root/radiance/ray/build_utils/load_plat.py
Revision 1.9 - (view) (download) (as text) (annotate) - [selected]
Wed Jun 7 12:25:36 2006 UTC (18 years, 10 months ago) by schorsch
Changes since 1.8: +1 -2 lines
Diff to previous 1.8
Fixed the Python2.4 fix to work with older versions again.
Tue Jun 6 22:32:05 2006 UTC (18 years, 10 months ago) by schorsch
Changes since 1.7: +1 -2 lines
Diff to previous 1.7 , to selected 1.9
Fixed SCons problem with Python2.4
Revision 1.7 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Sep 19 11:30:09 2005 UTC (19 years, 7 months ago) by schorsch
Changes since 1.6: +12 -12 lines
Diff to previous 1.6 , to selected 1.9
Wed Sep 14 09:28:35 2005 UTC (19 years, 7 months ago) by schorsch
Diff to previous 1.5 , to selected 1.9
Tue Sep 13 12:24:46 2005 UTC (19 years, 7 months ago) by schorsch
Changes since 1.4: +0 -1 lines
Diff to previous 1.4 , to selected 1.9
Removed temporary debug output.
Mon Sep 12 11:32:30 2005 UTC (19 years, 7 months ago) by schorsch
Changes since 1.3: +3 -0 lines
Diff to previous 1.3 , to selected 1.9
Special case testing for mingw.
Thu Oct 21 15:47:12 2004 UTC (20 years, 6 months ago) by schorsch
Changes since 1.2: +2 -1 lines
Diff to previous 1.2 , to selected 1.9
SCons build simplifications.
Revision 1.2 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Oct 27 10:35:41 2003 UTC (21 years, 6 months ago) by schorsch
Changes since 1.1: +12 -9 lines
Diff to previous 1.1 , to selected 1.9
Tue Oct 21 19:27:28 2003 UTC (21 years, 6 months ago) by schorsch
Diff to selected 1.9
Links to HEAD: (view) (download) (as text) (annotate) Links to rad3R8: (view) (download) (as text) (annotate)
