root/radiance/ray/build_utils/find_libs.py
Thu May 27 19:32:12 2010 UTC (14 years, 11 months ago) by greg
Thu Oct 22 21:16:05 2009 UTC (15 years, 6 months ago) by schorsch
Changes since 1.4: +9 -0 lines
SCons now checks for installed auxiliary support files.
Tue Dec 23 15:03:59 2008 UTC (16 years, 4 months ago) by schorsch
Changes since 1.3: +28 -8 lines
Thu Oct 21 15:47:12 2004 UTC (20 years, 6 months ago) by schorsch
Changes since 1.2: +19 -14 lines
Diff to previous 1.2
SCons build simplifications.
Revision 1.2 - (view) (download) (as text) (annotate) - [selected]
Sun Jul 4 12:08:47 2004 UTC (20 years, 10 months ago) by schorsch
Changes since 1.1: +12 -1 lines
Diff to previous 1.1
Tue Oct 21 19:27:28 2003 UTC (21 years, 6 months ago) by schorsch
Diff to selected 1.2
Links to HEAD: (view) (download) (as text) (annotate) Links to rad4R1: (view) (download) (as text) (annotate)
