root/radiance/ray/build_utils/load_plat.py
Revision 1.12 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Dec 23 15:03:59 2008 UTC (15 years, 3 months ago) by schorsch
Changes since 1.11: +6 -2 lines
Diff to previous 1.11
Revision 1.11 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Apr 24 10:28:24 2008 UTC (15 years, 11 months ago) by schorsch
Diff to previous 1.10
Revision 1.10 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Apr 21 07:31:27 2008 UTC (16 years ago) by schorsch
Changes since 1.9: +3 -1 lines
Diff to previous 1.9
Scons update for mingw.
Revision 1.9 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Jun 7 12:25:36 2006 UTC (17 years, 10 months ago) by schorsch
Changes since 1.8: +1 -2 lines
Diff to previous 1.8
Fixed the Python2.4 fix to work with older versions again.
Tue Jun 6 22:32:05 2006 UTC (17 years, 10 months ago) by schorsch
Changes since 1.7: +1 -2 lines
Diff to previous 1.7
Fixed SCons problem with Python2.4
Revision 1.7 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Sep 19 11:30:09 2005 UTC (18 years, 7 months ago) by schorsch
Changes since 1.6: +12 -12 lines
Diff to previous 1.6
Wed Sep 14 09:28:35 2005 UTC (18 years, 7 months ago) by schorsch
Diff to previous 1.5
Tue Sep 13 12:24:46 2005 UTC (18 years, 7 months ago) by schorsch
Changes since 1.4: +0 -1 lines
Diff to previous 1.4
Removed temporary debug output.
Mon Sep 12 11:32:30 2005 UTC (18 years, 7 months ago) by schorsch
Changes since 1.3: +3 -0 lines
Diff to previous 1.3
Special case testing for mingw.
Thu Oct 21 15:47:12 2004 UTC (19 years, 6 months ago) by schorsch
Changes since 1.2: +2 -1 lines
Diff to previous 1.2
SCons build simplifications.
Revision 1.2 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Oct 27 10:35:41 2003 UTC (20 years, 5 months ago) by schorsch
Changes since 1.1: +12 -9 lines
Tue Oct 21 19:27:28 2003 UTC (20 years, 6 months ago) by schorsch
Links to HEAD: (view) (download) (as text) (annotate) Links to rad4R2P1: (view) (download) (as text) (annotate)
