root/radiance/ray/build_utils/find_libs.py
Revision: 1.10
Committed: Tue Apr 19 21:21:23 2016 UTC (9 years, 3 months ago) by schorsch
Content type: text/x-python
Changes since 1.9: +15 -0 lines
Build with VC2013 until text pipe bug is fixed; prepare for pyinstaller on scripts
1 from __future__ import print_function
2
3 import os
4
5 from SCons.SConf import SConf # aka Configure
6
7 def find_radlib(env):
8 v = env.FindFile('helvet.fnt', './lib')
9 if not v:
10 print('''
11 Radiance auxiliary support files not found.
12 -> Download from radiance-online.org and extract.
13 ''')
14 env.Exit()
15
16 def find_pyinstaller(env):
17 if os.name != 'nt':
18 return
19 conf = SConf(env)
20 oldpath = (env['ENV'].get('PATH'))
21 try:
22 env['ENV']['PATH'] = os.environ['PATH']
23 pyinst = conf.CheckProg('pyinstaller.exe')
24 if pyinst:
25 env['PYINSTALLER'] = pyinst
26 env['PYSCRIPTS'] = []
27 env = conf.Finish()
28 finally:
29 env['ENV']['PATH'] = oldpath
30
31 def find_x11(env):
32 # Search for libX11, remember the X11 library and include dirs
33 for d in ('/usr/X11R6', '/usr/X11', '/usr/openwin'):
34 if os.path.isdir (d):
35 incdir = os.path.join(d, 'include')
36 libdir = os.path.join(d, 'lib')
37 env.Prepend(CPPPATH=[incdir]) # add temporarily
38 env.Prepend(LIBPATH=[libdir])
39 conf = SConf(env)
40 if conf.CheckLibWithHeader('X11', 'X11/X.h', 'C', autoadd=0):
41 env.Replace(X11INCLUDE=incdir)
42 env.Replace(X11LIB=libdir)
43 env['CPPPATH'].remove(incdir) # not needed for now
44 env['LIBPATH'].remove(libdir)
45 if env['X11INCLUDE']:
46 # Check for SGI stereo extension
47 if conf.CheckCHeader('X11/extensions/SGIStereo.h'):
48 env['RAD_STEREO'] = '-DSTEREO'
49 else: env['RAD_STEREO'] = '-DNOSTEREO'
50 env = conf.Finish ()
51 break
52 env = conf.Finish ()
53
54
55 def find_gl(env):
56 # Check for libGL, set flag
57 dl = [(None,None)] # standard search path
58 if env.has_key('X11INCLUDE'): # sometimes found there (Darwin)
59 dl.append((env['X11INCLUDE'], env['X11LIB']))
60 for incdir, libdir in dl:
61 if incdir: env.Prepend(CPPPATH=[incdir]) # add temporarily
62 if libdir: env.Prepend(LIBPATH=[libdir])
63 conf = SConf(env)
64 if (conf.CheckLib('GL')
65 or conf.CheckLib('opengl32')
66 or conf.CheckCHeader('OpenGL/gl.h')
67 or conf.CheckCHeader('GL/gl.h')):
68 env['OGL'] = 1
69 if os.name == 'nt':
70 if (conf.CheckLib('GLU') # for winrview
71 or conf.CheckLib('glu32')
72 or conf.CheckCHeader('OpenGL/glu.h')):
73 env['GLU'] = 1
74 if incdir: env['CPPPATH'].remove(incdir) # not needed for now
75 if libdir: env['LIBPATH'].remove(libdir)
76 if env.has_key('OGL'):
77 if incdir: env.Replace(OGLINCLUDE=[incdir])
78 if env.has_key('GLU'):
79 if incdir: env.Replace(GLUINCLUDE=[incdir])
80 #if libdir: env.Replace(OGLLIB=[libdir])
81 conf.Finish()
82 break
83 conf.Finish()
84
85
86 def find_libtiff(env):
87 # Check for libtiff, set flag and include/lib directories
88 dl = [ (None,None), ] # standard search path
89 cfgi = env.get('TIFFINCLUDE')
90 cfgl = env.get('TIFFLIB')
91 if cfgi or cfgl:
92 dl.insert(0,(cfgi, cfgl))
93 for incdir, libdir in dl:
94 xenv = env.Clone()
95 if incdir: xenv.Prepend(CPPPATH=[incdir]) # add temporarily
96 if libdir:
97 xenv.Prepend(LIBPATH=[libdir])
98 xenv.Prepend(PATH=[libdir])
99 conf = SConf(xenv)
100 libname = 'tiff'
101 if os.name == 'nt':
102 xenv['INCPREFIX'] = '/I ' # Bug in SCons (uses '/I')
103 libname = 'libtiff'
104 if conf.CheckLib(libname, 'TIFFInitSGILog',
105 header='''#include "tiff.h"''', autoadd=0):
106 env['TIFFLIB_INSTALLED'] = 1
107 if env.has_key('TIFFLIB_INSTALLED'):
108 env.Replace(RAD_LIBTIFF=libname)
109 if incdir: env.Replace(RAD_TIFFINCLUDE=[incdir])
110 if libdir: env.Replace(RAD_TIFFLIB=[libdir])
111 conf.Finish()
112 break
113 conf.Finish()
114
