root/radiance/ray/cmake_tests/CMakeLists.txt
Revision: 1.1
Committed: Sat Oct 22 22:38:10 2011 UTC (13 years, 5 months ago) by greg
CVS Tags: rad4R2P2, rad4R2P1, rad5R1, rad4R2, rad4R1, rad5R0
Added qt interface for rvu and cmake files from Bill Hoffman
# User Rev Content
1 greg 1.1 include(FindPerl)
2
3     set(office_dir
4     "${radiance_BINARY_DIR}/Downloads/Source/radiance_support/obj/office")
5     set(test_dir "${CMAKE_CURRENT_BINARY_DIR}")
6
7     configure_file(setup_paths.cmake.in setup_paths.cmake @ONLY)
8     # configure these files so that they will be in the binary
9     # directory. This will allow them to include setup_paths.cmake
10     # from the binary directory and just use regular variables in the
11     # configured files.
12     configure_file(test_setup.cmake test_setup.cmake COPYONLY)
13     configure_file(test_rtrace.cmake test_rtrace.cmake COPYONLY)
14     configure_file(test_rpict.cmake test_rpict.cmake COPYONLY)
15     configure_file(test_getinfo.cmake test_getinfo.cmake COPYONLY)
16     configure_file(test_pcond.cmake test_pcond.cmake COPYONLY)
17     configure_file(test_falsecolor.cmake test_falsecolor.cmake COPYONLY)
18     configure_file(test_DC.cmake test_DC.cmake COPYONLY)
19
20     add_test(test_setup ${CMAKE_COMMAND}
21     -P ${CMAKE_CURRENT_BINARY_DIR}/test_setup.cmake)
22     set_tests_properties(test_setup PROPERTIES FAIL_REGULAR_EXPRESSION
23     "No such file|not found|cannot find file|unexpected character")
24
25     add_test(test_rtrace
26     ${CMAKE_COMMAND} -P ${CMAKE_CURRENT_BINARY_DIR}/test_rtrace.cmake)
27     set_tests_properties(test_rtrace PROPERTIES PASS_REGULAR_EXPRESSION "passed"
28     FAIL_REGULAR_EXPRESSION "failed"
29     DEPENDS "setup")
30     add_test(test_rpict
31     ${CMAKE_COMMAND} -P ${CMAKE_CURRENT_BINARY_DIR}/test_rpict.cmake)
32     set_tests_properties(test_rpict PROPERTIES PASS_REGULAR_EXPRESSION "passed"
33     FAIL_REGULAR_EXPRESSION "failed"
34     DEPENDS "setup")
35     add_test(test_getinfo
36     ${CMAKE_COMMAND} -P ${CMAKE_CURRENT_BINARY_DIR}/test_getinfo.cmake)
37     add_test(test_pcond
38     ${CMAKE_COMMAND} -P ${CMAKE_CURRENT_BINARY_DIR}/test_pcond.cmake)
39     set_tests_properties(test_pcond PROPERTIES PASS_REGULAR_EXPRESSION "passed"
40     FAIL_REGULAR_EXPRESSION "failed"
41     DEPENDS "setup")
42     if(PERL_FOUND)
43     add_test(test_falsecolor
44     ${CMAKE_COMMAND} -P ${CMAKE_CURRENT_BINARY_DIR}/test_falsecolor.cmake)
45     set_tests_properties(test_falsecolor PROPERTIES PASS_REGULAR_EXPRESSION "passed"
46     FAIL_REGULAR_EXPRESSION "failed"
47     DEPENDS "setup")
48     add_test(test_DC
49     ${CMAKE_COMMAND} -P ${CMAKE_CURRENT_BINARY_DIR}/test_DC.cmake)
50     set_tests_properties(test_DC PROPERTIES PASS_REGULAR_EXPRESSION "passed"
51     FAIL_REGULAR_EXPRESSION "failed"
52     DEPENDS "setup")
53     endif()
