neatens up columns for better display.
| 1043 |
.SH 3
| 1044 |
| 1045 |
| 1046 |
.pdfhref M "radiance-c-library-1"
| 1047 |
.LP
| 1048 |
The standard routines for loading and evaluating function files are
| 1049 |
divided into three modules, \f[C]src/common/calexpr.c\f[R] for
| 1050 |
expression parsing and evaluation, \f[C]src/common/caldefn.c\f[R] for
| 1051 |
variable and function storage and lookup, and
| 1052 |
\f[C]src/common/calfunc.c\f[R] for library function storage and function
| 1053 |
evaluation.
| 1054 |
There is a fourth module for writing out expressions called
| 1055 |
\f[C]src/common/calprnt.c\f[R], which we will not discuss.
| 1056 |
They all use the header file \f[C]src/common/calcomp.h\f[R], which
| 1057 |
defines common data structures and evaluation macros.
| 1058 |
Of these, the three most often used declarations for external routines
| 1059 |
are:
| 1060 |
.IP "\f[B]\f[CB]typedef struct epnode EPNODE;\f[B]\f[R]" 3
| 1061 |
Expression parse tree node.
| 1062 |
Some routines return pointers to this structure type, and the main
| 1063 |
evaluation macro, \f[C]evalue(ep)\f[R], takes an argument of this type.
| 1064 |
.RS 3
| 1065 |
.RE
| 1066 |
.IP "\f[B]\f[CB](double) evalue(ep);\f[B]\f[R]" 3
| 1067 |
Evaluate an expression parse tree.
| 1068 |
Uses node type table to access appropriate function depending on root
| 1069 |
node type.
| 1070 |
(E.g., an addition node calls \f[C]eadd(ep)\f[R].)
| 1071 |
.RS 3
| 1072 |
.RE
| 1073 |
.IP "\f[B]\f[CB]extern unsigned long eclock;\f[B]\f[R]" 3
| 1074 |
This is a counter used to determine when variable values need updating.
| 1075 |
The initial value is 0, which tells the routines always to reevaluate
| 1076 |
variables.
| 1077 |
Once incremented to 1, variable evaluations are cached and not
| 1078 |
recomputed until \f[C]eclock\f[R] is incremented again.
| 1079 |
Usually, client programs increment \f[C]eclock\f[R] each time
| 1080 |
definitions or internal states affecting returned values change.
| 1081 |
This assures the quickest evaluation of correct results.
| 1082 |
.RS 3
| 1083 |
.RE
| 1084 |
.LP
| 1085 |
The usual approach to handling definitions is to compile them into the
| 1086 |
central lookup table; variable and function references are later
| 1087 |
evaluated by traversing the stored parse trees.
| 1088 |
Syntax errors and undefined symbol errors during evaluation result in
| 1089 |
calls to the user-definable routine \f[C]eputs(s)\f[R] to report the
| 1090 |
error and \f[C]quit(status)\f[R] to exit the program.
| 1091 |
Domain and range errors during evaluation set \f[C]errno\f[R], then call
| 1092 |
the user-definable routine \f[C]wputs(s)\f[R] to report the error and
| 1093 |
return zero as the expression result.
| 1094 |
Following are standard routines provided for parsing from a file and
| 1095 |
parsing from a string:
| 1096 |
.IP "\f[B]\f[CB]EPNODE *eparse(char *expr);\f[B]\f[R]" 3
| 1097 |
Compile the string expr into a parse tree for later evaluation with
| 1098 |
evalue(ep).
| 1099 |
.RS 3
| 1100 |
.RE
| 1101 |
.IP "\f[B]\f[CB]epfree(EPNODE *ep);\f[B]\f[R]" 3
| 1102 |
Free memory associated with ep, including any variables referenced if
| 1103 |
they are no longer defined.
| 1104 |
.RS 3
| 1105 |
.RE
| 1106 |
.IP "\f[B]\f[CB]double eval(char *expr);\f[B]\f[R]" 3
| 1107 |
Immediately parse, evaluate and free the given string expression.
| 1108 |
.RS 3
| 1109 |
.RE
| 1110 |
.IP "\f[B]\f[CB]fcompile(char *fname);\f[B]\f[R]" 3
| 1111 |
Compile definitions from the given file, or standard input if fname is
| 1112 |
NULL.
| 1113 |
.RS 3
| 1114 |
.RE
| 1115 |
.IP "\f[B]\f[CB]scompile(char *str, char *fn, int ln);\f[B]\f[R]" 3
| 1116 |
Compile definitions from the string str, taken from file fn at line
| 1117 |
number ln.
| 1118 |
If no file is associated, fn can be NULL, and ln can be 0.
| 1119 |
.RS 3
| 1120 |
.RE
| 1121 |
.LP
| 1122 |
The following routines allow one to control the current context for
| 1123 |
definition lookup and storage:
| 1124 |
.IP "\f[B]\f[CB]char *setcontext(char *ctx);\f[B]\f[R]" 3
| 1125 |
Set the current context to ctx.
| 1126 |
If ctx is NULL, then simply return the current context.
| 1127 |
An empty string sets the global context.
| 1128 |
.RS 3
| 1129 |
.RE
| 1130 |
.IP "\f[B]\f[CB]char *pushcontext(char *name);\f[B]\f[R]" 3
| 1131 |
Push another context onto the stack.
| 1132 |
Return the new (full) context.
| 1133 |
.RS 3
| 1134 |
.RE
| 1135 |
.IP "\f[B]\f[CB]char *popcontext();\f[B]\f[R]" 3
| 1136 |
Pop the top context name off the stack.
| 1137 |
| 1138 |
.RS 3
| 1139 |
.RE
| 1140 |
.LP
| 1141 |
The following functions permit the explicit setting of variable and
| 1142 |
function values:
| 1143 |
.IP "\f[B]\f[CB]varset(char *vname, int assign, double val);\f[B]\f[R]" 3
| 1144 |
Set the specified variable to the given value, using a constant
| 1145 |
assignment if assign is `:' or a regular one if it is `='.
| 1146 |
This is always faster than compiling a string to do the same thing.
| 1147 |
.RS 3
| 1148 |
.RE
| 1149 |
.IP "\f[B]\f[CB]funset(char *fname, int nargs, int assign, double (*fptr)(char *fn));\f[B]\f[R]" 3
| 1150 |
Assign the specified library function, which takes a minimum of nargs
| 1151 |
arguments.
| 1152 |
The function will have the constant attribute if assign is `:', or not
| 1153 |
if it is `='.
| 1154 |
The only argument to the referenced function pointer is the function
| 1155 |
name, which will equal fname.
| 1156 |
(This string must therefore be declared static.)
| 1157 |
This offers a convenient method to identify calls to an identical
| 1158 |
function assigned multiple tasks.
| 1159 |
Argument values are obtained with calls back to the argument(n) library
| 1160 |
function.
| 1161 |
.RS 3
| 1162 |
.RE
| 1163 |
.LP
| 1164 |
The following functions are provided for evaluating a function or
| 1165 |
variable in the current definition set:
| 1166 |
.IP "\f[B]\f[CB]double varvalue(char *vname);\f[B]\f[R]" 3
| 1167 |
Evaluate the given variable and return the result.
| 1168 |
Since a hash lookup is necessary to resolve the reference, this is
| 1169 |
slightly less efficient than evaluating a compiled expression via
| 1170 |
evalue(ep), which uses soft links generated and maintained during
| 1171 |
compilation.
| 1172 |
.RS 3
| 1173 |
.RE
| 1174 |
.IP "\f[B]\f[CB]double funvalue(char *fn, int n, double a);\f[B]\f[R]" 3
| 1175 |
Evaluate the function fn, passing n real arguments in the array a.
| 1176 |
There is currently no mechanism for passing functions or function name
| 1177 |
arguments from client programs.
| 1178 |
.RS 3
| 1179 |
.RE
| 1180 |
.LP
| 1181 |
These routines can be used to check the existence of a specific function
| 1182 |
or variable:
| 1183 |
.IP "\f[B]\f[CB]int vardefined(char *vname);\f[B]\f[R]" 3
| 1184 |
Return non-zero if the named variable is defined.
| 1185 |
(If the symbol is defined as a function, zero is returned.)
| 1186 |
.RS 3
| 1187 |
.RE
| 1188 |
.IP "\f[B]\f[CB]int fundefined(char *fname);\f[B]\f[R]" 3
| 1189 |
Return the number of required arguments for the named function if it is
| 1190 |
defined, or zero if it is not defined.
| 1191 |
(If the symbol is defined as a variable, zero is returned.)
| 1192 |
.RS 3
| 1193 |
.RE
| 1194 |
.LP
| 1195 |
These routines allow definitions to be cleared:
| 1196 |
.IP "\f[B]\f[CB]dclear(char *dname);\f[B]\f[R]" 3
| 1197 |
Clear the given variable or function, unless it is a constant
| 1198 |
expression.
| 1199 |
.RS 3
| 1200 |
.RE
| 1201 |
.IP "\f[B]\f[CB]dremove(char *dname);\f[B]\f[R]" 3
| 1202 |
Clear the given variable or function, even if it is a constant
| 1203 |
expression.
| 1204 |
Library definitions cannot be removed, except by calling funset with a
| 1205 |
\f[C]NULL\f[R] pointer for the function argument.
| 1206 |
.RS 3
| 1207 |
.RE
| 1208 |
.IP "\f[B]\f[CB]dcleanup(int level);\f[B]\f[R]" 3
| 1209 |
Clear definitions.
| 1210 |
If level is 0, then just clear variable definitions.
| 1211 |
If level is 2, then clear constants as well.
| 1212 |
If the current context is local, then only local definitions will be
| 1213 |
affected.
| 1214 |
If global, all definitions in all contexts will be affected.
| 1215 |
.RS 3
| 1216 |
.RE
| 1217 |
.LP
| 1218 |
These routines may be used during library function evaluation:
| 1219 |
.IP "\f[B]\f[CB]int nargum();\f[B]\f[R]" 3
| 1220 |
Determine the number of arguments available in the current function
| 1221 |
evaluation context.
| 1222 |
.RS 3
| 1223 |
.RE
| 1224 |
.IP "\f[B]\f[CB]double argument(int n);\f[B]\f[R]" 3
| 1225 |
Evaluate and return the nth argument.
| 1226 |
.RS 3
| 1227 |
.RE
| 1228 |
.IP "\f[B]\f[CB]char *argfun(n);\f[B]\f[R]" 3
| 1229 |
Get the name of the function passed as argument n.\ (Generates an error
| 1230 |
if the nth argument is not a function.)
| 1231 |
.RS 3
| 1232 |
.RE
| 1233 |
.LP
| 1234 |
Other, even more specialized routines are provided for controlling the
| 1235 |
parsing process, printing out expressions and sifting through stored
| 1236 |
definitions, but these are not accessed by most client programs.
| 1237 |
Worth noting are the various compile flags that affect which features of
| 1238 |
the expression language are included.
| 1239 |
The standard library sets the flags \f[C]-DVARIABLE\f[R],
| 1240 |
\f[C]-DFUNCTION\f[R], \f[C]-DRCONST\f[R], and \f[C]-DBIGLIB\f[R].
| 1241 |
Here is a list of compile flags and their meanings:
| 1242 |
.IP "\f[B]\f[CB]-DVARIABLE\f[B]\f[R]" 3
| 1243 |
Allow user-defined variables and (if \f[C]-DFUNCTION\f[R]) user- defined
| 1244 |
functions.
| 1245 |
.RS 3
| 1246 |
.RE
| 1247 |
.IP "\f[B]\f[CB]-DFUNCTION\f[B]\f[R]" 3
| 1248 |
Compile in library functions and (if \f[C]-DVARIABLE\f[R]) allow
| 1249 |
user-supplied function definitions.
| 1250 |
.RS 3
| 1251 |
.RE
| 1252 |
.IP "\f[B]\f[CB]-DBIGLIB\f[B]\f[R]" 3
| 1253 |
Include larger library of standard functions, i.e., standard C math
| 1254 |
library.
| 1255 |
Otherwise, only minimal library is compiled in, and other functions may
| 1256 |
be added using \f[C]funset\f[R].
| 1257 |
.RS 3
| 1258 |
.RE
| 1259 |
.IP "\f[B]\f[CB]-DRCONST\f[B]\f[R]" 3
| 1260 |
Reduce constant subexpressions during compilation.
| 1261 |
This can result in substantial savings during later evaluation, but the
| 1262 |
original user-supplied expressions are lost.
| 1263 |
.RS 3
| 1264 |
.RE
| 1265 |
.IP "\f[B]\f[CB]-DREDEFW\f[B]\f[R]" 3
| 1266 |
Issue a warning via \f[C]wputs(s)\f[R] if a new definition hides a
| 1267 |
constant definition or library function, or replaces an existing,
| 1268 |
distinct definition for the same symbol.
| 1269 |
(The \f[C]varset\f[R] routine never generates warnings, however.)
| 1270 |
.RS 3
| 1271 |
.RE
| 1272 |
.IP "\f[B]\f[CB]-DINCHAN\f[B]\f[R]" 3
| 1273 |
Provide for \f[C]\[rs]$N\f[R] syntax for input channels, which result in
| 1274 |
callbacks to client-supplied chanvalue(n) routine on each evaluation.
