1 |
schorsch |
1.1 |
2 |
import os |
3 |
import sys |
4 |
import string |
5 |
import ConfigParser |
6 |
7 |
8 |
_platdir = 'platform' |
9 |
10 |
11 |
def POSIX_setup(env): |
12 |
# common stuff for all posix systems |
13 |
env['RAD_PROCESS'] = string.split('unix_process.c') |
14 |
15 |
16 |
schorsch |
1.2 |
def read_plat(env, args, fn): |
17 |
schorsch |
1.1 |
cfig = ConfigParser.ConfigParser(env.Dictionary()) |
18 |
cfig.read(fn) |
19 |
schorsch |
1.2 |
buildvars = [['CC'], # replace |
20 |
schorsch |
1.3 |
['CPPPATH', 'CPPDEFINES', 'CPPFLAGS', 'CCFLAGS', |
21 |
'LIBPATH', 'LINKFLAGS']] # append |
22 |
schorsch |
1.1 |
vars = [ |
23 |
['install', |
24 |
['RAD_BASEDIR', 'RAD_BINDIR', 'RAD_RLIBDIR', 'RAD_MANDIR'], |
25 |
26 |
['code', |
27 |
['RAD_SPEED'], |
28 |
schorsch |
1.2 |
['RAD_COMPAT', 'RAD_MEMCOMPAT', 'RAD_MATHCOMPAT', 'RAD_ARGSCOMPAT', |
29 |
'RAD_MLIB', 'RAD_PROCESS']], |
30 |
schorsch |
1.1 |
31 |
schorsch |
1.2 |
if args.get('RAD_DEBUG',0): |
32 |
vars.insert(0, ['debug'] + buildvars) |
33 |
else: vars.insert(0, ['build'] + buildvars) |
34 |
schorsch |
1.1 |
for section in vars: |
35 |
if cfig.has_section(section[0]): |
36 |
for p in section[1]: |
37 |
try: v = cfig.get(section[0], p) |
38 |
except ConfigParser.NoOptionError: continue |
39 |
env[p] = v |
40 |
#print '%s: %s' % (p, env[p]) |
41 |
for p in section[2]: |
42 |
43 |
44 |
apply(env.Append,[],{p:string.split(v)}) |
45 |
46 |
# XXX Check that basedir exists. |
47 |
for k in ['RAD_BINDIR', 'RAD_RLIBDIR', 'RAD_MANDIR']: |
48 |
if (env.has_key('RAD_BASEDIR') and env.has_key(k) |
49 |
and not os.path.isabs(env[k])): |
50 |
env[k] = os.path.join(env['RAD_BASEDIR'],env[k]) |
51 |
52 |
53 |
schorsch |
1.2 |
def load_plat(env, args, platform=None): |
54 |
schorsch |
1.1 |
if os.name == 'posix': |
55 |
POSIX_setup(env) |
56 |
if platform == None: # override |
57 |
p = sys.platform |
58 |
else: p = platform |
59 |
pl = [] |
60 |
print 'Detected platform "%s" (%s).' % (sys.platform, os.name) |
61 |
for i in [len(p), -1, -2]: |
62 |
pfn = os.path.join(_platdir, p[:i] + '_custom.cfg') |
63 |
if os.path.isfile(pfn): |
64 |
print 'Reading configuration "%s"' % pfn |
65 |
schorsch |
1.2 |
read_plat(env, args, pfn) |
66 |
schorsch |
1.1 |
return 1 |
67 |
pfn = os.path.join(_platdir, p[:i] + '.cfg') |
68 |
69 |
70 |
schorsch |
1.2 |
71 |
schorsch |
1.1 |
return 1 |
72 |
73 |
74 |
pfn = os.path.join(_platdir, 'posix.cfg') |
75 |
76 |
print 'Reading generic configuration "%s".' % pfn |
77 |
schorsch |
1.2 |
78 |
schorsch |
1.1 |
return 1 |
79 |
80 |
print 'Platform "%s/%s" not supported yet' % (os.name, sys.platform) |
81 |
sys.exit(2) |
82 |
83 |
84 |
