--- ray/build_utils/copyright.py 2003/10/21 19:27:28 1.1 +++ ray/build_utils/copyright.py 2003/12/12 15:48:31 1.2 @@ -1,50 +1,50 @@ +import os import sys import string -_ltext = ''' - RADIANCE LICENSE AGREEMENT +def _get_ltextl(): + f = open(os.path.join('src','common','copyright.h'), 'r') + ltl = f.readlines() + f.close() + ltl2 = [] + for line in ltl: + line = line.strip() + if line == '*/': line = '' + elif line.find('$Id:') > -1: line = '' + elif line and line[0] == '*': + line = line[2:] + elif line and line[1] == '*': + line = line[3:] + ltl2.append(line) + return ltl2 + [''] -Radiance is a registered copyright of The Regents of the University of -California ("The Regents"). The Regents grant to you a nonexclusive, -nontransferable license ("License") to use Radiance source code without -fee. You may not sell or distribute Radiance to others without the -prior express written permission of The Regents. You may compile and -use this software on any machines to which you have personal access, -and may share its use with others who have access to the same machines. +def _show_ltextl(ltextl, lines=23): + llen = len(ltextl) + for i in range(0, llen, lines): + sys.stderr.write('\n'.join(ltextl[i:i+lines])) + if i+lines < llen: + raw_input('\n[press to continue] ') -NEITHER THE UNITED STATES NOR THE UNITED STATES DEPARTMENT OF ENERGY, NOR ANY -OF THEIR EMPLOYEES, MAKES ANY WARRANTY, EXPRESS OR IMPLIED, OR ASSUMES ANY -LEGAL LIABILITY OR RESPONSIBILITY FOR THE ACCURACY, COMPLETENESS, OR USEFULNESS -OF ANY INFORMATION, APPARATUS, PRODUCT, OR PROCESS DISCLOSED, OR REPRESENTS -THAT ITS USE WOULD NOT INFRINGE PRIVATELY OWNED RIGHTS. By downloading, using -or copying this software, you agree to abide by the intellectual property laws -and all other applicable laws of the United States, and by the terms of this -License Agreement. Ownership of the software shall remain solely in The -Regents. The Regents shall have the right to terminate this License -immediately by written notice upon your breach of, or noncompliance with, any -of its terms. You shall be liable for any infringement or damages resulting -from your failure to abide by the terms of this License Agreement. - - - -''' - def show_license(): - sys.stderr.write(_ltext) - sys.stderr.write( - 'Do you understand and accept the terms of this agreement [n]?\n\n') + try: + ltextl = _get_ltextl() + _show_ltextl(ltextl) + sys.stderr.write( + 'Do you understand and accept the terms of this agreement [n]?\n\n') + answer = '' + s = 'Please enter "yes" or "no", or use ^C to exit: ' + while answer not in ['y', 'ye', 'yes', 'n', 'no']: + if answer: sys.stderr.write('invalid input "%s"\n' % answer) + answer = string.lower(raw_input(s)) - answer = '' - s = 'Please enter "yes" or "no", or use ^C to exit: ' - while answer not in ['y', 'ye', 'yes', 'n', 'no']: - if answer: sys.stderr.write('invalid input "%s"\n' % answer) - answer = string.lower(raw_input(s)) - - if answer[0] == 'y': - return - else: + if answer[0] == 'y': + return + else: + sys.stderr.write('\n*** Installation cancelled ***\n') + sys.exit(1) + except KeyboardInterrupt: sys.stderr.write('\n*** Installation cancelled ***\n') sys.exit(1)
