root/radiance/ray/build_utils/load_plat.py
Revision 1.20 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Jan 9 00:08:57 2018 UTC (7 years, 6 months ago) by schorsch
Diff to previous 1.19 , to selected 1.4
SCons Option to build Pmap with OOC data on unix
Revision 1.19 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Jan 8 13:38:37 2018 UTC (7 years, 6 months ago) by schorsch
Changes since 1.18: +35 -19 lines
Diff to previous 1.18 , to selected 1.4
Revision 1.18 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Apr 19 21:21:23 2016 UTC (9 years, 2 months ago) by schorsch
Changes since 1.17: +6 -5 lines
Diff to previous 1.17 , to selected 1.4
Build with VC2013 until text pipe bug is fixed; prepare for pyinstaller on scripts
Revision 1.17 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Mar 28 17:48:43 2016 UTC (9 years, 3 months ago) by schorsch
Diff to previous 1.16 , to selected 1.4
Refactoring of test suite, use independently of SCons and with Py2.7 or 3.x.
Revision 1.16 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Mar 10 17:36:18 2016 UTC (9 years, 4 months ago) by schorsch
Changes since 1.15: +44 -17 lines
Diff to previous 1.15 , to selected 1.4
Tifflib support and sleeker binaries on Windows
Revision 1.15 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Mar 10 01:49:56 2016 UTC (9 years, 4 months ago) by schorsch
Changes since 1.14: +28 -25 lines
Diff to previous 1.14 , to selected 1.4
SCons build system learns about platform architecture
Revision 1.14 - (view) (download) (as text) (annotate) - [select for diffs]
Sun Mar 6 01:13:17 2016 UTC (9 years, 4 months ago) by schorsch
Changes since 1.13: +6 -3 lines
Diff to previous 1.13 , to selected 1.4
Revision 1.13 - (view) (download) (as text) (annotate) - [select for diffs]
Sat Mar 5 00:40:25 2016 UTC (9 years, 4 months ago) by schorsch
Changes since 1.12: +7 -1 lines
Diff to previous 1.12 , to selected 1.4
update SCons
Revision 1.12 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Dec 23 15:03:59 2008 UTC (16 years, 6 months ago) by schorsch
Changes since 1.11: +6 -2 lines
Diff to previous 1.11 , to selected 1.4
Revision 1.11 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Apr 24 10:28:24 2008 UTC (17 years, 2 months ago) by schorsch
Diff to previous 1.10 , to selected 1.4
Revision 1.10 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Apr 21 07:31:27 2008 UTC (17 years, 2 months ago) by schorsch
Changes since 1.9: +3 -1 lines
Diff to previous 1.9 , to selected 1.4
Scons update for mingw.
Revision 1.9 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Jun 7 12:25:36 2006 UTC (19 years, 1 month ago) by schorsch
Changes since 1.8: +1 -2 lines
Diff to previous 1.8 , to selected 1.4
Fixed the Python2.4 fix to work with older versions again.
Tue Jun 6 22:32:05 2006 UTC (19 years, 1 month ago) by schorsch
Changes since 1.7: +1 -2 lines
Diff to previous 1.7 , to selected 1.4
Fixed SCons problem with Python2.4
Revision 1.7 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Sep 19 11:30:09 2005 UTC (19 years, 10 months ago) by schorsch
Changes since 1.6: +12 -12 lines
Diff to previous 1.6 , to selected 1.4
Wed Sep 14 09:28:35 2005 UTC (19 years, 10 months ago) by schorsch
Diff to previous 1.5 , to selected 1.4
Tue Sep 13 12:24:46 2005 UTC (19 years, 10 months ago) by schorsch
Changes since 1.4: +0 -1 lines
Diff to previous 1.4
Removed temporary debug output.
Revision 1.4 - (view) (download) (as text) (annotate) - [selected]
Mon Sep 12 11:32:30 2005 UTC (19 years, 10 months ago) by schorsch
Changes since 1.3: +3 -0 lines
Diff to previous 1.3
Special case testing for mingw.
Thu Oct 21 15:47:12 2004 UTC (20 years, 8 months ago) by schorsch
Changes since 1.2: +2 -1 lines
Diff to previous 1.2 , to selected 1.4
SCons build simplifications.
Revision 1.2 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Oct 27 10:35:41 2003 UTC (21 years, 8 months ago) by schorsch
Changes since 1.1: +12 -9 lines
Diff to previous 1.1 , to selected 1.4
Tue Oct 21 19:27:28 2003 UTC (21 years, 8 months ago) by schorsch
Diff to selected 1.4
Links to HEAD: (view) (download) (as text) (annotate) Links to MAIN: (view) (download) (as text) (annotate)