| 1275 |
.RS 3
| 1276 |
.RE
| 1277 |
.IP "\f[B]\f[CB]-DOUTCHAN\f[B]\f[R]" 3
| 1278 |
Provide for \f[C]\[rs]$N\f[R] lvalue syntax for output channels, which
| 1279 |
are evaluated via the chanout(cs) library function, which calls
| 1280 |
\f[C](*cs)(n, value)\f[R]for each assigned channel definition.
| 1281 |
.RS 3
| 1282 |
.RE
| 1283 |
.SH 2
| 1284 |
Data File Format (.dat suffix)
| 1285 |
.pdfhref O 2 "Data File Format \(.dat suffix\)"
| 1286 |
.pdfhref M "data-file-format-.dat-suffix"
| 1287 |
.LP
| 1288 |
Although it is possible to store tabular data in a function file using
| 1289 |
the select library function, it is more convenient and efficient to
| 1290 |
devote a special file format to this purpose.
| 1291 |
\f[I]Radiance\f[R] data files store scalar values on an N-dimensional
| 1292 |
rectangular grid.
| 1293 |
Grid (independent) axes may be regularly or irregularly divided, as
| 1294 |
shown in Figure 1.
| 1295 |
This data is interpolated during rendering (using N-dimensional linear
| 1296 |
interpolation) to compute the desired values.
| 1297 |
.PSPIC "figure1.eps"
| 1298 |
.ce 1000
| 1299 |
Division of axes in .dat file
| 1300 |
.ce 0
| 1301 |
.PP
| 1302 |
\f[B]Figure 1.\f[R] A 2-dimensional grid with one regularly divided axis
| 1303 |
and one irregularly divided axis.
| 1304 |
Each intersection corresponds to a data value that appears in the file.
| 1305 |
.PP
| 1306 |
Data files are broken into two sections, the header and the body.
| 1307 |
The header specifies the grid, and the body contains the data values in
| 1308 |
a standard order.
| 1309 |
The first value in the file is a positive integer indicating the number
| 1310 |
of dimensions.
| 1311 |
Next comes that number of axis specifications, in one of two formats.
| 1312 |
For a regularly divided axis, the starting and ending value is given,
| 1313 |
followed by the number of divisions.
| 1314 |
For an irregularly divided axis, two zeros are followed by the number of
| 1315 |
divisions then that number of division values.
| 1316 |
The two zeros are merely there to indicate an irregular spacing is being
| 1317 |
specified.
| 1318 |
Once all the axes have been given, the header is done and the body of
| 1319 |
the file begins, which consists of one data value after another.
| 1320 |
The ordering of the data is such that the last axis given is the one
| 1321 |
being traversed most rapidly, similar to a static array assignment in C.
| 1322 |
.PP
| 1323 |
A file corresponding to the topology shown in Figure 1 is:
| 1324 |
.IP
| 1325 |
.nf
| 1326 |
\f[C]
| 1327 |
######### Header ########
| 1328 |
2 # Two-dimensional data array
| 1329 |
0.5 0.1 5 # The regularly spaced axis
| 1330 |
0 0 5 3 5 10 16 20 # The irregularly spaced axis
| 1331 |
########## Body #########
| 1332 |
# The data values, starting with the
| 1333 |
# upper left, moving right then down:
| 1334 |
19.089 7.001 14.647 6.3671 8.0003
| 1335 |
3.8388 11.873 19.294 16.605 2.7435
| 1336 |
16.699 6.387 2.8123 16.195 17.615
| 1337 |
14.36 14.413 16.184 15.635 4.5403
| 1338 |
3.6740 14.550 10.332 15.932 1.2678
| 1339 |
\f[]
| 1340 |
.fi
| 1341 |
.LP
| 1342 |
Comments begin with a pound sign (`#') and continue to the end of the
| 1343 |
line.
| 1344 |
White space is ignored except as a data separator, thus the position of
| 1345 |
header and data values on each line is irrelevant except to improve
| 1346 |
readability.
| 1347 |
.SH 3
| 1348 |
| 1349 |
| 1350 |
.pdfhref M "radiance-programs-2"
| 1351 |
.LP
| 1352 |
Table 3 shows \f[I]Radiance\f[R] programs that read and write data
| 1353 |
files.
| 1354 |
.PP
| 1355 |
.na
| 1356 |
.TS
| 1357 |
delim(@@) tab( );
| 1358 |
l l l l.
| 1359 |
T{
| 1360 |
Program
| 1361 |
T} T{
| 1362 |
Read
| 1363 |
T} T{
| 1364 |
Write
| 1365 |
T} T{
| 1366 |
Function
| 1367 |
T}
| 1368 |
_
| 1369 |
T{
| 1370 |
\f[B]ies2rad\f[R]
| 1371 |
T} T{
| 1372 |
T} T{
| 1373 |
X
| 1374 |
T} T{
| 1375 |
| 1376 |
T}
| 1377 |
T{
| 1378 |
\f[B]mgf2rad\f[R]
| 1379 |
T} T{
| 1380 |
T} T{
| 1381 |
X
| 1382 |
T} T{
| 1383 |
| 1384 |
T}
| 1385 |
T{
| 1386 |
\f[B]rpict\f[R]
| 1387 |
T} T{
| 1388 |
X
| 1389 |
T} T{
| 1390 |
T} T{
| 1391 |
| 1392 |
T}
| 1393 |
T{
| 1394 |
\f[B]rtrace\f[R]
| 1395 |
T} T{
| 1396 |
X
| 1397 |
T} T{
| 1398 |
T} T{
| 1399 |
| 1400 |
T}
| 1401 |
T{
| 1402 |
\f[B]rview\f[R]
| 1403 |
T} T{
| 1404 |
X
| 1405 |
T} T{
| 1406 |
T} T{
| 1407 |
| 1408 |
T}
| 1409 |
.TE
| 1410 |
.ad
| 1411 |
.LP
| 1412 |
\f[B]Table 3.\f[R] Programs in the \f[I]Radiance\f[R] distribution that
| 1413 |
read and write data files.
| 1414 |
.SH 3
| 1415 |
| 1416 |
| 1417 |
.pdfhref M "radiance-c-library-2"
| 1418 |
.LP
| 1419 |
The header file \f[C]src/rt/data.h\f[R] gives the standard data
| 1420 |
structures used by the routines in \f[C]src/rt/data.c\f[R] for reading
| 1421 |
and interpolating data files.
| 1422 |
The main data type is \f[C]DATARRAY\f[R], which is a structure
| 1423 |
containing the grid specification and a pointer to the data array, which
| 1424 |
is of the type \f[C]DATATYPE\f[R] (normally \f[B]float\f[R] to save
| 1425 |
space).
| 1426 |
.PP
| 1427 |
The main routine for reading data files is \f[C]getdata(dname)\f[R],
| 1428 |
which searches the standard \f[I]Radiance\f[R] library locations set by
| 1429 |
the \f[C]RAYPATH\f[R] environment variable.
| 1430 |
The return value is a pointer to the loaded \f[C]DATARRAY\f[R], which
| 1431 |
may have been loaded by a previous call.
| 1432 |
(The routine keeps a hash table of loaded files to minimize time and
| 1433 |
memory requirements.)
| 1434 |
The \f[C]freedata(dname)\f[R] routine frees memory associated with the
| 1435 |
named data file, or all data arrays if \f[C]dname\f[R] is
| 1436 |
\f[C]NULL\f[R].
| 1437 |
.PP
| 1438 |
The routine that interpolates data values is \f[C]datavalue(dp,pt)\f[R],
| 1439 |
which takes a \f[C]DATARRAY\f[R] pointer and an array of
| 1440 |
\f[B]double\f[R]s of the appropriate length (the number of dimensions in
| 1441 |
\f[C]dp\f[R]).
| 1442 |
The \f[B]double\f[R] returned is the interpolated value at that point in
| 1443 |
the scalar field.
| 1444 |
If the requested point lies outside the data\[cq]s grid, it is
| 1445 |
extrapolated from the perimeter values up to a distance of one division
| 1446 |
in each dimension, and falls off harmonically to zero outside of that.
| 1447 |
This was selected as the most robust compromise, but to be safe it is
| 1448 |
generally best to avoid giving out-of-domain points to
| 1449 |
\f[C]datavalue\f[R].
| 1450 |
.SH 2
| 1451 |
Font File Format (.fnt suffix)
| 1452 |
.pdfhref O 2 "Font File Format \(.fnt suffix\)"
| 1453 |
.pdfhref M "font-file-format-.fnt-suffix"
| 1454 |
.LP
| 1455 |
Font files are used for text patterns and mixtures, and by the
| 1456 |
\f[B]psign\f[R] program to generate simple text labels.
| 1457 |
Each character glyph is set up on a simple rectangular coordinate system
| 1458 |
running from [0,255] in x and y, and the glyph itself is a polygon.
| 1459 |
Figure 2 shows an example of the letter \[lq]A\[rq].
| 1460 |
.PSPIC "figure2.eps"
| 1461 |
.ce 1000
| 1462 |
Drawing of an A, based on coordinates
| 1463 |
.ce 0
| 1464 |
.PP
| 1465 |
\f[B]Figure 2.\f[R] A glyph for an \[lq]A\[rq] character in standard
| 1466 |
font coordinates.
| 1467 |
Note that the hole is made via a seam, just as with \f[I]Radiance\f[R]
| 1468 |
scene polygons.
| 1469 |
The actual aspect and spacing of the character will be determined by the
| 1470 |
client program.
| 1471 |
.PP
| 1472 |
Each glyph begins with the decimal value of that character\[cq]s index,
| 1473 |
which is 65 for \[lq]A\[rq] according to the ASCII standard.
| 1474 |
This is followed by the number of vertices, then the vertices themselves
| 1475 |
in @left ( x sub 1 , y sub 1 right ) , left ( x sub 2 , y sub 2 right )@
| 1476 |
order.
| 1477 |
White space again serves as a separator, and comments may begin with a
| 1478 |
pound sign (`#') and continue to the end of line.
| 1479 |
Here is the glyph entry for the letter \[lq]A\[rq] corresponding to
| 1480 |
Figure 2:
| 1481 |
.IP
| 1482 |
.nf
| 1483 |
\f[C]
| 1484 |
65 15 # Helvetica \[dq]A\[dq]
| 1485 |
155 222 242 48 185 48 168 86
| 1486 |
83 86 65 48 12 48 101 222
| 1487 |
155 222 128 179 126 179 97 116
| 1488 |
155 116 128 179 155 222
| 1489 |
\f[]
| 1490 |
.fi
| 1491 |
.LP
| 1492 |
If the number of vertices given is zero, then the character is a space.
| 1493 |
This is not the same as no entry, which means there is no valid glyph
| 1494 |
for that character.
| 1495 |
Glyphs may appear in any order, with indices ranging from 0 to 255.
| 1496 |
The maximum number of vertices for a single glyph is 32767.
| 1497 |
.PP
| 1498 |
Two standard font files are provided, \f[C]helvet.fnt\f[R] and
| 1499 |
\f[C]hexbit4x1.fnt\f[R].
| 1500 |
The former is a Helvetica font from the public domain Hershey font set.
| 1501 |
The second is a simple bit pattern font for hexadecimal encodings of
| 1502 |
bitmaps.
| 1503 |
.SH 3
| 1504 |
| 1505 |
| 1506 |
.pdfhref M "radiance-programs-3"
| 1507 |
.LP
| 1508 |
Table 4 shows \f[I]Radiance\f[R] programs that read and write font
| 1509 |
files.
| 1510 |
.PP
| 1511 |
.na
| 1512 |
.TS
| 1513 |
delim(@@) tab( );
| 1514 |
l l l l.
| 1515 |
T{
| 1516 |
Program
| 1517 |
T} T{
| 1518 |
Read
| 1519 |
T} T{
| 1520 |
Write
| 1521 |
T} T{
| 1522 |
Function
| 1523 |
T}
| 1524 |
_
| 1525 |
T{
| 1526 |
\f[B]pcompos\f[R]
| 1527 |
T} T{
| 1528 |
X
| 1529 |
T} T{
| 1530 |
T} T{
| 1531 |
Compose \f[I]Radiance\f[R] pictures
| 1532 |
T}
| 1533 |
T{
| 1534 |
\f[B]psign\f[R]
| 1535 |
T} T{
| 1536 |
X
| 1537 |
T} T{
| 1538 |
T} T{
| 1539 |
Generate \f[I]Radiance\f[R] picture label
| 1540 |
T}
| 1541 |
T{
| 1542 |
\f[B]rpict\f[R]
| 1543 |
T} T{
| 1544 |
X
| 1545 |
T} T{
| 1546 |
T} T{
| 1547 |
| 1548 |
T}
| 1549 |
T{
| 1550 |
\f[B]rtrace\f[R]
| 1551 |
T} T{
| 1552 |
X
| 1553 |
T} T{
| 1554 |
T} T{
| 1555 |
| 1556 |
T}
| 1557 |
T{
| 1558 |
\f[B]rview\f[R]
| 1559 |
T} T{
| 1560 |
X
| 1561 |
T} T{
| 1562 |
T} T{
| 1563 |
| 1564 |
T}
| 1565 |
.TE
| 1566 |
.ad
| 1567 |
.LP
| 1568 |
\f[B]Table 4.\f[R] Programs in the \f[I]Radiance\f[R] distribution that
| 1569 |
read and write font files.
