root/Development/ray/build_utils/copyright.py
Revision: 1.2
Committed: Fri Dec 12 15:48:31 2003 UTC (21 years, 11 months ago) by schorsch
Content type: text/x-python
CVS Tags: rad5R1, rad5R0, rad4R2P2, rad4R2P1, rad4R2, rad4R1, rad4R0, rad3R9, rad3R8, rad3R7P2, rad3R7P1, rad3R6P1, rad3R6
Changes since 1.1: +40 -40 lines
Switching to current license text loaded from src/common/copyright.h.
1
2 import os
3 import sys
4 import string
5
6
7 def _get_ltextl():
8 f = open(os.path.join('src','common','copyright.h'), 'r')
9 ltl = f.readlines()
10 f.close()
11 ltl2 = []
12 for line in ltl:
13 line = line.strip()
14 if line == '*/': line = ''
15 elif line.find('$Id:') > -1: line = ''
16 elif line and line[0] == '*':
17 line = line[2:]
18 elif line and line[1] == '*':
19 line = line[3:]
20 ltl2.append(line)
21 return ltl2 + ['']
22
23 def _show_ltextl(ltextl, lines=23):
24 llen = len(ltextl)
25 for i in range(0, llen, lines):
26 sys.stderr.write('\n'.join(ltextl[i:i+lines]))
27 if i+lines < llen:
28 raw_input('\n[press <return> to continue] ')
29
30 def show_license():
31 try:
32 ltextl = _get_ltextl()
33 _show_ltextl(ltextl)
34 sys.stderr.write(
35 'Do you understand and accept the terms of this agreement [n]?\n\n')
36 answer = ''
37 s = 'Please enter "yes" or "no", or use ^C to exit: '
38 while answer not in ['y', 'ye', 'yes', 'n', 'no']:
39 if answer: sys.stderr.write('invalid input "%s"\n' % answer)
40 answer = string.lower(raw_input(s))
41
42 if answer[0] == 'y':
43 return
44 else:
45 sys.stderr.write('\n*** Installation cancelled ***\n')
46 sys.exit(1)
47 except KeyboardInterrupt:
48 sys.stderr.write('\n*** Installation cancelled ***\n')
49 sys.exit(1)
50
