--- ray/build_utils/find_libs.py 2003/10/21 19:27:28 1.1 +++ ray/build_utils/find_libs.py 2008/12/23 15:03:59 1.4 @@ -8,8 +8,8 @@ def find_x11(env): if os.path.isdir (d): incdir = os.path.join(d, 'include') libdir = os.path.join(d, 'lib') - env.Append(CPPPATH=[incdir]) # add temporarily - env.Append(LIBPATH=[libdir]) + env.Prepend(CPPPATH=[incdir]) # add temporarily + env.Prepend(LIBPATH=[libdir]) conf = SConf(env) if conf.CheckLibWithHeader('X11', 'X11/X.h', 'C', autoadd=0): env.Replace(X11INCLUDE=incdir) @@ -25,12 +25,48 @@ def find_x11(env): break env = conf.Finish () + def find_gl(env): # Check for libGL, set flag - conf = SConf(env) - if conf.CheckLibWithHeader('GL', 'GL/gl.h', 'C', autoadd=0): - env['OGL'] = 1 - env = conf.Finish() + dl = [(None,None)] # standard search path + if env.has_key('X11INCLUDE'): # sometimes found there (Darwin) + dl.append((env['X11INCLUDE'], env['X11LIB'])) + for incdir, libdir in dl: + if incdir: env.Prepend(CPPPATH=[incdir]) # add temporarily + if libdir: env.Prepend(LIBPATH=[libdir]) + conf = SConf(env) + if conf.CheckLibWithHeader('GL', 'GL/gl.h', 'C', autoadd=0): + env['OGL'] = 1 + if incdir: env['CPPPATH'].remove(incdir) # not needed for now + if libdir: env['LIBPATH'].remove(libdir) + if env.has_key('OGL'): + if incdir: env.Replace(OGLINCLUDE=[incdir]) + #if libdir: env.Replace(OGLLIB=[libdir]) + conf.Finish() + break + conf.Finish() +def find_libtiff(env): + # Check for libtiff, set flag and include/lib directories + dl = [ (None,None), ] # standard search path + cfgi = env.get('TIFFINCLUDE') + cfgl = env.get('TIFFLIB') + if cfgi or cfgl: + dl.insert(0,(cfgi, cfgl)) + for incdir, libdir in dl: + if incdir: env.Prepend(CPPPATH=[incdir]) # add temporarily + if libdir: env.Prepend(LIBPATH=[libdir]) + conf = SConf(env) + if conf.CheckLib('tiff', 'TIFFInitSGILog', + header='void TIFFInitSGILog(void);', autoadd=0): + env['TIFFLIB_INSTALLED'] = 1 + if incdir: env['CPPPATH'].remove(incdir) # not needed for now + if libdir: env['LIBPATH'].remove(libdir) + if env.has_key('TIFFLIB_INSTALLED'): + if incdir: env.Replace(RAD_TIFFINCLUDE=[incdir]) + if libdir: env.Replace(RAD_TIFFLIB=[libdir]) + conf.Finish() + break + conf.Finish()