| 1570 |
.SH 3
| 1571 |
| 1572 |
| 1573 |
.pdfhref M "radiance-c-library-3"
| 1574 |
.LP
| 1575 |
Similar to data files, font files are usually read and stored in a
| 1576 |
lookup table.
| 1577 |
The data structures for fonts are in src/common/font.h, and the routines
| 1578 |
for reading and spacing them are in \f[C]src/common/font.c\f[R].
| 1579 |
The main structure type is \f[C]FONT\f[R].
| 1580 |
The routine \f[C]getfont(fname)\f[R] loads a font file from the
| 1581 |
\f[I]Radiance\f[R] library (set by the \f[C]RAYPATH\f[R] environment
| 1582 |
variable), and returns a pointer to the resulting \f[C]FONT\f[R]
| 1583 |
structure.
| 1584 |
If the file has been previously loaded, a pointer to the stored
| 1585 |
structure is returned.
| 1586 |
The \f[C]freefont(fname)\f[R] routine frees memory associated with the
| 1587 |
named font file and deletes it from the table, or frees all font data if
| 1588 |
\f[C]fname\f[R] is \f[C]NULL\f[R].
| 1589 |
.PP
| 1590 |
Three different routines are available for text spacing.
| 1591 |
The \f[C]uniftext(sp,tp,f\f[R]) function takes the nul-terminated string
| 1592 |
\f[C]tp\f[R] and computes uniform per-character spacing for the font
| 1593 |
\f[C]f\f[R], returned in the short integer array \f[C]sp\f[R].
| 1594 |
(This is a fairly simple process, and all spacing values will be 255
| 1595 |
unless a character has no corresponding glyph.)
| 1596 |
The \f[C]squeeztext(sp,tp,f,cis)\f[R] performs a similar function, but
| 1597 |
puts only \f[C]ci\f[R]s units between adjacent characters, based on the
| 1598 |
actual width of each font glyph.
| 1599 |
The most sophisticated spacing function is
| 1600 |
\f[C]proptext(sp,tp,f,cis,nsi)\f[R], which produces a total line length
| 1601 |
equal to what it would be with uniform spacing, while maintaining equal
| 1602 |
inter-character spacing throughout (i.e., proportional spacing).
| 1603 |
The \f[C]nsi\f[R] argument is the number of spaces (zero-vertex glyphs)
| 1604 |
considered as an indent.
| 1605 |
That is, if this many or more adjacent spaces occur in \f[C]tp\f[R], the
| 1606 |
indented text following will appear at the same point as it would have
| 1607 |
had the spacing been uniform.
| 1608 |
This maintains columns in tabulated text despite the proportional
| 1609 |
spacing.
| 1610 |
Tabs are not understood or interpreted by any of these routines, and
| 1611 |
must be expanded to the appropriate number of spaces via
| 1612 |
\f[B]expand\f[R].
| 1613 |
.SH 3
| 1614 |
Octree Format (.oct suffix)
| 1615 |
.pdfhref O 3 "Octree Format \(.oct suffix\)"
| 1616 |
.pdfhref M "octree-format-.oct-suffix"
| 1617 |
.LP
| 1618 |
In \f[I]Radiance\f[R], octrees are used to accelerate ray intersection
| 1619 |
calculations as described by Glassner [Glassner84].
| 1620 |
This data structure is computed by the \f[B]oconv\f[R] program, which
| 1621 |
produces a binary file as its output.
| 1622 |
An octree file contains a list of \f[I]Radiance\f[R] scene description
| 1623 |
files (which may be empty), some information to guarantee portability
| 1624 |
between systems and different versions of the code, followed by the
| 1625 |
octree data itself.
| 1626 |
If the octree file is \[lq]frozen,\[rq] then it will also contain the
| 1627 |
scene data, compiled into a binary format for quick loading.
| 1628 |
This is most convenient for octrees that are used in \f[I]instance\f[R]
| 1629 |
primitives, which may be moved to a different (library) location from
| 1630 |
the originating scene files.
| 1631 |
.PP
| 1632 |
An octree recursively subdivides 3-dimensional space into 8 subtrees,
| 1633 |
hence its name.
| 1634 |
Each \[lq]leaf\[rq] node contains between zero and \f[C]MAXSET\f[R]
| 1635 |
surface primitives, indicating that section of space contains part or
| 1636 |
all of those surfaces.
| 1637 |
(Surface primitives may appear more than once in the octree.)
| 1638 |
The goal of \f[B]oconv\f[R] is to build an octree that contains no more
| 1639 |
than N surfaces in each leaf node, where N is set by the \f[B]-n\f[R]
| 1640 |
option (5 by default).
| 1641 |
It may allow more surfaces in places where the octree has reached its
| 1642 |
maximum resolution (depth), set by the \f[B]-r\f[R] option (1024 \[em]
| 1643 |
depth 10 by default).
| 1644 |
Figure 3 shows a quadtree dividing 2-dimensional space, analogous to our
| 1645 |
3-dimensional octree.
| 1646 |
.PSPIC "figure3.eps"
| 1647 |
.ce 1000
| 1648 |
A quadtree dividing two-dimensional space
| 1649 |
.ce 0
| 1650 |
.PP
| 1651 |
\f[B]Figure 3.\f[R] An example quadtree divided so that no leaf node
| 1652 |
contains more than 2 objects.
| 1653 |
A three-dimensional octree works the same way.
| 1654 |
Each leaf node is either empty, or contains a list of intersecting
| 1655 |
surfaces.
| 1656 |
.SH 3
| 1657 |
| 1658 |
| 1659 |
.pdfhref M "basic-file-structure-1"
| 1660 |
.LP
| 1661 |
An octree file is divided into five sections: the information header,
| 1662 |
the scene boundaries, the scene file names, the octree data structure,
| 1663 |
and the compiled scene data.
| 1664 |
If the octree is frozen, then the compiled scene data is included and
| 1665 |
the scene file names are not.
| 1666 |
Otherwise, the scene data is left off.
| 1667 |
.SH 4
| 1668 |
Information Header
| 1669 |
.pdfhref O 4 "Information Header"
| 1670 |
.pdfhref M "information-header"
| 1671 |
.LP
| 1672 |
As with other binary \f[I]Radiance\f[R] formats, the beginning of an
| 1673 |
octree file is the information header.
| 1674 |
The first line is \[lq]#?RADIANCE\[rq] to aid in identification by the
| 1675 |
UNIX \f[B]file\f[R] program.
| 1676 |
Following this is the \f[B]oconv\f[R] command (or commands) used to
| 1677 |
produce the octree, then a line indicating the format,
| 1678 |
\f[C]FORMAT=Radiance_octree\f[R].
| 1679 |
The end of the information header is always an empty line.
| 1680 |
Here is an example of an octree information header, as reported by
| 1681 |
\f[B]getinfo\f[R]:
| 1682 |
.IP
| 1683 |
.nf
| 1684 |
\f[C]
| 1685 |
#?RADIANCE
| 1686 |
oconv model.b90 desk misc
| 1687 |
oconv -f -i modelb.oct window blinds lights lamp
| 1688 |
| 1689 |
\f[]
| 1690 |
.fi
| 1691 |
.LP
| 1692 |
The actual content of this header is ignored when an octree is read
| 1693 |
except for the \f[C]FORMAT\f[R] line, which if it appears must match the
| 1694 |
one shown above.
| 1695 |
.SH 4
| 1696 |
Scene Boundaries
| 1697 |
.pdfhref O 4 "Scene Boundaries"
| 1698 |
.pdfhref M "scene-boundaries"
| 1699 |
.LP
| 1700 |
After the information header, there is a magic number indicating the
| 1701 |
format version and the size of object indices (in bytes per index).
| 1702 |
This is a two-byte quantity, which must be one of the following in the
| 1703 |
current release:
| 1704 |
.PP
| 1705 |
.na
| 1706 |
.nr LLold \n[LL]
| 1707 |
.TS
| 1708 |
delim(@@) tab( );
| 1709 |
lw(35.0n) lw(35.0n).
| 1710 |
T{
| 1711 |
.nr LL 35.0n
| 1712 |
285
| 1713 |
T} T{
| 1714 |
.nr LL 35.0n
| 1715 |
Two-byte object indices.
| 1716 |
T}
| 1717 |
T{
| 1718 |
.nr LL 35.0n
| 1719 |
287
| 1720 |
T} T{
| 1721 |
.nr LL 35.0n
| 1722 |
Four-byte object indices.
| 1723 |
T}
| 1724 |
T{
| 1725 |
.nr LL 35.0n
| 1726 |
291
| 1727 |
T} T{
| 1728 |
.nr LL 35.0n
| 1729 |
Eight-byte object indices.
| 1730 |
(Only supported on architectures with 64-bit \f[B]longs\f[R].)
| 1731 |
T}
| 1732 |
.TE
| 1733 |
.nr LL \n[LLold]
| 1734 |
.ad
| 1735 |
.LP
| 1736 |
Technically, the code will also support odd-sized integers, but they are
| 1737 |
not found on any existing machine architectures so we can forget about
| 1738 |
them.
| 1739 |
.PP
| 1740 |
Following the octree magic number, we have the enclosing cube for the
| 1741 |
scene, which defines the dimensions of the octree\[cq]s root node.
| 1742 |
The cube is aligned along the world coordinate axes, so may be defined
| 1743 |
by one corner (the 3-dimensional minimum) and the side length.
| 1744 |
For historical reasons, these four values are stored as ASCII-encoded
| 1745 |
real values in nul-terminated strings.
| 1746 |
(The octree boundaries may also be read using \f[B]getinfo\f[R] with the
| 1747 |
\f[B]-d\f[R] option.)
| 1748 |
.SH 4
| 1749 |
Scene File Names
| 1750 |
.pdfhref O 4 "Scene File Names"
| 1751 |
.pdfhref M "scene-file-names"
| 1752 |
.LP
| 1753 |
Following the octree dimensions, the names of the scene description
| 1754 |
files are given, each stored a nul-terminated string.
| 1755 |
The end of this file list is indicated by an empty string.
| 1756 |
If the octree is \[lq]frozen,\[rq] meaning it contains the compiled
| 1757 |
scene information as well, then no file names will be present (i.e., the
| 1758 |
first string will be empty).
| 1759 |
.SH 4
| 1760 |
Octree Data Structure
| 1761 |
.pdfhref O 4 "Octree Data Structure"
| 1762 |
.pdfhref M "octree-data-structure"
| 1763 |
.LP
| 1764 |
After the scene description files, an N-byte integer indicates the total
| 1765 |
number of primitives given to \f[B]oconv\f[R], where N is the size
| 1766 |
derived from the magic number as we described.
| 1767 |
This object count will be used to verify that the files have not changed
| 1768 |
significantly since the octree was written\**.
| 1769 |
.FS
| 1770 |
Small changes that do not affect geometry will not cause problems, but
| 1771 |
if the primitive count changes, so does the indexing of surfaces, and
| 1772 |
with that the octree data structure becomes invalid.
| 1773 |
A second check is made to insure that no non-surface primitives appear
| 1774 |
in any leaf nodes, and this at least guarantees that the renderer will
| 1775 |
not dump core from an outdated octree, even if the results are wrong.
| 1776 |
.FE
| 1777 |
.PP
| 1778 |
After the primitive count, the actual octree is stored, using the
| 1779 |
following recursive procedure:
| 1780 |
.IP
| 1781 |
.nf
| 1782 |
\f[C]
| 1783 |
puttree(ot) begin
| 1784 |
if ot is a tree then
| 1785 |
write the character \[aq]\[rs]002\[aq]
| 1786 |
call puttree on each child node (0-7) else if ot is empty then
| 1787 |
write the character \[aq]\[rs]000\[aq]
| 1788 |
else
| 1789 |
write the character \[aq]\[rs]001\[aq]
| 1790 |
write out the number of surfaces
| 1791 |
write out each surface\[aq]s index
| 1792 |
end
| 1793 |
end puttree
| 1794 |
\f[]
| 1795 |
.fi
| 1796 |
.LP
| 1797 |
The number of surfaces and the surface indices are each N-byte integers,
| 1798 |
and the tree node types are single bytes.
| 1799 |
Reading the octree is accomplished with a complementary procedure.
| 1800 |
.SH 4
| 1801 |
Compiled Scene Data
| 1802 |
.pdfhref O 4 "Compiled Scene Data"
| 1803 |
.pdfhref M "compiled-scene-data"
| 1804 |
.LP
| 1805 |
If the octree is frozen, then this data structure is followed by a
| 1806 |
compiled version of the scene.
| 1807 |
This avoids the problems of changes to scene files, and allows an octree
| 1808 |
to be moved conveniently from one location and one system to another
| 1809 |
without worrying about the associated scene files.
| 1810 |
.PP
| 1811 |
The scene data begins with a listing of the defined primitive types.
| 1812 |
This list consists of the name of each type as a nul-terminated string,
| 1813 |
followed by an empty string once the list has been exhausted.
| 1814 |
This permits the indexing of primitive types with a single byte later
| 1815 |
on, without concern about changes to \f[I]Radiance\f[R] involving
| 1816 |
\f[C]src/common/otypes.h\f[R].
