--- ray/build_utils/load_plat.py 2016/03/10 01:49:56 1.15 +++ ray/build_utils/load_plat.py 2018/01/08 13:38:37 1.19 @@ -1,28 +1,31 @@ +from __future__ import division, print_function, unicode_literals import os import sys +import re import platform -import ConfigParser +try: import configparser # Py3 +except ImportError: + import ConfigParser as configparser # Py2 - _platdir = 'platform' -def read_plat(env, args, fn): +def read_plat(env, fn): envdict = env.Dictionary().copy() - # can't feed ConfigParser the original dict, because it also + # can't feed configparser the original dict, because it also # contains non-string values. - for k,v in envdict.items(): + for k,v in list(envdict.items()): # make a list, so we can change the dict. if not isinstance(v, str): del envdict[k] - cfig = ConfigParser.ConfigParser(envdict) + cfig = configparser.ConfigParser(envdict) cfig.read(fn) buildvars = [['CC', 'TIFFINCLUDE', # where to find preinstalled tifflib headers 'TIFFLIB', # where to find a preinstalled tifflib library ], # replace ['CPPPATH', 'CPPDEFINES', 'CPPFLAGS', 'CCFLAGS', - 'LIBPATH', 'LINKFLAGS', + 'LIBS', 'LIBPATH', 'LINKFLAGS', 'EZXML_CPPDEFINES', # build flags specific to ezxml.c ]] # append vars = [ @@ -43,62 +46,103 @@ def read_plat(env, args, fn): 'RAD_PCALLS', # more custom process abstraction ]], ] - if args.get('RAD_DEBUG',0): + if env.get('RAD_DEBUG',0) not in(0,'0','','n','no','false',None): vars.insert(0, ['debug'] + buildvars) - else: vars.insert(0, ['build'] + buildvars) + print('Processing DEBUG version') + else: + vars.insert(0, ['build'] + buildvars) + print('Processing RELEASE version') for section in vars: if cfig.has_section(section[0]): for p in section[1]: # single items to replace try: v = cfig.get(section[0], p) - except ConfigParser.NoOptionError: continue - if section[0] == 'install' and '{' in v: - try: - vv = v.format(**os.environ) - except KeyError: vv = v - else: v = vv + except configparser.NoOptionError: continue + if section[0] in ('install','build','debug'): + if '{' in v: + v = subst_sysenvvars(v, env) env[p] = v #print('%s: %s' % (p, env[p])) for p in section[2]: # multiple items to append - try: v = cfig.get(section[0], p) - except ConfigParser.NoOptionError: continue - apply(env.Append,[],{p:env.Split(v)}) - # XXX Check that basedir exists. + try: + v = cfig.get(section[0], p) + if section[0] in ('build','debug') and '{' in v: + v = subst_sconsvars(v, env) + #print('%s: %s - %s' % (section[0], p, v)) + except configparser.NoOptionError: continue + env.Append(*[], **{p:env.Split(v)}) + #apply(env.Append,[],{p:env.Split(v)}) + +def combine_instpaths(env): + # XXX Check that basedir exists? for k in ['RAD_BINDIR', 'RAD_RLIBDIR', 'RAD_MANDIR']: if (env.has_key('RAD_BASEDIR') and env.has_key(k) and not os.path.isabs(env[k])): env[k] = os.path.join(env['RAD_BASEDIR'],env[k]) -def load_plat(env, args, arch=None): - cfgname = 'posix' + +def subst_sysenvvars(s, env): + try: return s.format(**os.environ) + except KeyError: return s + +def subst_sconsvars(s, env, + pat=re.compile('({[a-z0-9_]+})', re.I)): + l = pat.split(s) + nl = [] + for ss in l: + if ss.startswith('{') and ss.endswith('}'): + v = env.get(ss[1:-1]) + #print(ss, v) + if v: + if v.startswith('#'): + v = str(env.Dir(v)) + nl.append(v) + continue + nl.append(ss) + return ''.join(nl) + + +def identify_plat(env): memmodel, binformat = platform.architecture() platsys = platform.system() - print 'Detected platform "%s" (%s).' % (platsys, memmodel) + print('Detected platform "%s" (%s).' % (platsys, memmodel)) cfgname = platsys + '_' + memmodel[:2] + env['CFG_PLATSYS'] = platsys + env['CFG_MEMMODEL'] = memmodel[:2] + env['CFG_PATHFILE'] = os.path.join('#scbuild', cfgname, 'install_paths.py') + env['CFG_OPTFILE'] = os.path.join('#scbuild', cfgname, 'build_opts.py') + + +def load_plat(env, testenv): + platsys = testenv['CFG_PLATSYS'] + memmodel = testenv['CFG_MEMMODEL'] + cfgname = platsys + '_' + memmodel[:2] + env['RAD_BUILDBIN'] = os.path.join('#scbuild', cfgname, 'bin') - env['RAD_BUILDLIB'] = os.path.join('#scbuild', cfgname, 'lib') - env['RAD_BUILDOBJ'] = os.path.join('#scbuild', cfgname, 'obj') + env['RAD_BUILDLIB'] = os.path.join('#scbuild', cfgname, 'lib') + env['RAD_BUILDOBJ'] = os.path.join('#scbuild', cfgname, 'obj') - pfn = os.path.join(_platdir, cfgname + '_custom.cfg') - if os.path.isfile(pfn): - print 'Reading configuration "%s"' % pfn - read_plat(env, args, pfn) + cust_pfn = os.path.join(_platdir, cfgname + '_custom.cfg') + if os.path.isfile(cust_pfn): + print('Reading configuration "%s"' % cust_pfn) + read_plat(env, cust_pfn) return 1 pfn = os.path.join(_platdir, cfgname + '.cfg') if os.path.isfile(pfn): - print 'Reading configuration "%s"' % pfn - read_plat(env, args, pfn) + print('Reading configuration "%s"' % pfn) + read_plat(env, pfn) return 1 if os.name == 'posix': pfn = os.path.join(_platdir, 'posix.cfg') if os.path.isfile(pfn): - print 'Reading generic configuration "%s".' % pfn - read_plat(env, args, pfn) + print('No platform specific configuration found.\n') + print('Reading generic configuration "%s".' % pfn) + read_plat(env, pfn) return 1 - print 'Platform "%s", system "%s" not supported yet' % (os.name, sys.platform) + print('Platform "%s", system "%s" not supported yet' + % (os.name, sys.platform)) sys.exit(2) - - +# vi: set ts=4 sw=4 :
