| 1 |
import os
| 2 |
| 3 |
from SCons.SConf import SConf # aka Configure
| 4 |
| 5 |
def find_x11(env):
| 6 |
# Search for libX11, remember the X11 library and include dirs
| 7 |
for d in ('/usr/X11R6', '/usr/X11', '/usr/openwin'):
| 8 |
if os.path.isdir (d):
| 9 |
incdir = os.path.join(d, 'include')
| 10 |
libdir = os.path.join(d, 'lib')
| 11 |
env.Append(CPPPATH=[incdir]) # add temporarily
| 12 |
env.Append(LIBPATH=[libdir])
| 13 |
conf = SConf(env)
| 14 |
if conf.CheckLibWithHeader('X11', 'X11/X.h', 'C', autoadd=0):
| 15 |
env.Replace(X11INCLUDE=incdir)
| 16 |
env.Replace(X11LIB=libdir)
| 17 |
env['CPPPATH'].remove(incdir) # not needed for now
| 18 |
env['LIBPATH'].remove(libdir)
| 19 |
if env['X11INCLUDE']:
| 20 |
# Check for SGI stereo extension
| 21 |
if conf.CheckCHeader('X11/extensions/SGIStereo.h'):
| 22 |
env['RAD_STEREO'] = '-DSTEREO'
| 23 |
else: env['RAD_STEREO'] = '-DNOSTEREO'
| 24 |
env = conf.Finish ()
| 25 |
break
| 26 |
| 27 |
| 28 |
| 29 |
def find_gl(env):
| 30 |
# Check for libGL, set flag
| 31 |
dl = [(None,None)] # standard search path
| 32 |
if env.has_key('X11INCLUDE'): # sometimes found there (Darwin)
| 33 |
dl.append((env['X11INCLUDE'], env['X11LIB']))
| 34 |
#if os.name == 'nt':
| 35 |
# dl.append((some win specific dirs))
| 36 |
#if some other weirdness:
| 37 |
| 38 |
for incdir, libdir in dl:
| 39 |
if incdir: env.Append(CPPPATH=[incdir]) # add temporarily
| 40 |
if libdir: env.Append(LIBPATH=[libdir])
| 41 |
conf = SConf(env)
| 42 |
if conf.CheckLibWithHeader('GL', 'GL/gl.h', 'C', autoadd=0):
| 43 |
env['OGL'] = 1
| 44 |
if incdir: env['CPPPATH'].remove(incdir) # not needed for now
| 45 |
if libdir: env['LIBPATH'].remove(libdir)
| 46 |
if env.has_key('OGL'):
| 47 |
if incdir: env.Replace(OGLINCLUDE=[incdir])
| 48 |
#if libdir: env.Replace(OGLLIB=[libdir])
| 49 |
conf.Finish()
| 50 |
break
| 51 |
conf.Finish()
| 52 |
