--- ray/build_utils/load_plat.py 2016/04/19 21:21:23 1.18 +++ ray/build_utils/load_plat.py 2018/01/08 13:38:37 1.19 @@ -1,23 +1,24 @@ -from __future__ import print_function +from __future__ import division, print_function, unicode_literals import os import sys import re import platform -import ConfigParser +try: import configparser # Py3 +except ImportError: + import ConfigParser as configparser # Py2 - _platdir = 'platform' def read_plat(env, fn): envdict = env.Dictionary().copy() - # can't feed ConfigParser the original dict, because it also + # can't feed configparser the original dict, because it also # contains non-string values. - for k,v in envdict.items(): + for k,v in list(envdict.items()): # make a list, so we can change the dict. if not isinstance(v, str): del envdict[k] - cfig = ConfigParser.ConfigParser(envdict) + cfig = configparser.ConfigParser(envdict) cfig.read(fn) buildvars = [['CC', 'TIFFINCLUDE', # where to find preinstalled tifflib headers @@ -55,9 +56,10 @@ def read_plat(env, fn): if cfig.has_section(section[0]): for p in section[1]: # single items to replace try: v = cfig.get(section[0], p) - except ConfigParser.NoOptionError: continue - if section[0] in ('install','build','debug') and '{' in v: - v = subst_osenvvars(v) + except configparser.NoOptionError: continue + if section[0] in ('install','build','debug'): + if '{' in v: + v = subst_sysenvvars(v, env) env[p] = v #print('%s: %s' % (p, env[p])) for p in section[2]: # multiple items to append @@ -66,15 +68,20 @@ def read_plat(env, fn): if section[0] in ('build','debug') and '{' in v: v = subst_sconsvars(v, env) #print('%s: %s - %s' % (section[0], p, v)) - except ConfigParser.NoOptionError: continue - apply(env.Append,[],{p:env.Split(v)}) - # XXX Check that basedir exists. + except configparser.NoOptionError: continue + env.Append(*[], **{p:env.Split(v)}) + #apply(env.Append,[],{p:env.Split(v)}) + +def combine_instpaths(env): + # XXX Check that basedir exists? for k in ['RAD_BINDIR', 'RAD_RLIBDIR', 'RAD_MANDIR']: if (env.has_key('RAD_BASEDIR') and env.has_key(k) and not os.path.isabs(env[k])): env[k] = os.path.join(env['RAD_BASEDIR'],env[k]) -def subst_osenvvars(s): + + +def subst_sysenvvars(s, env): try: return s.format(**os.environ) except KeyError: return s @@ -94,16 +101,26 @@ def subst_sconsvars(s, env, nl.append(ss) return ''.join(nl) -def load_plat(env): + +def identify_plat(env): memmodel, binformat = platform.architecture() - # XXX env['TARGET_ARCH'] --> memmodel platsys = platform.system() print('Detected platform "%s" (%s).' % (platsys, memmodel)) cfgname = platsys + '_' + memmodel[:2] + env['CFG_PLATSYS'] = platsys + env['CFG_MEMMODEL'] = memmodel[:2] + env['CFG_PATHFILE'] = os.path.join('#scbuild', cfgname, 'install_paths.py') + env['CFG_OPTFILE'] = os.path.join('#scbuild', cfgname, 'build_opts.py') + +def load_plat(env, testenv): + platsys = testenv['CFG_PLATSYS'] + memmodel = testenv['CFG_MEMMODEL'] + cfgname = platsys + '_' + memmodel[:2] + env['RAD_BUILDBIN'] = os.path.join('#scbuild', cfgname, 'bin') - env['RAD_BUILDLIB'] = os.path.join('#scbuild', cfgname, 'lib') - env['RAD_BUILDOBJ'] = os.path.join('#scbuild', cfgname, 'obj') + env['RAD_BUILDLIB'] = os.path.join('#scbuild', cfgname, 'lib') + env['RAD_BUILDOBJ'] = os.path.join('#scbuild', cfgname, 'obj') cust_pfn = os.path.join(_platdir, cfgname + '_custom.cfg') if os.path.isfile(cust_pfn): @@ -128,5 +145,4 @@ def load_plat(env): % (os.name, sys.platform)) sys.exit(2) - - +# vi: set ts=4 sw=4 :
