root/radiance/ray/build_utils/find_libs.py
Revision 1.6 - (view) (download) (as text) (annotate) - [selected]
Thu May 27 19:32:12 2010 UTC (14 years, 8 months ago) by greg
Diff to previous 1.5
Thu Oct 22 21:16:05 2009 UTC (15 years, 3 months ago) by schorsch
Changes since 1.4: +9 -0 lines
Diff to previous 1.4 , to selected 1.6
SCons now checks for installed auxiliary support files.
Tue Dec 23 15:03:59 2008 UTC (16 years, 1 month ago) by schorsch
Changes since 1.3: +28 -8 lines
Diff to previous 1.3 , to selected 1.6
Thu Oct 21 15:47:12 2004 UTC (20 years, 3 months ago) by schorsch
Changes since 1.2: +19 -14 lines
Diff to previous 1.2 , to selected 1.6
SCons build simplifications.
Revision 1.2 - (view) (download) (as text) (annotate) - [select for diffs]
Sun Jul 4 12:08:47 2004 UTC (20 years, 6 months ago) by schorsch
Changes since 1.1: +12 -1 lines
Diff to previous 1.1 , to selected 1.6
Tue Oct 21 19:27:28 2003 UTC (21 years, 3 months ago) by schorsch
Diff to selected 1.6
Links to HEAD: (view) (download) (as text) (annotate) Links to rad5R0: (view) (download) (as text) (annotate)
