root/radiance/ray/build_utils/load_plat.py
Revision: 1.12
Committed: Tue Dec 23 15:03:59 2008 UTC (16 years, 3 months ago) by schorsch
Content type: text/x-python
CVS Tags: rad4R2P2, rad5R0, rad4R2, rad4R1, rad4R0, rad4R2P1
Changes since 1.11: +6 -2 lines
1
2 import os
3 import sys
4 import ConfigParser
5
6
7 _platdir = 'platform'
8
9
10 def read_plat(env, args, fn):
11 cfig = ConfigParser.ConfigParser(env.Dictionary())
12 cfig.read(fn)
13 buildvars = [['CC',
14 'TIFFINCLUDE', # where to find preinstalled tifflib headers
15 'TIFFLIB', # where to find a preinstalled tifflib library
16 ], # replace
17 ['CPPPATH', 'CPPDEFINES', 'CPPFLAGS', 'CCFLAGS',
18 'LIBPATH', 'LINKFLAGS',
19 'EZXML_CPPDEFINES', # build flags specific to ezxml.c
20 ]] # append
21 vars = [
22 ['install',
23 ['RAD_BASEDIR', 'RAD_BINDIR', 'RAD_RLIBDIR', 'RAD_MANDIR'],
24 []],
25 ['code',
26 [ # replace
27 ],
28 [ # append
29 'RAD_COMPAT', # theoretically obsolete (src/common/strcmp.c)
30 'RAD_MATHCOMPAT', # erf.c floating point error function
31 'RAD_ARGSCOMPAT', # fixargv0.c for Windows
32 'RAD_NETCOMPAT', # [win_]netproc.c for ranimate
33 'RAD_MLIB', # usually 'm', or any fastlib available
34 'RAD_SOCKETLIB', # ws_2_32 on Windows (VC links it automatically)
35 'RAD_PROCESS', # our process abstraction and win_popen()
36 'RAD_PCALLS', # more custom process abstraction
37 ]],
38 ]
39 if args.get('RAD_DEBUG',0):
40 vars.insert(0, ['debug'] + buildvars)
41 else: vars.insert(0, ['build'] + buildvars)
42 for section in vars:
43 if cfig.has_section(section[0]):
44 for p in section[1]: # single items to replace
45 try: v = cfig.get(section[0], p)
46 except ConfigParser.NoOptionError: continue
47 env[p] = v
48 #print '%s: %s' % (p, env[p])
49 for p in section[2]: # multiple items to append
50 try: v = cfig.get(section[0], p)
51 except ConfigParser.NoOptionError: continue
52 apply(env.Append,[],{p:env.Split(v)})
53 # XXX Check that basedir exists.
54 for k in ['RAD_BINDIR', 'RAD_RLIBDIR', 'RAD_MANDIR']:
55 if (env.has_key('RAD_BASEDIR') and env.has_key(k)
56 and not os.path.isabs(env[k])):
57 env[k] = os.path.join(env['RAD_BASEDIR'],env[k])
58
59
60 def load_plat(env, args, platform=None):
61 if platform == None: # override
62 p = sys.platform
63 else: p = platform
64 if p == 'win32' and 'gcc' in env['TOOLS']:
65 # we don't really want to know this here...
66 p = 'mingw'
67 pl = []
68 print 'Detected platform "%s" (%s).' % (sys.platform, os.name)
69 for i in [len(p), -1, -2]:
70 pfn = os.path.join(_platdir, p[:i] + '_custom.cfg')
71 if os.path.isfile(pfn):
72 print 'Reading configuration "%s"' % pfn
73 read_plat(env, args, pfn)
74 return 1
75 pfn = os.path.join(_platdir, p[:i] + '.cfg')
76 if os.path.isfile(pfn):
77 print 'Reading configuration "%s"' % pfn
78 read_plat(env, args, pfn)
79 return 1
80
81 if os.name == 'posix':
82 pfn = os.path.join(_platdir, 'posix.cfg')
83 if os.path.isfile(pfn):
84 print 'Reading generic configuration "%s".' % pfn
85 read_plat(env, args, pfn)
86 return 1
87
88 print 'Platform "%s/%s" not supported yet' % (os.name, sys.platform)
89 sys.exit(2)
90
91
92