| 1817 |
.PP
| 1818 |
The scene primitives are written one at a time.
| 1819 |
First is a single byte with the primitive type index, as determined from
| 1820 |
the list given above.
| 1821 |
Second is the N-byte modifier index, followed by the primitive\[cq]s
| 1822 |
identifier as a nul-terminated string.
| 1823 |
String arguments start with a 2-byte integer indicating the argument
| 1824 |
count, followed by the strings themselves, which are nul-terminated.
| 1825 |
Real arguments next have a 2-byte count followed by the real values,
| 1826 |
each stored as a 4-byte mantissa followed by a 1-byte (signed) exponent.
| 1827 |
(The mantissa is the numerator of a fraction of @2 sup 31 \[u2212] 1@.)
| 1828 |
The end of data is indicated with a -1 value for the object type
| 1829 |
(byte=255).
| 1830 |
.SH 3
| 1831 |
| 1832 |
| 1833 |
.pdfhref M "radiance-programs-4"
| 1834 |
.LP
| 1835 |
Table 5 shows \f[I]Radiance\f[R] programs that read and write octree
| 1836 |
files.
| 1837 |
.PP
| 1838 |
.na
| 1839 |
.TS
| 1840 |
delim(@@) tab( );
| 1841 |
l l l l.
| 1842 |
T{
| 1843 |
Program
| 1844 |
T} T{
| 1845 |
Read
| 1846 |
T} T{
| 1847 |
Write
| 1848 |
T} T{
| 1849 |
Function
| 1850 |
T}
| 1851 |
_
| 1852 |
T{
| 1853 |
\f[B]getinfo\f[R]
| 1854 |
T} T{
| 1855 |
X
| 1856 |
T} T{
| 1857 |
T} T{
| 1858 |
Print information header from binary file
| 1859 |
T}
| 1860 |
T{
| 1861 |
\f[B]oconv\f[R]
| 1862 |
T} T{
| 1863 |
X
| 1864 |
T} T{
| 1865 |
X
| 1866 |
T} T{
| 1867 |
| 1868 |
T}
| 1869 |
T{
| 1870 |
\f[B]rad\f[R]
| 1871 |
T} T{
| 1872 |
X
| 1873 |
T} T{
| 1874 |
X
| 1875 |
T} T{
| 1876 |
| 1877 |
T}
| 1878 |
T{
| 1879 |
\f[B]rpict\f[R]
| 1880 |
T} T{
| 1881 |
X
| 1882 |
T} T{
| 1883 |
T} T{
| 1884 |
| 1885 |
T}
| 1886 |
T{
| 1887 |
\f[B]rpiece\f[R]
| 1888 |
T} T{
| 1889 |
X
| 1890 |
T} T{
| 1891 |
T} T{
| 1892 |
Parallel batch rendering program
| 1893 |
T}
| 1894 |
T{
| 1895 |
\f[B]rtrace\f[R]
| 1896 |
T} T{
| 1897 |
X
| 1898 |
T} T{
| 1899 |
T} T{
| 1900 |
| 1901 |
T}
| 1902 |
T{
| 1903 |
\f[B]rview\f[R]
| 1904 |
T} T{
| 1905 |
X
| 1906 |
T} T{
| 1907 |
T} T{
| 1908 |
| 1909 |
T}
| 1910 |
.TE
| 1911 |
.ad
| 1912 |
.LP
| 1913 |
\f[B]Table 5.\f[R] Programs in the \f[I]Radiance\f[R] distribution that
| 1914 |
read and write octree files.
| 1915 |
.SH 3
| 1916 |
| 1917 |
| 1918 |
.pdfhref M "radiance-c-library-4"
| 1919 |
.LP
| 1920 |
Since reading an octree file also may involve reading a
| 1921 |
\f[I]Radiance\f[R] scene description, some of the same library routines
| 1922 |
are called indirectly.
| 1923 |
The header file \f[C]src/common/octree.h\f[R] is needed in addition to
| 1924 |
the \f[C]src/common/object.\f[R]h file.
| 1925 |
The module \f[C]src/ot/writeoct.c\f[R] contains the main routines for
| 1926 |
writing an octree to stdout, while \f[C]src/common/readoct.c\f[R]
| 1927 |
contains the corresponding routines for reading an octree from a file.
| 1928 |
Both modules access routines in \f[C]src/common/portio.c\f[R] for
| 1929 |
reading and writing portable binary data.
| 1930 |
.PP
| 1931 |
Here is the main call for writing out an octree:
| 1932 |
.IP "\f[B]\f[CB]writeoct(int store, CUBE *scene, char *ofn[]);\f[B]\f[R]" 3
| 1933 |
Write the octree stored in scene to stdout, assuming the header has
| 1934 |
already been written.
| 1935 |
The flags in store determine what will be included.
| 1936 |
Normally, this variable is one of \f[C]IO_ALL\f[R] or
| 1937 |
\f[C](IO_ALL & \[ti]IO_FILES)\f[R] correspondingto writing a normal or a
| 1938 |
frozen octree, respectively.
| 1939 |
.RS 3
| 1940 |
.RE
| 1941 |
.LP
| 1942 |
Here is the main call for reading in an octree:
| 1943 |
.IP "\f[B]\f[CB]readoct(char *fname, int load, CUBE *scene, char *ofn[]);\f[B]\f[R]" 3
| 1944 |
Read the octree file fname into scene, saving scene file names in the
| 1945 |
ofn array.
| 1946 |
What is loaded depends on the flags in load,which may be one or more of
| 1947 |
\f[C]IO_CHECK\f[R], \f[C]IO_INFO\f[R], \f[C]IO_SCENE\f[R],
| 1948 |
\f[C]IO_TREE\f[R], \f[C]IO_FILES\f[R] and \f[C]IO_BOUNDS\f[R].
| 1949 |
These correspond to checking file type and consistency, transferring the
| 1950 |
information header to stdout, loading the scene data, loading the octree
| 1951 |
structure, assigning the scene file names to ofn, and assigning the
| 1952 |
octree cube boundaries.
| 1953 |
The macro \f[C]IO_ALL\f[R] includes all of these flags, for convenience.
| 1954 |
.RS 3
| 1955 |
.RE
| 1956 |
.SH 2
| 1957 |
Picture File Format (.hdr suffix)
| 1958 |
.pdfhref O 2 "Picture File Format \(.hdr suffix\)"
| 1959 |
.pdfhref M "picture-file-format-.hdr-suffix"
| 1960 |
.LP
| 1961 |
\f[I]Radiance\f[R] pictures\**
| 1962 |
.FS
| 1963 |
The picture filename extension used to be .pic, but that conflicted with
| 1964 |
too many other programs.
| 1965 |
It was replaced with .hdr, an abbreviation of \[lq]high dynamic
| 1966 |
range.\[rq]
| 1967 |
.FE
| 1968 |
differ from standard computer graphics images inasmuch as they contain
| 1969 |
real physical data, namely radiance values at each pixel.
| 1970 |
To do this, it is necessary to maintain floating point information, and
| 1971 |
we use a 4-byte/pixel encoding described in Chapter II.5 of Graphics
| 1972 |
Gems II [Arvo91,p.80].
| 1973 |
The basic idea is to store a 1-byte mantissa for each of three
| 1974 |
primaries, and a common 1-byte exponent.
| 1975 |
The accuracy of these values will be on the order of 1% (±1 in 200) over
| 1976 |
a dynamic range from 10\*{-38\*} to 10\*{38\*}.
| 1977 |
.PP
| 1978 |
Although \f[I]Radiance\f[R] pictures \f[I]may\f[R] contain physical
| 1979 |
data, they do not \f[I]necessarily\f[R] contain physical data.
| 1980 |
If the rendering did not use properly modeled light sources, or the
| 1981 |
picture was converted from some other format, or custom filtering was
| 1982 |
applied, then the physical data will be invalid.
| 1983 |
Table 6 lists programs that read and write \f[I]Radiance\f[R] pictures,
| 1984 |
with pluses next to the X-marks indicating where physical data is
| 1985 |
preserved (or at least understood).
| 1986 |
Specifically, if the picture file read or written by a program has an
| 1987 |
\[lq]X+\[rq], then it has maintained the physical validity of the pixels
| 1988 |
by keeping track of any exposure or color corrections in the appropriate
| 1989 |
header variables, described below.
| 1990 |
.SH 3
| 1991 |
Basic File Structure
| 1992 |
.pdfhref O 3 "Basic File Structure"
| 1993 |
.pdfhref M "basic-file-structure-2"
| 1994 |
.LP
| 1995 |
\f[I]Radiance\f[R] picture files are divided into three sections: the
| 1996 |
information header, the resolution string, and the scanline records.
| 1997 |
All of these must be present or the file is incomplete.
| 1998 |
.SH 4
| 1999 |
Information Header
| 2000 |
| 2001 |
.pdfhref M "information-header-1"
| 2002 |
.LP
| 2003 |
The information header begins with the usual \f[C]#?RADIANCE\f[R]
| 2004 |
identifier, followed by one or more lines containing the programs used
| 2005 |
to produce the picture.
| 2006 |
These commands may be interspersed with variables describing relevant
| 2007 |
information such as the view, exposure, color correction, and so on.
| 2008 |
Variable assignments begin on a new line, and the variable name (usually
| 2009 |
all upper case) is followed by an equals sign (`='), which is followed
| 2010 |
by the assigned value up until the end of line.
| 2011 |
Some variable assignments override previous assignments in the same
| 2012 |
header, where other assignments are cumulative.
| 2013 |
Here are the most important variables for \f[I]Radiance\f[R] pictures:
| 2014 |
.IP "\f[B]\f[CB]FORMAT\f[B]\f[R]" 3
| 2015 |
A line indicating the file\[cq]s format.
| 2016 |
At most one \f[C]FORMAT\f[R] line is allowed, and it must be assigned a
| 2017 |
value of either \f[C]32- bit_rle_rgbe\f[R] or \f[C]32-bit_rle_xyze\f[R]
| 2018 |
to be a valid \f[I]Radiance\f[R] picture.
| 2019 |
.RS 3
| 2020 |
.RE
| 2021 |
.IP "\f[B]\f[CB]EXPOSURE\f[B]\f[R]" 3
| 2022 |
A single floating point number indicating a multiplier that has been
| 2023 |
applied to all the pixels in the file.
| 2024 |
\f[C]EXPOSURE\f[R] values are cumulative, so the original pixel values
| 2025 |
(i.e., radiances in w/sr/m\*{2\*}) must be derived by taking the values
| 2026 |
in the file and dividing by all the \f[C]EXPOSURE\f[R] settings
| 2027 |
multiplied together.
| 2028 |
No \f[C]EXPOSURE\f[R] setting implies that no exposure changes have
| 2029 |
taken place.
| 2030 |
.RS 3
| 2031 |
.RE
| 2032 |
.IP "\f[B]\f[CB]COLORCORR\f[B]\f[R]" 3
| 2033 |
A color correction multiplier that has been applied to this picture.
| 2034 |
Similar to the \f[C]EXPOSURE\f[R] variable except given in three parts
| 2035 |
for the three primaries.
| 2036 |
In general, the value should have a brightness of unity, so that it does
| 2037 |
not affect the actual brightness of pixels, which should be tracked by
| 2038 |
\f[C]EXPOSURE\f[R] changes instead.
| 2039 |
(This variable is also cumulative.)
| 2040 |
.RS 3
| 2041 |
.RE
| 2042 |
.IP "\f[B]\f[CB]SOFTWARE\f[B]\f[R]" 3
| 2043 |
The software version used to create the picture, usually something like
| 2044 |
\f[C]RADIANCE 3.04 official release July 16, 1996\f[R].
| 2045 |
.RS 3
| 2046 |
.RE
| 2047 |
.IP "\f[B]\f[CB]PIXASPECT\f[B]\f[R]" 3
| 2048 |
The pixel aspect ratio, expressed as a decimal fraction of the height of
| 2049 |
each pixel to its width.
| 2050 |
This is not to be confused with the image aspect ratio, which is the
| 2051 |
total height over width.
| 2052 |
(The image aspect ratio is actually equal to the height in pixels over
| 2053 |
the width in pixels, \f[I]multiplied\f[R] by the pixel aspect ratio.)
| 2054 |
These assignments are cumulative, so the actual pixel aspect ratio is
| 2055 |
all ratios multiplied together.
| 2056 |
If no \f[C]PIXASPECT\f[R] assignment appears, the ratio is assumed to be
| 2057 |
1.
| 2058 |
.RS 3
| 2059 |
.RE
| 2060 |
.IP "\f[B]\f[CB]VIEW\f[B]\f[R]" 3
| 2061 |
The \f[I]Radiance\f[R] view parameters used to create this picture.
| 2062 |
Multiple assignments are cumulative inasmuch as new view options add to
| 2063 |
or override old ones.
| 2064 |
.RS 3
| 2065 |
.RE
| 2066 |
.LP
| 2067 |
\f[C]PRIMARIES\f[R] The CIE (x,y) chromaticity coordinates of the three
| 2068 |
(RGB) primaries and the white point used to standardize the
| 2069 |
picture\[cq]s color system.
| 2070 |
This is used mainly by the \f[B]ra_xyze\f[R] program to convert between
| 2071 |
color systems.
