root/radiance/ray/build_utils/install.py
Revision: 1.6
Committed: Mon Jan 8 13:38:37 2018 UTC (7 years, 6 months ago) by schorsch
Content type: text/x-python
CVS Tags: rad5R4, rad5R2, rad5R3, rad6R0, HEAD
Changes since 1.5: +28 -13 lines
# User Rev Content
1 schorsch 1.6 from __future__ import division, print_function, unicode_literals
2 schorsch 1.1
3     import os
4 schorsch 1.6 import stat
5 schorsch 1.1
6 schorsch 1.6 def install_dir(env, instlist, sbase, tbase, subdir):
7     fulldir = os.path.join(sbase, subdir)
8 schorsch 1.1 l = os.listdir(fulldir)
9 schorsch 1.6 instdir = os.path.join(tbase, subdir)
10 schorsch 1.1 for item in l:
11 schorsch 1.6 if (item[0] == '.'
12     or item[-1] in '%~'
13     or item == 'CVS'
14     or item.lower().startswith('cmake')):
15 schorsch 1.1 continue
16     elif os.path.isdir(os.path.join(fulldir, item)):
17 schorsch 1.6 install_dir(env, instlist, sbase, tbase, os.path.join(subdir, item))
18 schorsch 1.1 else:
19     inst = env.Install(instdir, os.path.join(fulldir, item))
20 schorsch 1.6 instlist.append(inst)
21 schorsch 1.1
22     def install_rlibfiles(env):
23     buildrlib = env['RAD_BUILDRLIB']
24     if buildrlib[0] == '#':
25     buildrlib = buildrlib[1:]
26     sbase = os.path.join(os.getcwd(), buildrlib)
27 schorsch 1.6 instlist = []
28     install_dir(env, instlist, sbase, env['RAD_RLIBDIR'], '')
29     env.Append(RAD_RLIBINSTALL=instlist)
30 schorsch 1.1
31
32     def install_manfiles(env):
33     buildman = env['RAD_BUILDMAN']
34     if buildman[0] == '#':
35     buildman = buildman[1:]
36     sbase = os.path.join(os.getcwd(), buildman)
37     il = []
38     install_dir(env, il, sbase, env['RAD_MANDIR'], '')
39     env.Append(RAD_MANINSTALL=il)
40
41
42 schorsch 1.3 def install_script(target, source, env):
43 schorsch 1.6 #for t,s in map(None,target,source):
44     for t,s in zip(target, source):
45 schorsch 1.2 sf = open(str(s), 'r')
46     tf = open(str(t), 'w')
47     tf.write(sf.read())
48 schorsch 1.6 os.chmod(str(t),
49     stat.S_IRUSR | stat.S_IWUSR | stat.S_IXUSR |
50     stat.S_IRGRP | stat.S_IWGRP |
51     stat.S_IROTH | stat.S_IWOTH)
52 schorsch 1.2
53 schorsch 1.4 def install_tclscript(target, source, env):
54     # XXX posix only for the moment
55 schorsch 1.6 #for t,s in map(None, target,source):
56     for t,s in zip(target, source):
57 schorsch 1.4 bindir = os.path.split(t.get_abspath())[0]
58     instdir = os.path.split(bindir)[0]
59     tcllibdir = os.path.join(instdir, 'lib', 'tcl')
60     sf = open(str(s), 'r')
61     tf = open(str(t), 'w')
62     # as recommended in the wish manpage
63     tf.write('''#!/bin/sh\n''')
64     for line in sf.readlines():
65     if line.startswith('#!'):
66     tf.write('### ' + line)
67     if line.startswith('set radlib'):
68     # XXX this should really be handled by an envvar.
69     line = 'set radlib %s\n' % tcllibdir
70     tf.write(line)
71 schorsch 1.6 os.chmod(str(t),
72     stat.S_IRUSR | stat.S_IWUSR | stat.S_IXUSR |
73     stat.S_IRGRP | stat.S_IWGRP |
74     stat.S_IROTH | stat.S_IWOTH)
75 schorsch 1.5
76     def build_with_pyinstaller(targets, sources, env):
77     workpath = env.Dir('$RAD_BUILDOBJ', 'pybuild') # --workpath @
78     specpath = workpath # --specpath @
79     # -F # one-file
80     # --noconsole
81     pass
82 schorsch 1.6
83     # vi: set ts=4 sw=4 :
