root/radiance/ray/build_utils/find_libs.py
Revision: 1.1
Committed: Tue Oct 21 19:27:28 2003 UTC (20 years, 6 months ago) by schorsch
Content type: text/x-python
1 import os
2
3 from SCons.SConf import SConf # aka Configure
4
5 def find_x11(env):
6 # Search for libX11, remember the X11 library and include dirs
7 for d in ('/usr/X11R6', '/usr/X11', '/usr/openwin'):
8 if os.path.isdir (d):
9 incdir = os.path.join(d, 'include')
10 libdir = os.path.join(d, 'lib')
11 env.Append(CPPPATH=[incdir]) # add temporarily
12 env.Append(LIBPATH=[libdir])
13 conf = SConf(env)
14 if conf.CheckLibWithHeader('X11', 'X11/X.h', 'C', autoadd=0):
15 env.Replace(X11INCLUDE=incdir)
16 env.Replace(X11LIB=libdir)
17 env['CPPPATH'].remove(incdir) # not needed for now
18 env['LIBPATH'].remove(libdir)
19 if env['X11INCLUDE']:
20 # Check for SGI stereo extension
21 if conf.CheckCHeader('X11/extensions/SGIStereo.h'):
22 env['RAD_STEREO'] = '-DSTEREO'
23 else: env['RAD_STEREO'] = '-DNOSTEREO'
24 env = conf.Finish ()
25 break
26 env = conf.Finish ()
27
28 def find_gl(env):
29 # Check for libGL, set flag
30 conf = SConf(env)
31 if conf.CheckLibWithHeader('GL', 'GL/gl.h', 'C', autoadd=0):
32 env['OGL'] = 1
33 env = conf.Finish()
34
35
36