| 2072 |
If no \f[C]PRIMARIES\f[R] line appears, we assume the standard primaries
| 2073 |
defined in \f[C]src/common/color.h\f[R], namely
| 2074 |
\f[C]0.640 0.330 0.290 0.600 0.150 0.060 0.333 0.333\f[R] for red,
| 2075 |
green, blue and white, respectively.
| 2076 |
.PP
| 2077 |
As always, the end of the header is indicated by an empty line.
| 2078 |
.SH 4
| 2079 |
Resolution String
| 2080 |
.pdfhref O 4 "Resolution String"
| 2081 |
.pdfhref M "resolution-string"
| 2082 |
.LP
| 2083 |
All \f[I]Radiance\f[R] pictures have a standard coordinate system, which
| 2084 |
is shown in Figure 4.
| 2085 |
The origin is always at the lower left corner, with the X coordinate
| 2086 |
increasing to the right, and the Y coordinate increasing in the upward
| 2087 |
direction.
| 2088 |
The actual ordering of pixels in the picture file, however, is addressed
| 2089 |
by the resolution string.
| 2090 |
.PSPIC "figure4.eps"
| 2091 |
.ce 1000
| 2092 |
Radiance picture coordinate system
| 2093 |
.ce 0
| 2094 |
.PP
| 2095 |
\f[B]Figure 4.\f[R] The standard coordinate system for an MxN picture.
| 2096 |
.PP
| 2097 |
The resolution string is given as one of the following:
| 2098 |
.IP "\f[B]\f[CB]-Y N +X M\f[B]\f[R]" 3
| 2099 |
The standard orientation produced by the renderers, indicating that Y is
| 2100 |
decreasing in the file, and X is increasing.
| 2101 |
X positions are increasing in each scanline, starting with the upper
| 2102 |
left position in the picture and moving to the upper right initially,
| 2103 |
then on down the picture.
| 2104 |
Some programs will only handle pictures with this ordering.
| 2105 |
.RS 3
| 2106 |
.RE
| 2107 |
.IP "\f[B]\f[CB]-Y N -X M\f[B]\f[R]" 3
| 2108 |
The X ordering has been reversed, effectively flipping the image left to
| 2109 |
right from the standard ordering.
| 2110 |
.RS 3
| 2111 |
.RE
| 2112 |
.IP "\f[B]\f[CB]+Y N -X M\f[B]\f[R]" 3
| 2113 |
The image has been flipped left to right and also top to bottom, which
| 2114 |
is the same as rotating it by 180 degrees.
| 2115 |
.RS 3
| 2116 |
.RE
| 2117 |
.IP "\f[B]\f[CB]+Y N +X M\f[B]\f[R]" 3
| 2118 |
The image has been flipped top to bottom from the standard ordering.
| 2119 |
.RS 3
| 2120 |
.RE
| 2121 |
.IP "\f[B]\f[CB]+X M +Y N\f[B]\f[R]" 3
| 2122 |
The image has been rotated 90 degrees clockwise.
| 2123 |
.RS 3
| 2124 |
.RE
| 2125 |
.IP "\f[B]\f[CB]-X M +Y N\f[B]\f[R]" 3
| 2126 |
The image has been rotated 90 degrees clockwise, then flipped top to
| 2127 |
bottom.
| 2128 |
.RS 3
| 2129 |
.RE
| 2130 |
.IP "\f[B]\f[CB]-X M -Y N\f[B]\f[R]" 3
| 2131 |
The image has been rotated 90 degrees counter-clockwise.
| 2132 |
.RS 3
| 2133 |
.RE
| 2134 |
.IP "\f[B]\f[CB]+X M -Y N\f[B]\f[R]" 3
| 2135 |
The image has been rotate 90 degrees counter-clockwise, then flipped top
| 2136 |
to bottom.
| 2137 |
.RS 3
| 2138 |
.RE
| 2139 |
.LP
| 2140 |
The reason for tracking all these changes in picture orientation is so
| 2141 |
programs that compute ray origin and direction from the \f[C]VIEW\f[R]
| 2142 |
variable in the information header will work despite such changes.
| 2143 |
Also, it can reduce memory requirements on converting from other image
| 2144 |
formats that have a different scanline ordering, such as Targa.
| 2145 |
.SH 4
| 2146 |
Scanline Records
| 2147 |
.pdfhref O 4 "Scanline Records"
| 2148 |
.pdfhref M "scanline-records"
| 2149 |
.LP
| 2150 |
\f[I]Radiance\f[R] scanlines come in one of three flavors, described
| 2151 |
below:
| 2152 |
.IP "\f[B]Uncompressed\f[R]" 3
| 2153 |
Each scanline is represented by M pixels with 4 bytes per pixel, for a
| 2154 |
total length of 4xM bytes.
| 2155 |
This is the simplest format to read and write, since it has a one-to-one
| 2156 |
correspondence to an array of \f[C]COLR\f[R] values.
| 2157 |
.RS 3
| 2158 |
.RE
| 2159 |
.IP "\f[B]Old run-length encoded\f[R]" 3
| 2160 |
Repeated pixel values are indicated by an illegal (i.e., unnormalized)
| 2161 |
pixel that has 1\[cq]s for all three mantissas, and an exponent that
| 2162 |
corresponds to the number of times the previous pixel is repeated.
| 2163 |
Consecutive repeat indicators contain higher-order bytes of the count.
| 2164 |
.RS 3
| 2165 |
.RE
| 2166 |
.IP "\f[B]New run-length encoded\f[R]" 3
| 2167 |
In this format, the four scanline components (three primaries and
| 2168 |
exponent) are separated for better compression using adaptive run-length
| 2169 |
encoding (described by Glassner in Chapter II.8 of Graphics Gems II
| 2170 |
[Arvo91,p.89]).
| 2171 |
The record begins with an unnormalized pixel having two bytes equal to
| 2172 |
2, followed by the upper byte and the lower byte of the scanline length
| 2173 |
(which must be less than 32768).
| 2174 |
A run is indicated by a byte with its high-order bit set, corresponding
| 2175 |
to a count with excess 128.
| 2176 |
A non-run is indicated with a byte less than 128.
| 2177 |
The maximum compression ratio using this scheme is better than 100:1,
| 2178 |
but typical performance for \f[I]Radiance\f[R] pictures is more like
| 2179 |
2:1.
| 2180 |
.RS 3
| 2181 |
.RE
| 2182 |
.LP
| 2183 |
The physical values these scanlines correspond to depend on the format
| 2184 |
and other information contained in the information header.
| 2185 |
If the \f[C]FORMAT\f[R] string indicates RGB data, then the units for
| 2186 |
each primary are spectral radiances over the corresponding waveband,
| 2187 |
such that a pixel value of @left ( 1 , 1 , 1 right )@ corresponds to a
| 2188 |
total energy of 1 w/sr/m\*{2\*} over the visible spectrum.
| 2189 |
The actual luminance value (in lm/sr/m\*{2\*}) can be computed from the
| 2190 |
following formula for the standard \f[I]Radiance\f[R] RGB primaries:
| 2191 |
.PP
| 2192 |
.EQ
| 2193 |
L sub v = 179 left ( 0.265 r + 0.670 g + 0.065 b right )
| 2194 |
.EN
| 2195 |
.PP
| 2196 |
The value of 179 lm/w is the standard \f[I]luminous efficacy\f[R] of
| 2197 |
equal-energy white light that is defined and used by \f[I]Radiance\f[R]
| 2198 |
specifically for this conversion.
| 2199 |
This and the other values above are defined in
| 2200 |
\f[C]src/common/color.h\f[R], and the above formula is given as a macro,
| 2201 |
\f[C]luminance(col)\f[R].
| 2202 |
.PP
| 2203 |
If the \f[C]FORMAT\f[R] string indicates XYZ data, then the units of the
| 2204 |
Y primary are already lm/st/m\*{2\*}, so the above conversion is
| 2205 |
unnecessary.
| 2206 |
.SH 3
| 2207 |
\f[BI]Radiance\f[B] programs
| 2208 |
.pdfhref O 3 "Radiance programs"
| 2209 |
.pdfhref M "radiance-programs-5"
| 2210 |
.LP
| 2211 |
Table 6 shows the many programs that read and write \f[I]Radiance\f[R]
| 2212 |
pictures.
| 2213 |
.PP
| 2214 |
.na
| 2215 |
.TS
| 2216 |
delim(@@) tab( );
| 2217 |
l l l l.
| 2218 |
T{
| 2219 |
Program
| 2220 |
T} T{
| 2221 |
Read
| 2222 |
T} T{
| 2223 |
Write
| 2224 |
T} T{
| 2225 |
Function
| 2226 |
T}
| 2227 |
_
| 2228 |
T{
| 2229 |
\f[B]falsecolor\f[R]
| 2230 |
T} T{
| 2231 |
X+
| 2232 |
T} T{
| 2233 |
X
| 2234 |
T} T{
| 2235 |
Create false color image
| 2236 |
T}
| 2237 |
T{
| 2238 |
\f[B]findglare\f[R]
| 2239 |
T} T{
| 2240 |
X+
| 2241 |
T} T{
| 2242 |
T} T{
| 2243 |
Find sources of discomfort glare
| 2244 |
T}
| 2245 |
T{
| 2246 |
\f[B]getinfo\f[R]
| 2247 |
T} T{
| 2248 |
X
| 2249 |
T} T{
| 2250 |
T} T{
| 2251 |
| 2252 |
T}
| 2253 |
T{
| 2254 |
| 2255 |
T} T{
| 2256 |
X
| 2257 |
T} T{
| 2258 |
X
| 2259 |
T} T{
| 2260 |
| 2261 |
T}
| 2262 |
T{
| 2263 |
\f[B]normpat\f[R]
| 2264 |
T} T{
| 2265 |
X
| 2266 |
T} T{
| 2267 |
X
| 2268 |
T} T{
| 2269 |
Normalize picture for use as pattern tile
| 2270 |
T}
| 2271 |
T{
| 2272 |
\f[B]objpict\f[R]
| 2273 |
T} T{
| 2274 |
T} T{
| 2275 |
X
| 2276 |
T} T{
| 2277 |
Generate composite picture of object
| 2278 |
T}
| 2279 |
T{
| 2280 |
\f[B]pcomb\f[R]
| 2281 |
T} T{
| 2282 |
X+
| 2283 |
T} T{
| 2284 |
X
| 2285 |
T} T{
| 2286 |
| 2287 |
T}
| 2288 |
T{
| 2289 |
\f[B]pcond\f[R]
| 2290 |
T} T{
| 2291 |
X+
| 2292 |
T} T{
| 2293 |
X
| 2294 |
T} T{
| 2295 |
Condition a picture for display
| 2296 |
T}
| 2297 |
T{
| 2298 |
\f[B]pcompos\f[R]
| 2299 |
T} T{
| 2300 |
X
| 2301 |
T} T{
| 2302 |
X
| 2303 |
T} T{
| 2304 |
Composite pictures
| 2305 |
T}
| 2306 |
T{
| 2307 |
\f[B]pextrem\f[R]
| 2308 |
T} T{
| 2309 |
X+
| 2310 |
T} T{
| 2311 |
T} T{
| 2312 |
Find minimum and maximum pixels
| 2313 |
T}
| 2314 |
T{
| 2315 |
\f[B]pfilt\f[R]
| 2316 |
T} T{
| 2317 |
X+
| 2318 |
T} T{
| 2319 |
X+
| 2320 |
T} T{
| 2321 |
Filter and anti-alias picture
| 2322 |
T}
| 2323 |
T{
| 2324 |
\f[B]pflip\f[R]
| 2325 |
T} T{
| 2326 |
X+
| 2327 |
T} T{
| 2328 |
X+
| 2329 |
T} T{
| 2330 |
Flip picture left-right and/or top-bottom
| 2331 |
T}
| 2332 |
T{
| 2333 |
\f[B]pinterp\f[R]
| 2334 |
T} T{
| 2335 |
X+
| 2336 |
T} T{
| 2337 |
X+
| 2338 |
T} T{
| 2339 |
Interpolate/extrapolate picture views
| 2340 |
T}
| 2341 |
T{
| 2342 |
\f[B]protate\f[R]
| 2343 |
T} T{
| 2344 |
X+
| 2345 |
T} T{
| 2346 |
X+
| 2347 |
T} T{
| 2348 |
Rotate picture 90 degrees clockwise
| 2349 |
T}
| 2350 |
T{
| 2351 |
\f[B]psign\f[R]
| 2352 |
T} T{
| 2353 |
T} T{
| 2354 |
X
| 2355 |
T} T{
| 2356 |
Create text picture
| 2357 |
T}
| 2358 |
T{
| 2359 |
\f[B]pvalue\f[R]
| 2360 |
T} T{
| 2361 |
X+
| 2362 |
T} T{
| 2363 |
X+
| 2364 |
T} T{
| 2365 |
Convert picture to/from simpler formats
| 2366 |
T}
| 2367 |
T{
| 2368 |
\f[B]ra_avs\f[R]
| 2369 |
T} T{
| 2370 |
X
| 2371 |
T} T{
| 2372 |
X
| 2373 |
T} T{
| 2374 |
Convert to/from AVS image format
| 2375 |
T}
| 2376 |
T{
| 2377 |
\f[B]ra_pict\f[R]
| 2378 |
T} T{
| 2379 |
X
| 2380 |
T} T{
| 2381 |
X
| 2382 |
T} T{
| 2383 |
Convert to/from Macintosh PICT2 format
| 2384 |
T}
| 2385 |
T{
| 2386 |
\f[B]ra_ppm\f[R]
| 2387 |
T} T{
| 2388 |
X
| 2389 |
T} T{
| 2390 |
X
| 2391 |
T} T{
| 2392 |
Convert to/from Poskanzer Port.
