root/radiance/ray/build_utils/load_plat.py
Revision: 1.1
Committed: Tue Oct 21 19:27:28 2003 UTC (21 years, 6 months ago) by schorsch
Content type: text/x-python
1
2 import os
3 import sys
4 import string
5 import ConfigParser
6
7
8 _platdir = 'platform'
9
10
11 def POSIX_setup(env):
12 # common stuff for all posix systems
13 env['RAD_PROCESS'] = string.split('unix_process.c')
14
15
16 def read_plat(env, fn):
17 cfig = ConfigParser.ConfigParser(env.Dictionary())
18 cfig.read(fn)
19 vars = [
20 ['build',
21 ['CC'], # replace
22 ['CPPFLAGS', 'CCFLAGS', 'CPPPATH', 'LIBPATH']], # append
23 ['install',
24 ['RAD_BASEDIR', 'RAD_BINDIR', 'RAD_RLIBDIR', 'RAD_MANDIR'],
25 []],
26 ['code',
27 ['RAD_SPEED'],
28 ['RAD_COMPAT', 'RAD_MLIB', 'RAD_PROCESS']],
29 ]
30 for section in vars:
31 if cfig.has_section(section[0]):
32 for p in section[1]:
33 try: v = cfig.get(section[0], p)
34 except ConfigParser.NoOptionError: continue
35 env[p] = v
36 #print '%s: %s' % (p, env[p])
37 for p in section[2]:
38 try: v = cfig.get(section[0], p)
39 except ConfigParser.NoOptionError: continue
40 apply(env.Append,[],{p:string.split(v)})
41 #print '%s: %s' % (p, env[p])
42 # XXX Check that basedir exists.
43 for k in ['RAD_BINDIR', 'RAD_RLIBDIR', 'RAD_MANDIR']:
44 if (env.has_key('RAD_BASEDIR') and env.has_key(k)
45 and not os.path.isabs(env[k])):
46 env[k] = os.path.join(env['RAD_BASEDIR'],env[k])
47
48
49 def load_plat(env, platform=None):
50 if os.name == 'posix':
51 POSIX_setup(env)
52 if platform == None: # override
53 p = sys.platform
54 else: p = platform
55 pl = []
56 print 'Detected platform "%s" (%s).' % (sys.platform, os.name)
57 for i in [len(p), -1, -2]:
58 pfn = os.path.join(_platdir, p[:i] + '_custom.cfg')
59 if os.path.isfile(pfn):
60 print 'Reading configuration "%s"' % pfn
61 read_plat(env, pfn)
62 return 1
63 pfn = os.path.join(_platdir, p[:i] + '.cfg')
64 if os.path.isfile(pfn):
65 print 'Reading configuration "%s"' % pfn
66 read_plat(env, pfn)
67 return 1
68
69 if os.name == 'posix':
70 pfn = os.path.join(_platdir, 'posix.cfg')
71 if os.path.isfile(pfn):
72 print 'Reading generic configuration "%s".' % pfn
73 read_plat(env, pfn)
74 return 1
75
76 print 'Platform "%s/%s" not supported yet' % (os.name, sys.platform)
77 sys.exit(2)
78
79
80
