root/Development/ray/build_utils/load_plat.py
Revision: 1.20
Committed: Tue Jan 9 00:08:57 2018 UTC (7 years, 11 months ago) by schorsch
Content type: text/x-python
CVS Tags: rad6R0, rad5R4, rad5R3, rad5R2, HEAD
SCons Option to build Pmap with OOC data on unix
1 from __future__ import division, print_function, unicode_literals
2
3 import os
4 import sys
5 import re
6 import platform
7 try: import configparser # Py3
8 except ImportError:
9 import ConfigParser as configparser # Py2
10
11 _platdir = 'platform'
12
13
14 def read_plat(env, fn):
15 envdict = env.Dictionary().copy()
16 # can't feed configparser the original dict, because it also
17 # contains non-string values.
18 for k,v in list(envdict.items()): # make a list, so we can change the dict.
19 if not isinstance(v, str):
20 del envdict[k]
21 cfig = configparser.ConfigParser(envdict)
22 cfig.read(fn)
23 buildvars = [['CC',
24 'TIFFINCLUDE', # where to find preinstalled tifflib headers
25 'TIFFLIB', # where to find a preinstalled tifflib library
26 ], # replace
27 ['CPPPATH', 'CPPDEFINES', 'CPPFLAGS', 'CCFLAGS',
28 'LIBS', 'LIBPATH', 'LINKFLAGS',
29 'EZXML_CPPDEFINES', # build flags specific to ezxml.c
30 ]] # append
31 vars = [
32 ['install',
33 ['RAD_BASEDIR', 'RAD_BINDIR', 'RAD_RLIBDIR', 'RAD_MANDIR'],
34 []],
35 ['code',
36 [ # replace
37 ],
38 [ # append
39 'RAD_COMPAT', # theoretically obsolete (src/common/strcmp.c)
40 'RAD_MATHCOMPAT', # erf.c floating point error function
41 'RAD_ARGSCOMPAT', # fixargv0.c for Windows
42 'RAD_NETCOMPAT', # [win_]netproc.c for ranimate
43 'RAD_MLIB', # usually 'm', or any fastlib available
44 'RAD_SOCKETLIB', # ws_2_32 on Windows (VC links it automatically)
45 'RAD_PROCESS', # our process abstraction and win_popen()
46 'RAD_PCALLS', # more custom process abstraction
47 ]],
48 ]
49 if env.get('RAD_DEBUG',0) not in(0,'0','','n','no','false',False,None):
50 vars.insert(0, ['debug'] + buildvars)
51 print('Processing DEBUG version')
52 else:
53 vars.insert(0, ['build'] + buildvars)
54 print('Processing RELEASE version')
55 for section in vars:
56 if cfig.has_section(section[0]):
57 for p in section[1]: # single items to replace
58 try: v = cfig.get(section[0], p)
59 except configparser.NoOptionError: continue
60 if section[0] in ('install','build','debug'):
61 if '{' in v:
62 v = subst_sysenvvars(v, env)
63 env[p] = v
64 #print('%s: %s' % (p, env[p]))
65 for p in section[2]: # multiple items to append
66 try:
67 v = cfig.get(section[0], p)
68 if section[0] in ('build','debug') and '{' in v:
69 v = subst_sconsvars(v, env)
70 #print('%s: %s - %s' % (section[0], p, v))
71 except configparser.NoOptionError: continue
72 env.Append(*[], **{p:env.Split(v)})
73 #apply(env.Append,[],{p:env.Split(v)})
74
75 def combine_instpaths(env):
76 # XXX Check that basedir exists?
77 for k in ['RAD_BINDIR', 'RAD_RLIBDIR', 'RAD_MANDIR']:
78 if (env.has_key('RAD_BASEDIR') and env.has_key(k)
79 and not os.path.isabs(env[k])):
80 env[k] = os.path.join(env['RAD_BASEDIR'],env[k])
81
82
83
84 def subst_sysenvvars(s, env):
85 try: return s.format(**os.environ)
86 except KeyError: return s
87
88 def subst_sconsvars(s, env,
89 pat=re.compile('({[a-z0-9_]+})', re.I)):
90 l = pat.split(s)
91 nl = []
92 for ss in l:
93 if ss.startswith('{') and ss.endswith('}'):
94 v = env.get(ss[1:-1])
95 #print(ss, v)
96 if v:
97 if v.startswith('#'):
98 v = str(env.Dir(v))
99 nl.append(v)
100 continue
101 nl.append(ss)
102 return ''.join(nl)
103
104
105 def identify_plat(env):
106 memmodel, binformat = platform.architecture()
107 platsys = platform.system()
108 print('Detected platform "%s" (%s).' % (platsys, memmodel))
109 cfgname = platsys + '_' + memmodel[:2]
110 env['CFG_PLATSYS'] = platsys
111 env['CFG_MEMMODEL'] = memmodel[:2]
112 env['CFG_PATHFILE'] = os.path.join('#scbuild', cfgname, 'install_paths.py')
113 env['CFG_OPTFILE'] = os.path.join('#scbuild', cfgname, 'build_opts.py')
114
115
116 def load_plat(env, testenv):
117 platsys = testenv['CFG_PLATSYS']
118 memmodel = testenv['CFG_MEMMODEL']
119 cfgname = platsys + '_' + memmodel[:2]
120
121 env['RAD_BUILDBIN'] = os.path.join('#scbuild', cfgname, 'bin')
122 env['RAD_BUILDLIB'] = os.path.join('#scbuild', cfgname, 'lib')
123 env['RAD_BUILDOBJ'] = os.path.join('#scbuild', cfgname, 'obj')
124
125 cust_pfn = os.path.join(_platdir, cfgname + '_custom.cfg')
126 if os.path.isfile(cust_pfn):
127 print('Reading configuration "%s"' % cust_pfn)
128 read_plat(env, cust_pfn)
129 return 1
130 pfn = os.path.join(_platdir, cfgname + '.cfg')
131 if os.path.isfile(pfn):
132 print('Reading configuration "%s"' % pfn)
133 read_plat(env, pfn)
134 return 1
135
136 if os.name == 'posix':
137 pfn = os.path.join(_platdir, 'posix.cfg')
138 if os.path.isfile(pfn):
139 print('No platform specific configuration found.\n')
140 print('Reading generic configuration "%s".' % pfn)
141 read_plat(env, pfn)
142 return 1
143
144 print('Platform "%s", system "%s" not supported yet'
145 % (os.name, sys.platform))
146 sys.exit(2)
147
148 # vi: set ts=4 sw=4 :