| 2393 |
Pixmap
| 2394 |
T}
| 2395 |
T{
| 2396 |
\f[B]ra_pr\f[R]
| 2397 |
T} T{
| 2398 |
X
| 2399 |
T} T{
| 2400 |
X
| 2401 |
T} T{
| 2402 |
Convert to/from Sun 8-bit rasterfile
| 2403 |
T}
| 2404 |
T{
| 2405 |
\f[B]ra_pr24\f[R]
| 2406 |
T} T{
| 2407 |
X
| 2408 |
T} T{
| 2409 |
X
| 2410 |
T} T{
| 2411 |
Convert to/from Sun 24-bit rasterfile
| 2412 |
T}
| 2413 |
T{
| 2414 |
\f[B]ra_ps\f[R]
| 2415 |
T} T{
| 2416 |
X
| 2417 |
T} T{
| 2418 |
T} T{
| 2419 |
Convert to B&W or color PostScript
| 2420 |
T}
| 2421 |
T{
| 2422 |
\f[B]ra_rgbe\f[R]
| 2423 |
T} T{
| 2424 |
X
| 2425 |
T} T{
| 2426 |
X
| 2427 |
T} T{
| 2428 |
Convert to/from uncompressed picture
| 2429 |
T}
| 2430 |
T{
| 2431 |
\f[B]ra_t8\f[R]
| 2432 |
T} T{
| 2433 |
X
| 2434 |
T} T{
| 2435 |
X
| 2436 |
T} T{
| 2437 |
Convert to/from Targa 8-bit format
| 2438 |
T}
| 2439 |
T{
| 2440 |
\f[B]ra_t16\f[R]
| 2441 |
T} T{
| 2442 |
X
| 2443 |
T} T{
| 2444 |
X
| 2445 |
T} T{
| 2446 |
Convert to/from Targa 16-bit and 24-bit
| 2447 |
T}
| 2448 |
T{
| 2449 |
\f[B]ra_tiff\f[R]
| 2450 |
T} T{
| 2451 |
X
| 2452 |
T} T{
| 2453 |
X
| 2454 |
T} T{
| 2455 |
Convert to/from TIFF 8-bit and 24-bit
| 2456 |
T}
| 2457 |
T{
| 2458 |
\f[B]ra_xyze\f[R]
| 2459 |
T} T{
| 2460 |
X
| 2461 |
T} T{
| 2462 |
X
| 2463 |
T} T{
| 2464 |
Convert to/from CIE primary picture
| 2465 |
T}
| 2466 |
T{
| 2467 |
\f[B]rad\f[R]
| 2468 |
T} T{
| 2469 |
T} T{
| 2470 |
X+
| 2471 |
T} T{
| 2472 |
Render Radiance scene
| 2473 |
T}
| 2474 |
T{
| 2475 |
\f[B]ranimate\f[R]
| 2476 |
T} T{
| 2477 |
T} T{
| 2478 |
X+
| 2479 |
T} T{
| 2480 |
Animate Radiance scene
| 2481 |
T}
| 2482 |
T{
| 2483 |
\f[B]rpict\f[R]
| 2484 |
T} T{
| 2485 |
X
| 2486 |
T} T{
| 2487 |
X+
| 2488 |
T} T{
| 2489 |
Batch rendering program
| 2490 |
T}
| 2491 |
T{
| 2492 |
\f[B]rpiece\f[R]
| 2493 |
T} T{
| 2494 |
X
| 2495 |
T} T{
| 2496 |
X+
| 2497 |
T} T{
| 2498 |
| 2499 |
T}
| 2500 |
T{
| 2501 |
\f[B]rtrace\f[R]
| 2502 |
T} T{
| 2503 |
X
| 2504 |
T} T{
| 2505 |
X+
| 2506 |
T} T{
| 2507 |
Customizable ray-tracer
| 2508 |
T}
| 2509 |
T{
| 2510 |
\f[B]rview\f[R]
| 2511 |
T} T{
| 2512 |
X
| 2513 |
T} T{
| 2514 |
X+
| 2515 |
T} T{
| 2516 |
Interactive renderer
| 2517 |
T}
| 2518 |
T{
| 2519 |
\f[B]vwright\f[R]
| 2520 |
T} T{
| 2521 |
X
| 2522 |
T} T{
| 2523 |
T} T{
| 2524 |
Get view parameters and shift them
| 2525 |
T}
| 2526 |
T{
| 2527 |
\f[B]xglaresrc\f[R]
| 2528 |
T} T{
| 2529 |
X
| 2530 |
T} T{
| 2531 |
T} T{
| 2532 |
Display glare sources from \f[B]findglare\f[R]
| 2533 |
T}
| 2534 |
T{
| 2535 |
\f[B]ximage\f[R]
| 2536 |
T} T{
| 2537 |
X+
| 2538 |
T} T{
| 2539 |
T} T{
| 2540 |
Display \f[I]Radiance\f[R] picture under \f[I]X11\f[R]
| 2541 |
T}
| 2542 |
T{
| 2543 |
\f[B]xshowtrace\f[R]
| 2544 |
T} T{
| 2545 |
X
| 2546 |
T} T{
| 2547 |
T} T{
| 2548 |
Show ray traces on \f[I]X11\f[R] display
| 2549 |
T}
| 2550 |
.TE
| 2551 |
.ad
| 2552 |
.LP
| 2553 |
\f[B]Table 6.\f[R] \f[I]Radiance\f[R] programs that read and write
| 2554 |
picture files.
| 2555 |
Pluses indicate when a program makes use of or preserves physical pixel
| 2556 |
values.
| 2557 |
.SH 3
| 2558 |
\f[BI]Radiance\f[B] C Library
| 2559 |
.pdfhref O 3 "Radiance C Library"
| 2560 |
.pdfhref M "radiance-c-library-5"
| 2561 |
.LP
| 2562 |
There are a fair number of routines for reading, writing and
| 2563 |
manipulating \f[I]Radiance\f[R] pictures.
| 2564 |
If you want to write a converter to or from a 24-bit image format, you
| 2565 |
can follow the skeletal example in \f[C]src/px/ra_skel.c\f[R].
| 2566 |
This has all of the basic functionality of the other \f[B]ra_*\f[R]
| 2567 |
image conversion programs, with the actual code for the destination type
| 2568 |
removed (or simplified).
| 2569 |
The method in \f[C]ra_skel\f[R] uses the routines in
| 2570 |
\f[C]src/common/colrops.c\f[R] to avoid conversion to machine floating
| 2571 |
point, which can slow things down and is not necessary in this case.
| 2572 |
.PP
| 2573 |
Below we describe routines for reading and writing pictures, which rely
| 2574 |
heavily on definitions in \f[C]src/common/color.h\f[R].
| 2575 |
We start with the calls for manipulating information headers, followed
| 2576 |
by the calls for resolution strings, then the calls for scanline
| 2577 |
records.
| 2578 |
.PP
| 2579 |
Information headers are manipulated with the routines in
| 2580 |
\f[C]src/common/header.c\f[R] and the macros in \f[C]color.h\f[R].
| 2581 |
Features for handing views are defined in \f[C]src/common/view.h\f[R]
| 2582 |
with routines in \f[C]src/common/image.c\f[R].
| 2583 |
Here are the relevant calls for reading and copying information headers:
| 2584 |
.IP "\f[B]\f[CB]int checkheader(FILE *fin, char *fmt, FILE *fout);\f[B]\f[R]" 3
| 2585 |
Read the header information from \f[C]fin\f[R], copying to
| 2586 |
\f[C]fou\f[R]t (unless fout is \f[C]NULL\f[R]), checking any
| 2587 |
\f[C]FORMAT\f[R] line against the string \f[C]fmt\f[R].
| 2588 |
The \f[C]FORMAT\f[R] line (if it exists) will not be copied to
| 2589 |
\f[C]fout\f[R].
| 2590 |
The function returns 1 if the header was OK and the format matched, 0 if
| 2591 |
the header was OK but there was no format line, and -1 if the format
| 2592 |
line did not match or there was some problem reading the header.
| 2593 |
Wildcard characters (`*' and `?') may appear in \f[C]fmt\f[R], in which
| 2594 |
case a globbing match is applied, and the matching format value will be
| 2595 |
copied to fmt upon success.
| 2596 |
The normal \f[C]fmt\f[R] values for pictures are \f[C]COLRFMT\f[R] for
| 2597 |
\f[I]Radiance\f[R] RGB, \f[C]CIEFMT\f[R] for 4-byte XYZ pixels, or a
| 2598 |
copy of \f[C]PICFMT\f[R] for glob matches to either.
| 2599 |
(Do not pass \f[C]PICFMT\f[R] directly, as this will cause an illegal
| 2600 |
memory access on systems that store static strings in read-only memory.)
| 2601 |
.RS 3
| 2602 |
.RE
| 2603 |
.IP "\f[B]\f[CB]int getheader(FILE *fp, int (*f)(), char *p);\f[B]\f[R]" 3
| 2604 |
For those who need more control, \f[C]getheader\f[R] reads the header
| 2605 |
from \f[C]fp\f[R], calling the function \f[C]f\f[R] (if
| 2606 |
not\f[C]NULL\f[R]) with each input line and the client data pointer
| 2607 |
\f[C]p\f[R].
| 2608 |
A simple call to skip the header is \f[C]getheader(fp,NULL,NULL)\f[R].
| 2609 |
To copy the header unconditionally to \f[C]stdout\f[R], call
| 2610 |
\f[C]getheader(fp,fputs,stdout)\f[R].
| 2611 |
More often, \f[C]getheader\f[R] is called with a client function, which
| 2612 |
checks each line for specific variable settings.
| 2613 |
.RS 3
| 2614 |
.RE
| 2615 |
.IP "\f[B]\f[CB]int isformat(char *s);\f[B]\f[R]" 3
| 2616 |
Returns non-zero if the line \f[C]s\f[R] is a \f[C]FORMAT\f[R]
| 2617 |
assignment.
| 2618 |
.RS 3
| 2619 |
.RE
| 2620 |
.IP "\f[B]\f[CB]int formatval(char *r, char *s);\f[B]\f[R]" 3
| 2621 |
Returns the \f[C]FORMAT\f[R] value from line \f[C]s\f[R] in the string
| 2622 |
\f[C]r\f[R].
| 2623 |
Returns non-zero if \f[C]s\f[R] is a valid format line.
| 2624 |
.RS 3
| 2625 |
.RE
| 2626 |
.IP "\f[B]\f[CB]fputformat(char *s, FILE *fp);\f[B]\f[R]" 3
| 2627 |
Put format assignment \f[C]s\f[R] to the stream \f[C]fp\f[R].
| 2628 |
.RS 3
| 2629 |
.RE
| 2630 |
.IP "\f[B]\f[CB]isexpos(s)\f[B]\f[R]" 3
| 2631 |
Macro returns non-zero if the line \f[C]s\f[R] is an \f[C]EXPOSURE\f[R]
| 2632 |
setting.
| 2633 |
.RS 3
| 2634 |
.RE
| 2635 |
.IP "\f[B]exposval(s)\f[R]" 3
| 2636 |
Macro returns \f[B]double\f[R] exposure value from line \f[C]s\f[R].
| 2637 |
.RS 3
| 2638 |
.RE
| 2639 |
.IP "\f[B]\f[CB]fputexpos(ex,fp)\f[B]\f[R]" 3
| 2640 |
Macro** | puts real exposure value \f[C]ex\f[R] to stream \f[C]fp\f[R].
| 2641 |
.RS 3
| 2642 |
.RE
| 2643 |
.LP
| 2644 |
\f[C]iscolcor(s)\f[R] :Macro returns non-zero if the line \f[C]s\f[R] is
| 2645 |
a \f[C]COLORCORR\f[R] setting.
| 2646 |
.IP "\f[B]\f[CB]colcorval(cc,s)\f[B]\f[R]" 3
| 2647 |
Macro assign color correction value from line \f[C]s\f[R] in the
| 2648 |
\f[C]COLOR\f[R] variable \f[C]cc\f[R].
| 2649 |
.RS 3
| 2650 |
.RE
| 2651 |
.IP "\f[B]\f[CB]fputcolcor(cc,fp)\f[B]\f[R]" 3
| 2652 |
Macro puts correction \f[C]COLOR\f[R] \f[C]cc\f[R] to stream
| 2653 |
\f[C]fp\f[R].
| 2654 |
.RS 3
| 2655 |
.RE
| 2656 |
.IP "\f[B]\f[CB]isaspect(s)\f[B]\f[R]" 3
| 2657 |
Macro returns non-zero if the line \f[C]s\f[R] is a \f[C]PIXASPECT\f[R]
| 2658 |
setting.
| 2659 |
.RS 3
| 2660 |
.RE
| 2661 |
.IP "\f[B]\f[CB]aspectval(s)\f[B]\f[R]" 3
| 2662 |
Macro returns double pixel aspect value from line \f[C]s\f[R].
