SCons Option to build Pmap with OOC data on unix
Build with VC2013 until text pipe bug is fixed; prepare for pyinstaller on scripts
Refactoring of test suite, use independently of SCons and with Py2.7 or 3.x.
Tifflib support and sleeker binaries on Windows
SCons build system learns about platform architecture
update SCons
Scons update for mingw.
Fixed the Python2.4 fix to work with older versions again.
Fixed SCons problem with Python2.4
Removed temporary debug output.
Special case testing for mingw.
SCons build simplifications.
