--- ray/build_utils/load_plat.py 2005/09/13 12:24:46 1.5 +++ ray/build_utils/load_plat.py 2008/04/24 10:28:24 1.11 @@ -1,48 +1,51 @@ import os import sys -import string import ConfigParser _platdir = 'platform' -def POSIX_setup(env): - # common stuff for all posix systems - env['RAD_PROCESS'] = string.split('unix_process.c') - - def read_plat(env, args, fn): cfig = ConfigParser.ConfigParser(env.Dictionary()) cfig.read(fn) buildvars = [['CC'], # replace ['CPPPATH', 'CPPDEFINES', 'CPPFLAGS', 'CCFLAGS', - 'LIBPATH', 'LINKFLAGS']] # append + 'LIBPATH', 'LINKFLAGS', + 'EZXML_CPPDEFINES', # build flags specific to ezxml.c + ]] # append vars = [ ['install', ['RAD_BASEDIR', 'RAD_BINDIR', 'RAD_RLIBDIR', 'RAD_MANDIR'], []], ['code', - ['RAD_SPEED'], - ['RAD_COMPAT', 'RAD_MEMCOMPAT', 'RAD_MATHCOMPAT', 'RAD_ARGSCOMPAT', - 'RAD_MLIB', 'RAD_PROCESS']], + [], # replace + [ # append + 'RAD_COMPAT', # theoretically obsolete (src/common/strcmp.c) + 'RAD_MATHCOMPAT', # erf.c floating point error function + 'RAD_ARGSCOMPAT', # fixargv0.c for Windows + 'RAD_NETCOMPAT', # [win_]netproc.c for ranimate + 'RAD_MLIB', # usually 'm', or any fastlib available + 'RAD_SOCKETLIB', # ws_2_32 on Windows (VC links it automatically) + 'RAD_PROCESS', # our process abstraction and win_popen() + 'RAD_PCALLS', # more custom process abstraction + ]], ] if args.get('RAD_DEBUG',0): vars.insert(0, ['debug'] + buildvars) else: vars.insert(0, ['build'] + buildvars) for section in vars: if cfig.has_section(section[0]): - for p in section[1]: + for p in section[1]: # single items to replace try: v = cfig.get(section[0], p) except ConfigParser.NoOptionError: continue env[p] = v #print '%s: %s' % (p, env[p]) - for p in section[2]: + for p in section[2]: # multiple items to append try: v = cfig.get(section[0], p) except ConfigParser.NoOptionError: continue - apply(env.Append,[],{p:string.split(v)}) - #print '%s: %s' % (p, env[p]) + apply(env.Append,[],{p:env.Split(v)}) # XXX Check that basedir exists. for k in ['RAD_BINDIR', 'RAD_RLIBDIR', 'RAD_MANDIR']: if (env.has_key('RAD_BASEDIR') and env.has_key(k) @@ -51,12 +54,11 @@ def read_plat(env, args, fn): def load_plat(env, args, platform=None): - if os.name == 'posix': - POSIX_setup(env) if platform == None: # override p = sys.platform else: p = platform if p == 'win32' and 'gcc' in env['TOOLS']: + # we don't really want to know this here... p = 'mingw' pl = [] print 'Detected platform "%s" (%s).' % (sys.platform, os.name)
