| 1 |
from __future__ import division, print_function, unicode_literals
| 2 |
| 3 |
import os
| 4 |
| 5 |
from SCons.SConf import SConf # aka Configure
| 6 |
| 7 |
def find_radlib(env):
| 8 |
v = env.FindFile('helvet.fnt', './lib')
| 9 |
if not v:
| 10 |
print('''
| 11 |
Radiance auxiliary support files not found.
| 12 |
-> Download from radiance-online.org and extract.
| 13 |
| 14 |
env.Exit()
| 15 |
| 16 |
def find_pyinstaller(env):
| 17 |
if os.name != 'nt':
| 18 |
return
| 19 |
conf = SConf(env)
| 20 |
oldpath = (env['ENV'].get('PATH'))
| 21 |
try:
| 22 |
env['ENV']['PATH'] = os.environ['PATH']
| 23 |
pyinst = conf.CheckProg('pyinstaller.exe')
| 24 |
if pyinst:
| 25 |
env['PYINSTALLER'] = pyinst
| 26 |
env['PYSCRIPTS'] = []
| 27 |
env = conf.Finish()
| 28 |
finally:
| 29 |
env['ENV']['PATH'] = oldpath
| 30 |
| 31 |
def find_x11(env):
| 32 |
# Search for libX11, remember the X11 library and include dirs
| 33 |
for d in ('/usr/X11R6', '/usr/X11', '/usr/openwin'):
| 34 |
if os.path.isdir (d):
| 35 |
incdir = os.path.join(d, 'include')
| 36 |
libdir = os.path.join(d, 'lib')
| 37 |
env.Prepend(CPPPATH=[incdir]) # add temporarily
| 38 |
env.Prepend(LIBPATH=[libdir])
| 39 |
conf = SConf(env)
| 40 |
if conf.CheckLibWithHeader('X11', 'X11/X.h', 'C', autoadd=0):
| 41 |
env.Replace(X11INCLUDE=incdir)
| 42 |
env.Replace(X11LIB=libdir)
| 43 |
env['CPPPATH'].remove(incdir) # not needed for now
| 44 |
env['LIBPATH'].remove(libdir)
| 45 |
if env['X11INCLUDE']:
| 46 |
# Check for SGI stereo extension
| 47 |
if conf.CheckCHeader('X11/extensions/SGIStereo.h'):
| 48 |
env['RAD_STEREO'] = '-DSTEREO'
| 49 |
else: env['RAD_STEREO'] = '-DNOSTEREO'
| 50 |
env = conf.Finish ()
| 51 |
break
| 52 |
| 53 |
| 54 |
| 55 |
def find_gl(env):
| 56 |
# Check for libGL, set flag
| 57 |
dl = [(None,None)] # standard search path
| 58 |
if env.has_key('X11INCLUDE'): # sometimes found there (Darwin)
| 59 |
dl.append((env['X11INCLUDE'], env['X11LIB']))
| 60 |
for incdir, libdir in dl:
| 61 |
if incdir: env.Prepend(CPPPATH=[incdir]) # add temporarily
| 62 |
if libdir: env.Prepend(LIBPATH=[libdir])
| 63 |
conf = SConf(env)
| 64 |
if (conf.CheckLib('GL')
| 65 |
or conf.CheckLib('opengl32')
| 66 |
or conf.CheckCHeader('OpenGL/gl.h')
| 67 |
or conf.CheckCHeader('GL/gl.h')):
| 68 |
env['OGL'] = 1
| 69 |
if os.name == 'nt':
| 70 |
if (conf.CheckLib('GLU') # for winrview
| 71 |
or conf.CheckLib('glu32')
| 72 |
or conf.CheckCHeader('OpenGL/glu.h')):
| 73 |
env['GLU'] = 1
| 74 |
if incdir: env['CPPPATH'].remove(incdir) # not needed for now
| 75 |
if libdir: env['LIBPATH'].remove(libdir)
| 76 |
if env.has_key('OGL'):
| 77 |
if incdir: env.Replace(OGLINCLUDE=[incdir])
| 78 |
if env.has_key('GLU'):
| 79 |
if incdir: env.Replace(GLUINCLUDE=[incdir])
| 80 |
#if libdir: env.Replace(OGLLIB=[libdir])
| 81 |
conf.Finish()
| 82 |
break
| 83 |
conf.Finish()
| 84 |
| 85 |
| 86 |
def find_libtiff(env):
| 87 |
# Check for libtiff, set flag and include/lib directories
| 88 |
dl = [ (None,None), ] # standard search path
| 89 |
cfgi = env.get('TIFFINCLUDE')
| 90 |
cfgl = env.get('TIFFLIB')
| 91 |
if cfgi or cfgl:
| 92 |
dl.insert(0,(cfgi, cfgl))
| 93 |
| 94 |
xenv = env.Clone()
| 95 |
if incdir: xenv.Prepend(CPPPATH=[incdir]) # add temporarily
| 96 |
if libdir:
| 97 |
xenv.Prepend(LIBPATH=[libdir])
| 98 |
xenv.Prepend(PATH=[libdir])
| 99 |
conf = SConf(xenv)
| 100 |
libname = 'tiff'
| 101 |
if os.name == 'nt':
| 102 |
xenv['INCPREFIX'] = '/I ' # Bug in SCons (uses '/I')
| 103 |
libname = 'libtiff'
| 104 |
if conf.CheckLib(libname, 'TIFFInitSGILog',
| 105 |
header='''#include "tiff.h"''', autoadd=0):
| 106 |
env['TIFFLIB_INSTALLED'] = 1
| 107 |
if env.has_key('TIFFLIB_INSTALLED'):
| 108 |
env.Replace(RAD_LIBTIFF=libname)
| 109 |
if incdir: env.Replace(RAD_TIFFINCLUDE=[incdir])
| 110 |
if libdir: env.Replace(RAD_TIFFLIB=[libdir])
| 111 |
conf.Finish()
| 112 |
break
| 113 |
conf.Finish()
| 114 |
| 115 |
# vi: set ts=4 sw=4 :
| 116 |
