root/radiance/ray/build_utils/find_libs.py
Revision: 1.6
Committed: Thu May 27 19:32:12 2010 UTC (15 years ago) by greg
Content type: text/x-python
CVS Tags: rad4R2P2, rad5R0, rad4R2, rad4R1, rad4R2P1
# User Rev Content
1 schorsch 1.1 import os
2
3     from SCons.SConf import SConf # aka Configure
4
5 schorsch 1.5 def find_radlib(env):
6 greg 1.6 v = env.FindFile('helvet.fnt', './lib')
7 schorsch 1.5 if not v:
8     print '''
9     Radiance auxiliary support files not found.
10     -> Download from radiance-online.org and extract.
11     '''
12     env.Exit()
13
14 schorsch 1.1 def find_x11(env):
15     # Search for libX11, remember the X11 library and include dirs
16     for d in ('/usr/X11R6', '/usr/X11', '/usr/openwin'):
17     if os.path.isdir (d):
18     incdir = os.path.join(d, 'include')
19     libdir = os.path.join(d, 'lib')
20 schorsch 1.4 env.Prepend(CPPPATH=[incdir]) # add temporarily
21     env.Prepend(LIBPATH=[libdir])
22 schorsch 1.1 conf = SConf(env)
23     if conf.CheckLibWithHeader('X11', 'X11/X.h', 'C', autoadd=0):
24     env.Replace(X11INCLUDE=incdir)
25     env.Replace(X11LIB=libdir)
26     env['CPPPATH'].remove(incdir) # not needed for now
27     env['LIBPATH'].remove(libdir)
28     if env['X11INCLUDE']:
29     # Check for SGI stereo extension
30     if conf.CheckCHeader('X11/extensions/SGIStereo.h'):
31     env['RAD_STEREO'] = '-DSTEREO'
32     else: env['RAD_STEREO'] = '-DNOSTEREO'
33     env = conf.Finish ()
34     break
35     env = conf.Finish ()
36
37 schorsch 1.3
38 schorsch 1.1 def find_gl(env):
39     # Check for libGL, set flag
40 schorsch 1.3 dl = [(None,None)] # standard search path
41     if env.has_key('X11INCLUDE'): # sometimes found there (Darwin)
42     dl.append((env['X11INCLUDE'], env['X11LIB']))
43     for incdir, libdir in dl:
44 schorsch 1.4 if incdir: env.Prepend(CPPPATH=[incdir]) # add temporarily
45     if libdir: env.Prepend(LIBPATH=[libdir])
46 schorsch 1.3 conf = SConf(env)
47 schorsch 1.2 if conf.CheckLibWithHeader('GL', 'GL/gl.h', 'C', autoadd=0):
48     env['OGL'] = 1
49     if incdir: env['CPPPATH'].remove(incdir) # not needed for now
50 schorsch 1.3 if libdir: env['LIBPATH'].remove(libdir)
51     if env.has_key('OGL'):
52     if incdir: env.Replace(OGLINCLUDE=[incdir])
53     #if libdir: env.Replace(OGLLIB=[libdir])
54     conf.Finish()
55     break
56     conf.Finish()
57 schorsch 1.1
58 schorsch 1.4
59     def find_libtiff(env):
60     # Check for libtiff, set flag and include/lib directories
61     dl = [ (None,None), ] # standard search path
62     cfgi = env.get('TIFFINCLUDE')
63     cfgl = env.get('TIFFLIB')
64     if cfgi or cfgl:
65     dl.insert(0,(cfgi, cfgl))
66     for incdir, libdir in dl:
67     if incdir: env.Prepend(CPPPATH=[incdir]) # add temporarily
68     if libdir: env.Prepend(LIBPATH=[libdir])
69     conf = SConf(env)
70     if conf.CheckLib('tiff', 'TIFFInitSGILog',
71     header='void TIFFInitSGILog(void);', autoadd=0):
72     env['TIFFLIB_INSTALLED'] = 1
73     if incdir: env['CPPPATH'].remove(incdir) # not needed for now
74     if libdir: env['LIBPATH'].remove(libdir)
75     if env.has_key('TIFFLIB_INSTALLED'):
76     if incdir: env.Replace(RAD_TIFFINCLUDE=[incdir])
77     if libdir: env.Replace(RAD_TIFFLIB=[libdir])
78     conf.Finish()
79     break
80     conf.Finish()
81
