root/radiance/ray/build_utils/install.py
Mon Jan 8 13:38:37 2018 UTC (7 years, 3 months ago) by schorsch
Changes since 1.5: +28 -13 lines
Diff to previous 1.5
Tue Apr 19 21:21:23 2016 UTC (9 years ago) by schorsch
Changes since 1.4: +7 -0 lines
Diff to previous 1.4
Build with VC2013 until text pipe bug is fixed; prepare for pyinstaller on scripts
Sat Mar 5 13:24:58 2016 UTC (9 years, 1 month ago) by schorsch
Changes since 1.3: +18 -0 lines
Diff to previous 1.3
Sat Mar 5 00:40:25 2016 UTC (9 years, 1 month ago) by schorsch
Diff to previous 1.2
update SCons
Revision 1.2 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Oct 21 15:47:12 2004 UTC (20 years, 6 months ago) by schorsch
Changes since 1.1: +7 -0 lines
Diff to previous 1.1
SCons build simplifications.
Tue Oct 21 19:27:28 2003 UTC (21 years, 6 months ago) by schorsch
Links to HEAD: (view) (download) (as text) (annotate) Links to rad5R4: (view) (download) (as text) (annotate)