| 2663 |
.RS 3
| 2664 |
.RE
| 2665 |
.IP "\f[B]\f[CB]fputaspect(pa,fp)\f[B]\f[R]" 3
| 2666 |
Macro puts real pixel aspect value \f[C]pa\f[R] to stream \f[C]fp\f[R].
| 2667 |
.RS 3
| 2668 |
.RE
| 2669 |
.IP "\f[B]\f[CB]int isview(char *s);\f[B]\f[R]" 3
| 2670 |
Returns non-zero if header line \f[C]s\f[R] contains view parameters.
| 2671 |
Note that \[ga]\f[C]s\f[R] could be either a \f[C]VIEW\f[R] assignment
| 2672 |
or a rendering command.
| 2673 |
.RS 3
| 2674 |
.RE
| 2675 |
.IP "\f[B]\f[CB]int sscanview(VIEW *vp, char *s);\f[B]\f[R]" 3
| 2676 |
Scan view options from the string \f[C]s\f[R] into the \f[C]VIEW\f[R]
| 2677 |
structure pointed to by \f[C]vp\f[R].
| 2678 |
.RS 3
| 2679 |
.RE
| 2680 |
.IP "\f[B]\f[CB]fprintview(VIEW *vp, FILE *fp);\f[B]\f[R]" 3
| 2681 |
Print view options in \f[C]vp\f[R] to the stream \f[C]fp\f[R].
| 2682 |
Note that this does not print out \[lq]VIEW=\[rq] first, or end the
| 2683 |
line.
| 2684 |
Therefore, one usually calls \f[C]fputs(VIEWSTR,fp)\f[R] followed by
| 2685 |
\f[C]fprintview(vp,fp)\f[R], then \f[C]putc(\[aq]\[rs]n\[aq],fp)\f[R].
| 2686 |
.RS 3
| 2687 |
.RE
| 2688 |
.IP "\f[B]\f[CB]isprims(s)\f[B]\f[R]" 3
| 2689 |
Macro returns non-zero if the line \f[C]s\f[R] is a \f[C]PRIMARIES\f[R]
| 2690 |
setting.
| 2691 |
.RS 3
| 2692 |
.RE
| 2693 |
.IP "\f[B]\f[CB]primsval(p,s)\f[B]\f[R]" 3
| 2694 |
Macro assign color primitives from line \f[C]s\f[R] in the
| 2695 |
\f[C]RGBPRIMS\f[R] variable \f[C]p\f[R].
| 2696 |
.RS 3
| 2697 |
.RE
| 2698 |
.IP "\f[B]\f[CB]fputprims(p,fp)\f[B]\f[R]" 3
| 2699 |
Macro puts color primitives \f[C]p\f[R] to stream \f[C]fp\f[R].
| 2700 |
.RS 3
| 2701 |
.RE
| 2702 |
.LP
| 2703 |
The header file \f[C]src/common/resolu.h\f[R] has macros for resolution
| 2704 |
strings, which are handled by routines in \f[C]src/common/resolu.c\f[R].
| 2705 |
Here are the relevant calls:
| 2706 |
.IP "\f[B]\f[CB]fgetsresolu(rs,fp)\f[B]\f[R]" 3
| 2707 |
Macro to get a resolution string from the stream \f[C]fp\f[R] and put it
| 2708 |
in the \f[C]RESOLU\f[R] structure pointed to by \f[C]rs\f[R].
| 2709 |
The return value is non-zero if the resolution was successfully loaded.
| 2710 |
.RS 3
| 2711 |
.RE
| 2712 |
.IP "\f[B]\f[CB]fputsresolu(rs,fp)\f[B]\f[R]" 3
| 2713 |
Macro to write the \f[C]RESOLU\f[R] structure pointed to by rs to the
| 2714 |
stream fp.
| 2715 |
.RS 3
| 2716 |
.RE
| 2717 |
.IP "\f[B]\f[CB]scanlen(rs)\f[B]\f[R]" 3
| 2718 |
Macro to get the scanline length from the \f[C]RESOL\f[R]U structure
| 2719 |
| 2720 |
.RS 3
| 2721 |
.RE
| 2722 |
.IP "\f[B]\f[CB]numscans(rs)\f[B]\f[R]" 3
| 2723 |
Macro to get the number of scanlines from the \f[C]RESOLU\f[R] structure
| 2724 |
| 2725 |
.RS 3
| 2726 |
.RE
| 2727 |
.IP "\f[B]\f[CB]fscnresolu(slp,nsp,fp)\f[B]\f[R]" 3
| 2728 |
Macro to read in a resolution string from \f[C]f\f[R]p and assign the
| 2729 |
scanline length and number of scanlines to the integers pointed to by
| 2730 |
\f[C]slp\f[R] and \f[C]nsp\f[R], respectively.
| 2731 |
This call expects standard English-text ordered scanlines, and returns
| 2732 |
non-zero only if the resolution string agrees.
| 2733 |
.RS 3
| 2734 |
.RE
| 2735 |
.IP "\f[B]\f[CB]fprtresolu(sl,ns,fp)\f[B]\f[R]" 3
| 2736 |
Macro to print out a resolution string for \f[C]ns\f[R] scanlines of
| 2737 |
length \f[C]sl\f[R] in standard English-text ordering to \f[C]fp\f[R].
| 2738 |
.RS 3
| 2739 |
.RE
| 2740 |
.LP
| 2741 |
The file \f[C]src/common/color.c\f[R] contains the essential routines
| 2742 |
for reading and writing scanline records.
| 2743 |
Here are the relevant calls and macros:
| 2744 |
.IP "\f[B]\f[CB]int freadcolrs(COLR *scn, int sl, FILE *fp);\f[B]\f[R]" 3
| 2745 |
Read a scanline record of length \f[C]sl\f[R] from stream \f[C]fp\f[R]
| 2746 |
into the \f[C]COLR\f[R] array \f[C]scn\f[R].
| 2747 |
Interprets uncompressed, old, and new run-length encoded records.
| 2748 |
Returns 0 on success, -1 on failure.
| 2749 |
.RS 3
| 2750 |
.RE
| 2751 |
.IP "\f[B]\f[CB]int fwritecolrs(COLR *scn, int sl, FILE *fp);\f[B]\f[R]" 3
| 2752 |
Write the scanline record stored in the \f[C]COLR\f[R] array
| 2753 |
\f[C]scn\f[R], length \f[C]sl\f[R], to the stream \f[C]fp\f[R].
| 2754 |
Uses the new run-length encoding unless \f[C]sl\f[R] is less than 8 or
| 2755 |
greater than 32767, when an uncompressed record is written.
| 2756 |
Returns 0 on success, -1 if there was an error.
| 2757 |
.RS 3
| 2758 |
.RE
| 2759 |
.IP "\f[B]\f[CB]int freadscan(COLOR *fscn, int sl, FILE *fp);\f[B]\f[R]" 3
| 2760 |
Reads a scanline of length \f[C]sl\f[R] from the stream \f[C]fp\f[R] and
| 2761 |
converts to machine floating-point format in the array \f[C]fscn\f[R].
| 2762 |
Recognizes all scanline record encodings.
| 2763 |
Returns 0 on success, or -1 on failure.
| 2764 |
.RS 3
| 2765 |
.RE
| 2766 |
.IP "\f[B]\f[CB]int fwritescan(COLOR *fscn, int sl, FILE *fp);\f[B]\f[R]" 3
| 2767 |
Write the floating-point scanline of length \f[C]sl\f[R] stored in the
| 2768 |
array fscn to the stream \f[C]fp\f[R].
| 2769 |
Converts to 4-byte/pixel scanline format and calls \f[C]fwritecolrs\f[R]
| 2770 |
to do the actual write.
| 2771 |
Returns 0 on success, or -1 if there was an error.
| 2772 |
.RS 3
| 2773 |
.RE
| 2774 |
.IP "\f[B]\f[CB]colval(col,p)\f[B]\f[R]" 3
| 2775 |
Macro to get primary p from the floating-point \f[C]COLOR col\f[R].
| 2776 |
The primary index may be one of \f[C]RED\f[R], \f[C]GRN\f[R] or
| 2777 |
\f[C]BLU\f[R] for RGB colors, or CIEX, CIEY or CIEZ for XYZ colors.
| 2778 |
This macro is a valid lvalue, so can be used on the left of assignment
| 2779 |
statements as well.
| 2780 |
.RS 3
| 2781 |
.RE
| 2782 |
.IP "\f[B]\f[CB]colrval(clr,p)\f[B]\f[R]" 3
| 2783 |
Macro to get primary \f[C]p\f[R] from the 4-byte \f[C]COLR\f[R] pixel
| 2784 |
\f[C]clr\f[R].
| 2785 |
The primary index may be one of RED, GRN or BLU for RGB colors, or CIEX,
| 2786 |
| 2787 |
Unless just one primary is needed, it is more efficient to call
| 2788 |
\f[C]colr_color\f[R] and use the \f[C]colval\f[R] macro on the result.
| 2789 |
.RS 3
| 2790 |
.RE
| 2791 |
.IP "\f[B]\f[CB]colr_color(COLOR col, COLR clr);\f[B]\f[R]" 3
| 2792 |
Convert the 4-byte pixel \f[C]clr\f[R] to a machine floating-point
| 2793 |
representation and store the result in \f[C]col\f[R].
| 2794 |
.RS 3
| 2795 |
.RE
| 2796 |
.IP "\f[B]\f[CB]setcolr(COLR clr, double p1, p2, p3);\f[B]\f[R]" 3
| 2797 |
Assign the 4-byte pixel \f[C]clr\f[R] according to the three primary
| 2798 |
values \f[C]p1\f[R], \f[C]p2\f[R] and \f[C]p3\f[R].
| 2799 |
These can be either \f[I]Radiance\f[R] RGB values or CIE XYZ values.
| 2800 |
.RS 3
| 2801 |
.RE
| 2802 |
.SH 2
| 2803 |
Z-buffer Format (.zbf suffix)
| 2804 |
.pdfhref O 2 "Z-buffer Format \(.zbf suffix\)"
| 2805 |
.pdfhref M "z-buffer-format-.zbf-suffix"
| 2806 |
.LP
| 2807 |
The Z-buffer format used in \f[I]Radiance\f[R] hardly qualifies as a
| 2808 |
format at all.
| 2809 |
It is in fact a straight copy on the 4-byte machine floating point
| 2810 |
values of each pixel in standard scanline order.
| 2811 |
There is no information header or resolution string that would make the
| 2812 |
file independently useful.
| 2813 |
This is usually OK, because Z-buffer files are almost always created and
| 2814 |
used in conjunction with a picture file, which has this identifying
| 2815 |
information.
| 2816 |
.PP
| 2817 |
The major shortcoming of this format is that the machine representation
| 2818 |
and byte ordering is not always the same from one system to another,
| 2819 |
which limits the portability of Z-buffer files.
| 2820 |
Since they are primarily used for interpolating animation frames, and
| 2821 |
this usually occurs on networks with similar architectures, there is
| 2822 |
usually no problem.
| 2823 |
Also, since the adoption of IEEE standard floating-point calculations,
| 2824 |
different machine representations are becoming quite rare.
| 2825 |
[TBD: is this necessary at this point?]
| 2826 |
.SH 3
| 2827 |
| 2828 |
| 2829 |
.pdfhref M "radiance-programs-6"
| 2830 |
.LP
| 2831 |
Table 7 shows the programs that read and write \f[I]Radiance\f[R]
| 2832 |
Z-buffer files.
| 2833 |
The pvalue program may be used to convert Z-buffer files to
| 2834 |
\f[I]Radiance\f[R] pictures for the purpose of visualizing the values
| 2835 |
using falsecolor.
| 2836 |
For example, the following command converts the Z-buffer file
| 2837 |
\f[C]frame110.zbf\f[R] associated with the picture
| 2838 |
\f[C]frame110.hdr\f[R] to a viewable image:
| 2839 |
.IP
| 2840 |
.nf
| 2841 |
\f[C]
| 2842 |
% pvalue -h \[ga]getinfo -d < frame110.hdr\[ga] -r -b -df
| 2843 |
frame110.zbf | falsecolor -m 1 -s 40 -l Meters >
| 2844 |
frame110z.hdr
| 2845 |
\f[]
| 2846 |
.fi
| 2847 |
.LP
| 2848 |
The \f[B]getinfo\f[R] program appearing in back-quotes was used to get
| 2849 |
the dimensions associated with the Z-buffer from its corresponding
| 2850 |
picture file.
| 2851 |
.PP
| 2852 |
.na
| 2853 |
.TS
| 2854 |
delim(@@) tab( );
| 2855 |
l l l l.
