root/radiance/ray/cmake_tests/test_setup.cmake
Revision: 1.1
Committed: Sat Oct 22 22:38:10 2011 UTC (13 years, 6 months ago) by greg
CVS Tags: rad4R2P2, rad4R2P1, rad5R1, rad4R2, rad4R1, rad5R0
Added qt interface for rvu and cmake files from Bill Hoffman
1 include(setup_paths.cmake) # configured file found in the same dir as this file
2
3 file(REMOVE_RECURSE ${test_output_dir})
4 file(MAKE_DIRECTORY ${test_output_dir})
5
6 message("Run: [oconv${CMAKE_EXECUTABLE_SUFFIX} model.b90 desk misc]")
7 execute_process(
8 COMMAND oconv${CMAKE_EXECUTABLE_SUFFIX} model.b90 desk misc
9 WORKING_DIRECTORY ${office_dir}
10 OUTPUT_FILE test/raytest_modelb.oct
11 RESULT_VARIABLE res
12 )
13 if(NOT ${res} EQUAL 0)
14 message(FATAL_ERROR "Bad return value from oconv, res = ${res}")
15 endif()
16
17 message("Run:
18 [oconv${CMAKE_EXECUTABLE_SUFFIX} -f -i test/raytest_modelb.oct
19 window blinds lights lamp picture]")
20 execute_process(
21 COMMAND oconv${CMAKE_EXECUTABLE_SUFFIX}
22 -f -i test/raytest_modelb.oct window blinds lights lamp picture
23 WORKING_DIRECTORY ${office_dir}
24 OUTPUT_FILE test/raytest_model.oct
25 RESULT_VARIABLE res
26 )
27
28 if(NOT ${res} EQUAL 0)
29 message(FATAL_ERROR "Bad return value from oconv, res = ${res}")
30 endif()
