root/Development/ray/SConstruct
Revision: 1.8
Committed: Fri Dec 26 17:00:32 2008 UTC (16 years, 11 months ago) by schorsch
Changes since 1.7: +39 -34 lines
Invoke test suite from SCons and installation instructions.
1
2 import os
3 import sys
4 import string
5
6 OPTFILE = 'rayopts.py'
7 def set_opts(env):
8 # XXX add some caching
9 opts = Options(OPTFILE, ARGUMENTS)
10 opts.Add('SKIP', 'Skip Display of License terms', 0)
11 opts.Add('RAD_BINDIR', 'Install executables here', env['RAD_BINDIR'])
12 opts.Add('RAD_RLIBDIR', 'Install support files here', env['RAD_RLIBDIR'])
13 opts.Add('RAD_MANDIR', 'Install man pages here', env['RAD_MANDIR'])
14 opts.Add('RAD_DEBUG', 'Build a debug version', 0)
15 opts.Update(env)
16 opts.Save(OPTFILE, env)
17 Help(opts.GenerateHelpText(env, sort=cmp))
18 # where stuff is located in the source tree
19 env['RAD_BUILDLIB'] = '#src/lib'
20 env['RAD_BUILDBIN'] = '#bin'
21 env['RAD_BUILDRLIB'] = '#lib'
22 env['RAD_BUILDMAN'] = '#doc/man'
23
24 def allplats_setup(env):
25 from build_utils import find_libs
26 find_libs.find_x11(env)
27 find_libs.find_gl(env) # OpenGL
28 find_libs.find_libtiff(env)
29
30 def post_common_setup(env):
31 env.Append(CPPPATH = [os.path.join('#src', 'common')])
32 env.Append(LIBPATH=['../lib']) # our own libs
33 if not env.has_key('RAD_MLIB'):
34 env['RAD_MLIB'] = [] #['m'] # no seperate mlib on Win
35
36 def shareinstall_setup(env):
37 from build_utils import install
38 # only scan for those files when we actually need them
39 if 'install' in sys.argv or 'rlibinstall' in sys.argv:
40 install.install_rlibfiles(env)
41 if 'install' in sys.argv or 'maninstall' in sys.argv:
42 install.install_manfiles(env)
43
44 # Set up build environment
45 env = Environment()
46 env.Decider('timestamp-match')
47
48 if os.name == 'posix':
49 from build_utils import install
50 csh_b = Builder(action = install.install_cshscript,
51 suffix = '', src_suffix = '.csh')
52 env.Append(BUILDERS={'InstallCsh': csh_b})
53
54 # configure platform-specific stuff
55 from build_utils import load_plat
56 load_plat.load_plat(env, ARGUMENTS, platform=None)
57
58 # override options
59 set_opts(env)
60
61 # accept license
62 if ((not env['SKIP']
63 or env['SKIP'].strip().lower() in (0,'0','no','false'))
64 and not '-c' in sys.argv and not 'test' in sys.argv):
65 from build_utils import copyright
66 copyright.show_license()
67
68 # fill in generic config
69 allplats_setup(env)
70
71
72 # Bring in all the actual things to build
73 Export('env')
74 if 'test' in sys.argv:
75 SConscript(os.path.join('test', 'SConscript'))
76
77 else:
78 SConscript(os.path.join('src', 'common', 'SConscript'))
79 post_common_setup(env)
80 for d in Split('meta cv gen ot rt px hd util cal'):
81 print d
82 SConscript(os.path.join('src', d, 'SConscript'))
83
84 if string.find(string.join(sys.argv[1:]), 'install') > -1:
85 shareinstall_setup(env)
86
87 Default('.')
88
89 # virtual targets
90 env.Alias('bininstall', '$RAD_BINDIR')
91 env.Alias('rlibinstall', '$RAD_RLIBDIR')
92 env.Alias('maninstall', '$RAD_MANDIR')
93
94 env.Alias('build', ['#bin'])
95 env.Alias('test', ['#test'])
96 env.Alias('install', ['bininstall', 'rlibinstall', 'maninstall'])
97