| 2856 |
T{
| 2857 |
Program
| 2858 |
T} T{
| 2859 |
Read
| 2860 |
T} T{
| 2861 |
Write
| 2862 |
T} T{
| 2863 |
Function
| 2864 |
T}
| 2865 |
_
| 2866 |
T{
| 2867 |
\f[B]pinterp\f[R]
| 2868 |
T} T{
| 2869 |
X
| 2870 |
T} T{
| 2871 |
X
| 2872 |
T} T{
| 2873 |
| 2874 |
T}
| 2875 |
T{
| 2876 |
\f[B]pvalue\f[R]
| 2877 |
T} T{
| 2878 |
X
| 2879 |
T} T{
| 2880 |
X
| 2881 |
T} T{
| 2882 |
| 2883 |
T}
| 2884 |
T{
| 2885 |
\f[B]rad\f[R]
| 2886 |
T} T{
| 2887 |
T} T{
| 2888 |
X
| 2889 |
T} T{
| 2890 |
| 2891 |
T}
| 2892 |
T{
| 2893 |
\f[B]ranimate\f[R]
| 2894 |
T} T{
| 2895 |
X
| 2896 |
T} T{
| 2897 |
X
| 2898 |
T} T{
| 2899 |
| 2900 |
T}
| 2901 |
T{
| 2902 |
\f[B]rpict\f[R]
| 2903 |
T} T{
| 2904 |
T} T{
| 2905 |
X
| 2906 |
T} T{
| 2907 |
| 2908 |
T}
| 2909 |
T{
| 2910 |
\f[B]rtrace\f[R]
| 2911 |
T} T{
| 2912 |
T} T{
| 2913 |
X
| 2914 |
T} T{
| 2915 |
| 2916 |
T}
| 2917 |
.TE
| 2918 |
.ad
| 2919 |
.LP
| 2920 |
\f[B]Table 7.\f[R] \f[I]Radiance\f[R] programs that read and write
| 2921 |
Z-buffer files.
| 2922 |
.SH 3
| 2923 |
| 2924 |
| 2925 |
.pdfhref M "radiance-c-library-6"
| 2926 |
.LP
| 2927 |
There are no library functions devoted to reading and writing Z-buffer
| 2928 |
files in particular.
| 2929 |
The normal method is to read and write Z-buffer scanlines with the
| 2930 |
standard \f[C]fread\f[R] and \f[C]fwrite\f[R] library functions using an
| 2931 |
appropriate float array.
| 2932 |
.SH 2
| 2933 |
Ambient File Format (.amb suffix)
| 2934 |
.pdfhref O 2 "Ambient File Format \(.amb suffix\)"
| 2935 |
.pdfhref M "ambient-file-format-.amb-suffix"
| 2936 |
.LP
| 2937 |
\f[I]Radiance\f[R] can store its diffuse interreflection cache in an
| 2938 |
\f[I]ambient file\f[R] for reuse by other processes.
| 2939 |
This file is in a system-independent binary format, similar to an octree
| 2940 |
or picture file, with an information header that can be read using
| 2941 |
\f[B]getinfo\f[R].
| 2942 |
Following the header, there is a magic number specific to this file
| 2943 |
type, then the ambient value records themselves in encoded form.
| 2944 |
.SH 4
| 2945 |
Information Header
| 2946 |
| 2947 |
.pdfhref M "information-header-2"
| 2948 |
.LP
| 2949 |
The information header begins with the usual \[lq]#?RADIANCE\[rq]
| 2950 |
identifier, followed by the originating program and the ambient
| 2951 |
calculation parameters (and octree name).
| 2952 |
After this is the line:
| 2953 |
.IP
| 2954 |
.nf
| 2955 |
\f[C]
| 2956 |
FORMAT=Radiance_ambval
| 2957 |
\f[]
| 2958 |
.fi
| 2959 |
.LP
| 2960 |
This identifies the general file type, followed by an empty line ending
| 2961 |
the header.
| 2962 |
As with most information headers, this exact sequence need not be
| 2963 |
followed, so long as there is no inconsistent \f[C]FORMAT\f[R] setting.
| 2964 |
.SH 4
| 2965 |
Magic Number
| 2966 |
.pdfhref O 4 "Magic Number"
| 2967 |
.pdfhref M "magic-number"
| 2968 |
.LP
| 2969 |
Following the information header is the two-byte magic number, which for
| 2970 |
the current ambient file format is 557.
| 2971 |
This number may change later should the file format be altered in
| 2972 |
incompatible ways.
| 2973 |
.SH 4
| 2974 |
Ambient Value Records
| 2975 |
.pdfhref O 4 "Ambient Value Records"
| 2976 |
.pdfhref M "ambient-value-records"
| 2977 |
.LP
| 2978 |
Ambient values are written to the file in no particular order.
| 2979 |
Each diffuse interreflection value in \f[I]Radiance\f[R] has the
| 2980 |
following members:
| 2981 |
.IP "\f[B]Level\f[R]" 3
| 2982 |
The number of reflections between the primary (eye) ray and this
| 2983 |
surface.
| 2984 |
A value with fewer reflections may be used in place of one with more,
| 2985 |
but not the other way around.
| 2986 |
.RS 3
| 2987 |
.RE
| 2988 |
.IP "\f[B]Weight\f[R]" 3
| 2989 |
The weighting value associated with this ray or ambient value.
| 2990 |
Similar to the level to avoid using inappropriate values from the cache.
| 2991 |
.RS 3
| 2992 |
.RE
| 2993 |
.IP "\f[B]Position\f[R]" 3
| 2994 |
The origin point of this interreflection calculation.
| 2995 |
.RS 3
| 2996 |
.RE
| 2997 |
.IP "\f[B]Direction\f[R]" 3
| 2998 |
The surface normal indicating the zenith of the sample hemisphere for
| 2999 |
this value.
| 3000 |
.RS 3
| 3001 |
.RE
| 3002 |
.IP "\f[B]Value\f[R]" 3
| 3003 |
The calculated indirect irradiance at this point, in w/m\*{2\*} (RGB
| 3004 |
color).
| 3005 |
.RS 3
| 3006 |
.RE
| 3007 |
.IP "\f[B]Radius\f[R]" 3
| 3008 |
The cosine-weighted, harmonic mean distance to other surfaces visible
| 3009 |
from this point, used to decide point spacing.
| 3010 |
.RS 3
| 3011 |
.RE
| 3012 |
.IP "\f[B]Posgradient\f[R]" 3
| 3013 |
The position-based gradient vector, indicating how brightness changes as
| 3014 |
a function of position in the sample plane.
| 3015 |
.RS 3
| 3016 |
.RE
| 3017 |
.IP "\f[B]Dirgradient\f[R]" 3
| 3018 |
The direction-based gradient vector, indicating how brightness changes
| 3019 |
as a function of surface orientation.
| 3020 |
.RS 3
| 3021 |
.RE
| 3022 |
.LP
| 3023 |
The members are stored one after the other in the above order using
| 3024 |
system-independent binary representations.
| 3025 |
The Level member takes 1 byte, Weight takes 5, Position takes 15,
| 3026 |
Direction another 15, Value is 4 bytes (using the same color format as
| 3027 |
\f[I]Radiance\f[R] pictures), Radius takes 5 bytes, and Posgradient and
| 3028 |
Dirgradient each take 15 bytes, for a total size of 75 bytes per record.
| 3029 |
.SH 3
| 3030 |
\f[BI]Radiance\f[B] Programs
| 3031 |
.pdfhref O 3 "Radiance Programs"
| 3032 |
.pdfhref M "radiance-programs-7"
| 3033 |
.LP
| 3034 |
Table 8 shows \f[I]Radiance\f[R] programs that read and write ambient
| 3035 |
files.
| 3036 |
The program \f[B]lookamb\f[R] is especially useful for examining the
| 3037 |
contents of ambient files and debugging problems in the calculation.
| 3038 |
.PP
| 3039 |
.na
| 3040 |
.TS
| 3041 |
delim(@@) tab( );
| 3042 |
l l l l.
| 3043 |
T{
| 3044 |
Program
| 3045 |
T} T{
| 3046 |
Read
| 3047 |
T} T{
| 3048 |
Write
| 3049 |
T} T{
| 3050 |
Function
| 3051 |
T}
| 3052 |
_
| 3053 |
T{
| 3054 |
\f[B]getinfo\f[R]
| 3055 |
T} T{
| 3056 |
X
| 3057 |
T} T{
| 3058 |
T} T{
| 3059 |
| 3060 |
T}
| 3061 |
T{
| 3062 |
\f[B]lookamb\f[R]
| 3063 |
T} T{
| 3064 |
X
| 3065 |
T} T{
| 3066 |
X
| 3067 |
T} T{
| 3068 |
Convert \f[I]Radiance\f[R] ambient file
| 3069 |
T}
| 3070 |
T{
| 3071 |
\f[B]rad\f[R]
| 3072 |
T} T{
| 3073 |
X
| 3074 |
T} T{
| 3075 |
X
| 3076 |
T} T{
| 3077 |
Render \f[I]Radiance\f[R] scene
| 3078 |
T}
| 3079 |
T{
| 3080 |
\f[B]rpict\f[R]
| 3081 |
T} T{
| 3082 |
X
| 3083 |
T} T{
| 3084 |
X
| 3085 |
T} T{
| 3086 |
| 3087 |
T}
| 3088 |
T{
| 3089 |
\f[B]rpiece\f[R]
| 3090 |
T} T{
| 3091 |
X
| 3092 |
T} T{
| 3093 |
X
| 3094 |
T} T{
| 3095 |
| 3096 |
T}
| 3097 |
T{
| 3098 |
\f[B]rtrace\f[R]
| 3099 |
T} T{
| 3100 |
X
| 3101 |
T} T{
| 3102 |
X
| 3103 |
T} T{
| 3104 |
| 3105 |
T}
| 3106 |
T{
| 3107 |
\f[B]rview\f[R]
| 3108 |
T} T{
| 3109 |
X
| 3110 |
T} T{
| 3111 |
X
| 3112 |
T} T{
| 3113 |
| 3114 |
T}
| 3115 |
.TE
| 3116 |
.ad
| 3117 |
.LP
| 3118 |
\f[B]Table 8.\f[R] Programs in the \f[I]Radiance\f[R] distribution that
| 3119 |
read and write ambient files.
| 3120 |
.SH 3
| 3121 |
| 3122 |
| 3123 |
.pdfhref M "radiance-c-library-7"
| 3124 |
.LP
| 3125 |
The \f[C]src/rt/ambient.h\f[R] file contains definitions of the
| 3126 |
\f[C]AMBVAL\f[R] structure and certain details of the ambient file
| 3127 |
format.
| 3128 |
The \f[C]src/rt/ambio.c\f[R] module contains the specialized routines
| 3129 |
for reading and writing ambient files, and these functions in turn
| 3130 |
access routines in \f[C]src/common/portio.c\f[R] for reading and writing
| 3131 |
| 3132 |
The information header is handled by the routines in
| 3133 |
s\f[C]rc/common/header.c\f[R], similar to the method described for
| 3134 |
\f[I]Radiance\f[R] picture files.
| 3135 |
Here are the main calls from \f[C]src/rt/ambio.c\f[R]:
| 3136 |
.IP "\f[B]\f[CB]putambmagic(FILE *fp);\f[B]\f[R]" 3
| 3137 |
Put out the appropriate two-byte magic number for a \f[I]Radiance\f[R]
| 3138 |
ambient file to the stream \f[C]fp\f[R].
| 3139 |
.RS 3
| 3140 |
.RE
| 3141 |
.IP "\f[B]\f[CB]int hasambmagic(FILE *fp);\f[B]\f[R]" 3
| 3142 |
Read the next two bytes from the stream \f[C]fp\f[R] and return non-zero
| 3143 |
if they match an ambient file\[cq]s magic number.
| 3144 |
.RS 3
| 3145 |
.RE
| 3146 |
.IP "\f[B]\f[CB]int writeambval(AMBVAL *av, FILE *fp);\f[B]\f[R]" 3
| 3147 |
Write out the ambient value structure \f[C]av\f[R] to the stream
| 3148 |
\f[C]fp\f[R], returning -1 if a file error occurred, or 0 normally.
| 3149 |
.RS 3
| 3150 |
.RE
| 3151 |
.IP "\f[B]\f[CB]int readambval(AMBVAL *av, FILE *fp);\f[B]\f[R]" 3
| 3152 |
Read in the next ambient value structure from the stream \f[C]fp\f[R]
| 3153 |
and put the result in \f[C]av\f[R].
| 3154 |
Return 1 if the read was successful, 0 if the end of file was reached or
| 3155 |
there was an error.
| 3156 |
The \f[C]ambvalOK\f[R] function is used to check the consistency of the
| 3157 |
value read.
| 3158 |
.RS 3
| 3159 |
.RE
| 3160 |
.IP "\f[B]\f[CB]int ambvalOK(AMBVAL *av);\f[B]\f[R]" 3
| 3161 |
Return non-zero if the member values of the \f[C]av\f[R] structure are
| 3162 |
not too outlandish.
| 3163 |
This is handy as insurance against a corrupted ambient file.
| 3164 |
.RS 3
| 3165 |
.RE
| 3166 |
.SH 2
| 3167 |
Conclusion
| 3168 |
.pdfhref O 2 "Conclusion"
| 3169 |
.pdfhref M "conclusion"
| 3170 |
.LP
| 3171 |
We have described the main file formats native to \f[I]Radiance\f[R] and
| 3172 |
shown how even the binary formats can be reliably shared in
| 3173 |
heterogeneous computing environments.
| 3174 |
This corresponds to one of the basic philosophies of UNIX software,
| 3175 |
which is system independence.
| 3176 |
A more detailed understanding of the formats may still require some use
| 3177 |
of binary dump programs and delving into the \f[I]Radiance\f[R] source
| 3178 |
code.
