root/radiance/ray/build_utils/load_plat.py
Revision: 1.14
Committed: Sun Mar 6 01:13:17 2016 UTC (9 years, 1 month ago) by schorsch
Content type: text/x-python
Changes since 1.13: +6 -3 lines
1
2 import os
3 import sys
4 import platform
5 import ConfigParser
6
7
8 _platdir = 'platform'
9
10
11 def read_plat(env, args, fn):
12 envdict = env.Dictionary().copy()
13 # can't feed ConfigParser the original dict, because it also
14 # contains non-string values.
15 for k,v in envdict.items():
16 if not isinstance(v, str):
17 del envdict[k]
18 cfig = ConfigParser.ConfigParser(envdict)
19 cfig.read(fn)
20 buildvars = [['CC',
21 'TIFFINCLUDE', # where to find preinstalled tifflib headers
22 'TIFFLIB', # where to find a preinstalled tifflib library
23 ], # replace
24 ['CPPPATH', 'CPPDEFINES', 'CPPFLAGS', 'CCFLAGS',
25 'LIBPATH', 'LINKFLAGS',
26 'EZXML_CPPDEFINES', # build flags specific to ezxml.c
27 ]] # append
28 vars = [
29 ['install',
30 ['RAD_BASEDIR', 'RAD_BINDIR', 'RAD_RLIBDIR', 'RAD_MANDIR'],
31 []],
32 ['code',
33 [ # replace
34 ],
35 [ # append
36 'RAD_COMPAT', # theoretically obsolete (src/common/strcmp.c)
37 'RAD_MATHCOMPAT', # erf.c floating point error function
38 'RAD_ARGSCOMPAT', # fixargv0.c for Windows
39 'RAD_NETCOMPAT', # [win_]netproc.c for ranimate
40 'RAD_MLIB', # usually 'm', or any fastlib available
41 'RAD_SOCKETLIB', # ws_2_32 on Windows (VC links it automatically)
42 'RAD_PROCESS', # our process abstraction and win_popen()
43 'RAD_PCALLS', # more custom process abstraction
44 ]],
45 ]
46 if args.get('RAD_DEBUG',0):
47 vars.insert(0, ['debug'] + buildvars)
48 else: vars.insert(0, ['build'] + buildvars)
49 for section in vars:
50 if cfig.has_section(section[0]):
51 for p in section[1]: # single items to replace
52 try: v = cfig.get(section[0], p)
53 except ConfigParser.NoOptionError: continue
54 env[p] = v
55 #print '%s: %s' % (p, env[p])
56 for p in section[2]: # multiple items to append
57 try: v = cfig.get(section[0], p)
58 except ConfigParser.NoOptionError: continue
59 apply(env.Append,[],{p:env.Split(v)})
60 # XXX Check that basedir exists.
61 for k in ['RAD_BINDIR', 'RAD_RLIBDIR', 'RAD_MANDIR']:
62 if (env.has_key('RAD_BASEDIR') and env.has_key(k)
63 and not os.path.isabs(env[k])):
64 env[k] = os.path.join(env['RAD_BASEDIR'],env[k])
65
66
67 def load_plat(env, args, ourplat=None):
68 if ourplat == None: # override
69 p = sys.platform
70 else: p = ourplat
71 # if p == 'win32' and platform.architecture()[0] == '64bit':
72 # p = 'win64'
73 if p == 'win32' and 'gcc' in env['TOOLS']:
74 # we don't really want to know this here...
75 p = 'mingw'
76 pl = []
77 print 'Detected platform "%s" (%s).' % (sys.platform, os.name)
78 for i in [len(p), -1, -2]:
79 pfn = os.path.join(_platdir, p[:i] + '_custom.cfg')
80 if os.path.isfile(pfn):
81 print 'Reading configuration "%s"' % pfn
82 read_plat(env, args, pfn)
83 return 1
84 pfn = os.path.join(_platdir, p[:i] + '.cfg')
85 if os.path.isfile(pfn):
86 print 'Reading configuration "%s"' % pfn
87 read_plat(env, args, pfn)
88 return 1
89
90 if os.name == 'posix':
91 pfn = os.path.join(_platdir, 'posix.cfg')
92 if os.path.isfile(pfn):
93 print 'Reading generic configuration "%s".' % pfn
94 read_plat(env, args, pfn)
95 return 1
96
97 print 'Platform "%s/%s" not supported yet' % (os.name, sys.platform)
98 sys.exit(2)
99
100
101
