root/radiance/ray/cmake_tests/CMakeLists.txt
Revision: 1.2
Committed: Mon Dec 4 21:58:10 2017 UTC (7 years, 4 months ago) by greg
Changes since 1.1: +0 -0 lines
State: FILE REMOVED
Added resources/ directory as requested by Rob G. and moved cmake_tests/ there
1 include(FindPerl)
2
3 set(office_dir
4 "${radiance_BINARY_DIR}/Downloads/Source/radiance_support/obj/office")
5 set(test_dir "${CMAKE_CURRENT_BINARY_DIR}")
6
7 configure_file(setup_paths.cmake.in setup_paths.cmake @ONLY)
8 # configure these files so that they will be in the binary
9 # directory. This will allow them to include setup_paths.cmake
10 # from the binary directory and just use regular variables in the
11 # configured files.
12 configure_file(test_setup.cmake test_setup.cmake COPYONLY)
13 configure_file(test_rtrace.cmake test_rtrace.cmake COPYONLY)
14 configure_file(test_rpict.cmake test_rpict.cmake COPYONLY)
15 configure_file(test_getinfo.cmake test_getinfo.cmake COPYONLY)
16 configure_file(test_pcond.cmake test_pcond.cmake COPYONLY)
17 configure_file(test_falsecolor.cmake test_falsecolor.cmake COPYONLY)
18 configure_file(test_DC.cmake test_DC.cmake COPYONLY)
19
20 add_test(test_setup ${CMAKE_COMMAND}
21 -P ${CMAKE_CURRENT_BINARY_DIR}/test_setup.cmake)
22 set_tests_properties(test_setup PROPERTIES FAIL_REGULAR_EXPRESSION
23 "No such file|not found|cannot find file|unexpected character")
24
25 add_test(test_rtrace
26 ${CMAKE_COMMAND} -P ${CMAKE_CURRENT_BINARY_DIR}/test_rtrace.cmake)
27 set_tests_properties(test_rtrace PROPERTIES PASS_REGULAR_EXPRESSION "passed"
28 FAIL_REGULAR_EXPRESSION "failed"
29 DEPENDS "setup")
30 add_test(test_rpict
31 ${CMAKE_COMMAND} -P ${CMAKE_CURRENT_BINARY_DIR}/test_rpict.cmake)
32 set_tests_properties(test_rpict PROPERTIES PASS_REGULAR_EXPRESSION "passed"
33 FAIL_REGULAR_EXPRESSION "failed"
34 DEPENDS "setup")
35 add_test(test_getinfo
36 ${CMAKE_COMMAND} -P ${CMAKE_CURRENT_BINARY_DIR}/test_getinfo.cmake)
37 add_test(test_pcond
38 ${CMAKE_COMMAND} -P ${CMAKE_CURRENT_BINARY_DIR}/test_pcond.cmake)
39 set_tests_properties(test_pcond PROPERTIES PASS_REGULAR_EXPRESSION "passed"
40 FAIL_REGULAR_EXPRESSION "failed"
41 DEPENDS "setup")
42 if(PERL_FOUND)
43 add_test(test_falsecolor
44 ${CMAKE_COMMAND} -P ${CMAKE_CURRENT_BINARY_DIR}/test_falsecolor.cmake)
45 set_tests_properties(test_falsecolor PROPERTIES PASS_REGULAR_EXPRESSION "passed"
46 FAIL_REGULAR_EXPRESSION "failed"
47 DEPENDS "setup")
48 add_test(test_DC
49 ${CMAKE_COMMAND} -P ${CMAKE_CURRENT_BINARY_DIR}/test_DC.cmake)
50 set_tests_properties(test_DC PROPERTIES PASS_REGULAR_EXPRESSION "passed"
51 FAIL_REGULAR_EXPRESSION "failed"
52 DEPENDS "setup")
53 endif()
