root/radiance/ray/cmake_tests/test_DC.cmake
Revision: 1.2
Committed: Wed Apr 25 22:21:06 2012 UTC (12 years, 1 month ago) by greg
CVS Tags: rad4R2P2, rad4R2P1, rad5R1, rad4R2, rad5R0
1 include(setup_paths.cmake)
2
3 file(MAKE_DIRECTORY "${test_output_dir}/dc")
4
5 set(view_def -x 50 -y 50 -vf model.vp)
6 message(STATUS "view_def=${view_def}")
7
8 file(WRITE ${office_dir}/test/raytest_dc.sky
9 "void glow skyglow\n0\n0\n4\n1 1 1 0\n\nskyglow source sky\n0\n0\n4\n0 0 1 360
10 ")
11
12 message("Run: oconv${CMAKE_EXECUTABLE_SUFFIX} -f -i test/raytest_model.oct test/raytest_dc.sky")
13 execute_process(
14 WORKING_DIRECTORY ${office_dir}
15 COMMAND oconv${CMAKE_EXECUTABLE_SUFFIX} -f -i test/raytest_model.oct test/raytest_dc.sky
16 OUTPUT_FILE test/raytest_model_dc.oct
17 )
18
19 execute_process(
20 WORKING_DIRECTORY ${office_dir}
21 COMMAND vwrays${CMAKE_EXECUTABLE_SUFFIX} -d ${view_def}
22 OUTPUT_VARIABLE vwrays_out
23 )
24
25 message(STATUS "vwrays_out: ${vwrays_out}")
26 string(STRIP "${vwrays_out}" vwrays_out)
27 separate_arguments(vwrays_out)
28
29 message("Run: vwrays${CMAKE_EXECUTABLE_SUFFIX} -ff ${view_def} | rtcontrib${CMAKE_EXECUTABLE_SUFFIX} -ab 1 ${rtcontrib_threads}-V+ -fo -ffc $\(vwrays -d ${view_def}\) -f tregenza.cal -bn 146 -b tbin -o ${test_output_dir}/dc/treg%03d.hdr -m skyglow test/raytest_model_dc.oct")
30 execute_process(
31 WORKING_DIRECTORY ${office_dir}
32 COMMAND vwrays${CMAKE_EXECUTABLE_SUFFIX} -ff ${view_def}
33 COMMAND rtcontrib${CMAKE_EXECUTABLE_SUFFIX} -ab 1 ${rtcontrib_threads}-V+ -fo -ffc ${vwrays_out} -f tregenza.cal -bn 146 -b tbin -o ${test_output_dir}/dc/treg%03d.hdr -m skyglow test/raytest_model_dc.oct
34 RESULT_VARIABLE res
35 )
36 if(NOT ${res} EQUAL 0)
37 message(FATAL_ERROR "Bad return value from vwrays, res = ${res}")
38 endif()
39
40 execute_process(
41 WORKING_DIRECTORY ${office_dir}
42 COMMAND gensky${CMAKE_EXECUTABLE_SUFFIX} 03 21 12 -a 40 -o 105 -m 105 +s
43 COMMAND ${perl} ${util_dir}/genskyvec.pl -m 1
44 COMMAND dctimestep${CMAKE_EXECUTABLE_SUFFIX} test/dc/treg%03d.hdr
45 COMMAND pfilt${CMAKE_EXECUTABLE_SUFFIX} -1 -x /1 -y /1
46 OUTPUT_FILE test/raytest_timestep.hdr
47 RESULT_VARIABLE res
48 )
49
50 if(NOT ${res} EQUAL 0)
51 message(FATAL_ERROR "Bad return value, res = ${res}")
52 endif()
53
54 file(READ ${office_dir}/test/raytest_timestep.hdr test_output)
55 if(test_output MATCHES "dctimestep${CMAKE_EXECUTABLE_SUFFIX} test/dc/treg%03d.hdr")
56 message(STATUS "passed")
57 else()
58 message(STATUS "failed")
59 endif()
