root/Development/ray/build_utils/find_libs.py
Revision 1.11 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Jan 8 13:38:37 2018 UTC (7 years, 11 months ago) by schorsch
Diff to previous 1.10
Revision 1.10 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Apr 19 21:21:23 2016 UTC (9 years, 8 months ago) by schorsch
Changes since 1.9: +15 -0 lines
Diff to previous 1.9
Build with VC2013 until text pipe bug is fixed; prepare for pyinstaller on scripts
Revision 1.9 - (view) (download) (as text) (annotate) - [select for diffs]
Sat Mar 19 12:58:59 2016 UTC (9 years, 9 months ago) by schorsch
Changes since 1.8: +11 -1 lines
Diff to previous 1.8
more flexible gl/glu checks for all platforms
Thu Mar 10 17:36:18 2016 UTC (9 years, 9 months ago) by schorsch
Changes since 1.7: +13 -10 lines
Diff to previous 1.7
Tifflib support and sleeker binaries on Windows
Revision 1.7 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Mar 10 01:49:56 2016 UTC (9 years, 9 months ago) by schorsch
Changes since 1.6: +7 -2 lines
Diff to previous 1.6
SCons build system learns about platform architecture
Thu May 27 19:32:12 2010 UTC (15 years, 6 months ago) by greg
Diff to previous 1.5
Thu Oct 22 21:16:05 2009 UTC (16 years, 1 month ago) by schorsch
Changes since 1.4: +9 -0 lines
Diff to previous 1.4
SCons now checks for installed auxiliary support files.
Tue Dec 23 15:03:59 2008 UTC (16 years, 11 months ago) by schorsch
Changes since 1.3: +28 -8 lines
Diff to previous 1.3
Thu Oct 21 15:47:12 2004 UTC (21 years, 2 months ago) by schorsch
Changes since 1.2: +19 -14 lines
Diff to previous 1.2
SCons build simplifications.
Revision 1.2 - (view) (download) (as text) (annotate) - [select for diffs]
Sun Jul 4 12:08:47 2004 UTC (21 years, 5 months ago) by schorsch
Changes since 1.1: +12 -1 lines
Tue Oct 21 19:27:28 2003 UTC (22 years, 2 months ago) by schorsch
Links to HEAD: (view) (download) (as text) (annotate)
