root/Development/ray/build_utils/copyright.py
Revision: 1.3
Committed: Mon Jan 8 13:38:37 2018 UTC (7 years, 11 months ago) by schorsch
Content type: text/x-python
CVS Tags: rad6R0, rad5R4, rad5R3, rad5R2, HEAD
Changes since 1.2: +8 -3 lines
# User Rev Content
1 schorsch 1.3 from __future__ import division, print_function, unicode_literals
2 schorsch 1.1
3 schorsch 1.2 import os
4 schorsch 1.1 import sys
5 schorsch 1.3 import builtins
6     if hasattr(builtins, 'raw_input'): # < Py3
7     input = builtins.raw_input
8 schorsch 1.1
9
10 schorsch 1.2 def _get_ltextl():
11     f = open(os.path.join('src','common','copyright.h'), 'r')
12     ltl = f.readlines()
13     f.close()
14     ltl2 = []
15     for line in ltl:
16     line = line.strip()
17     if line == '*/': line = ''
18     elif line.find('$Id:') > -1: line = ''
19     elif line and line[0] == '*':
20     line = line[2:]
21     elif line and line[1] == '*':
22     line = line[3:]
23     ltl2.append(line)
24     return ltl2 + ['']
25
26     def _show_ltextl(ltextl, lines=23):
27     llen = len(ltextl)
28     for i in range(0, llen, lines):
29     sys.stderr.write('\n'.join(ltextl[i:i+lines]))
30     if i+lines < llen:
31 schorsch 1.3 input('\n[press <return> to continue] ')
32 schorsch 1.1
33     def show_license():
34 schorsch 1.2 try:
35     ltextl = _get_ltextl()
36     _show_ltextl(ltextl)
37     sys.stderr.write(
38     'Do you understand and accept the terms of this agreement [n]?\n\n')
39     answer = ''
40     s = 'Please enter "yes" or "no", or use ^C to exit: '
41     while answer not in ['y', 'ye', 'yes', 'n', 'no']:
42     if answer: sys.stderr.write('invalid input "%s"\n' % answer)
43 schorsch 1.3 answer = input(s).lower()
44 schorsch 1.2
45     if answer[0] == 'y':
46     return
47     else:
48     sys.stderr.write('\n*** Installation cancelled ***\n')
49     sys.exit(1)
50     except KeyboardInterrupt:
51 schorsch 1.1 sys.stderr.write('\n*** Installation cancelled ***\n')
52     sys.exit(1)
53
54 schorsch 1.3 # vi: set ts=4 sw=4 :
55
