root/radiance/ray/build_utils/find_libs.py
Revision: 1.2
Committed: Sun Jul 4 12:08:47 2004 UTC (19 years, 11 months ago) by schorsch
Content type: text/x-python
Changes since 1.1: +12 -1 lines
1 import os
2
3 from SCons.SConf import SConf # aka Configure
4
5 def find_x11(env):
6 # Search for libX11, remember the X11 library and include dirs
7 for d in ('/usr/X11R6', '/usr/X11', '/usr/openwin'):
8 if os.path.isdir (d):
9 incdir = os.path.join(d, 'include')
10 libdir = os.path.join(d, 'lib')
11 env.Append(CPPPATH=[incdir]) # add temporarily
12 env.Append(LIBPATH=[libdir])
13 conf = SConf(env)
14 if conf.CheckLibWithHeader('X11', 'X11/X.h', 'C', autoadd=0):
15 env.Replace(X11INCLUDE=incdir)
16 env.Replace(X11LIB=libdir)
17 env['CPPPATH'].remove(incdir) # not needed for now
18 env['LIBPATH'].remove(libdir)
19 if env['X11INCLUDE']:
20 # Check for SGI stereo extension
21 if conf.CheckCHeader('X11/extensions/SGIStereo.h'):
22 env['RAD_STEREO'] = '-DSTEREO'
23 else: env['RAD_STEREO'] = '-DNOSTEREO'
24 env = conf.Finish ()
25 break
26 env = conf.Finish ()
27
28 def find_gl(env):
29 # Check for libGL, set flag
30 conf = SConf(env)
31 if conf.CheckLibWithHeader('GL', 'GL/gl.h', 'C', autoadd=0):
32 env['OGL'] = 1
33 elif env.has_key('X11INCLUDE'): # sometimes found there
34 incdir = env['X11INCLUDE']
35 libdir = env['X11LIB']
36 env.Append(CPPPATH=[incdir]) # add temporarily
37 #env.Append(LIBPATH=[libdir])
38 if conf.CheckLibWithHeader('GL', 'GL/gl.h', 'C', autoadd=0):
39 env['OGL'] = 1
40 env.Replace(OGLINCLUDE=incdir)
41 env.Replace(OGLLIB=libdir)
42 if incdir: env['CPPPATH'].remove(incdir) # not needed for now
43 #if libdir: env['LIBPATH'].remove(libdir)
44 conf.Finish()
45
46
47
