| 1 |
| 2 |
import os
| 3 |
import sys
| 4 |
import string
| 5 |
| 6 |
OPTFILE = 'rayopts.py'
| 7 |
| 8 |
def set_opts(env):
| 9 |
# XXX add some caching
| 10 |
opts = Options(OPTFILE, ARGUMENTS)
| 11 |
opts.Add('SKIP', 'Skip Display of License terms', 0)
| 12 |
opts.Add('RAD_BINDIR', 'Install executables here', env['RAD_BINDIR'])
| 13 |
opts.Add('RAD_RLIBDIR', 'Install support files here', env['RAD_RLIBDIR'])
| 14 |
opts.Add('RAD_MANDIR', 'Install man pages here', env['RAD_MANDIR'])
| 15 |
opts.Add('RAD_DEBUG', 'Build a debug version', 0)
| 16 |
opts.Update(env)
| 17 |
opts.Save(OPTFILE, env)
| 18 |
Help(opts.GenerateHelpText(env, sort=cmp))
| 19 |
# where stuff is located in the source tree
| 20 |
env['RAD_BUILDLIB'] = '#src/lib'
| 21 |
env['RAD_BUILDBIN'] = '#bin'
| 22 |
env['RAD_BUILDRLIB'] = '#lib'
| 23 |
env['RAD_BUILDMAN'] = '#doc/man'
| 24 |
| 25 |
def allplats_setup(env):
| 26 |
from build_utils import find_libs
| 27 |
find_libs.find_x11(env)
| 28 |
find_libs.find_gl(env) # OpenGL
| 29 |
#find_libs.find_pixar(env) # PIXAR_LIB for src/px/ra_pixar.c
| 30 |
| 31 |
def post_common_setup(env):
| 32 |
env.Append(CPPPATH = [os.path.join('#src', 'common')])
| 33 |
env.Append(LIBPATH=['../lib']) # our own libs
| 34 |
if not env.has_key('RAD_MLIB'):
| 35 |
env['RAD_MLIB'] = [] #['m'] # no seperate mlib on Win
| 36 |
| 37 |
def shareinstall_setup(env):
| 38 |
from build_utils import install
| 39 |
# only scan for those files when we actually need them
| 40 |
if 'install' in sys.argv or 'rlibinstall' in sys.argv:
| 41 |
install.install_rlibfiles(env)
| 42 |
if 'install' in sys.argv or 'maninstall' in sys.argv:
| 43 |
install.install_manfiles(env)
| 44 |
| 45 |
# Set up build environment
| 46 |
env = Environment()
| 47 |
| 48 |
# configure platform-specific stuff
| 49 |
from build_utils import load_plat
| 50 |
load_plat.load_plat(env, ARGUMENTS, platform=None)
| 51 |
| 52 |
# override options
| 53 |
set_opts(env)
| 54 |
| 55 |
# accept license
| 56 |
if not env['SKIP'] and not '-c' in sys.argv:
| 57 |
from build_utils import copyright
| 58 |
copyright.show_license()
| 59 |
| 60 |
# fill in generic config
| 61 |
allplats_setup(env)
| 62 |
| 63 |
# Bring in all the actual things to build
| 64 |
Export('env')
| 65 |
SConscript(os.path.join('src', 'common', 'SConscript'))
| 66 |
| 67 |
for d in Split('meta cv gen ot rt px hd util cal'):
| 68 |
print d
| 69 |
SConscript(os.path.join('src', d, 'SConscript'))
| 70 |
| 71 |
if string.find(string.join(sys.argv[1:]), 'install') > -1:
| 72 |
| 73 |
| 74 |
# virtual targets
| 75 |
# RAD_XXXINSTALL are filled in by the local scripts
| 76 |
env.Alias('bininstall', env.get('RAD_BININSTALL', []))
| 77 |
env.Alias('rlibinstall', env.get('RAD_RLIBINSTALL',[]))
| 78 |
env.Alias('maninstall', env.get('RAD_MANINSTALL', []))
| 79 |
| 80 |
env.Alias('build', ['#bin'])
| 81 |
env.Alias('test', ['#src/test'])
| 82 |
env.Alias('install', ['bininstall', 'rlibinstall', 'maninstall'])
| 83 |
| 84 |
# Further virtual targets are defined locally:
| 85 |
# meta_special: mt1601 okimate imagew mt160 mx80 impress aed5
| 86 |
# tcurve tscat tbar mtext libt4014.a plotout t4014
| 87 |
# px_special: ra_im, t4027, paintjet, mt160t, greyscale, colorscale, d48c
| 88 |
# util_special: scanner, makedist (not for Windows yet)
| 89 |
env.Alias('special', ['meta_special', 'px_special', 'util_special'])
| 90 |
env.Alias('special_install', ['meta_special_install',
| 91 |
'px_special_install', 'util_special_install'])
| 92 |
