1 |
from __future__ import division, print_function, unicode_literals |
2 |
3 |
import os |
4 |
import sys |
5 |
6 |
def set_pre_opts(testenv): |
7 |
optfile = File(testenv['CFG_OPTFILE']).abspath |
8 |
vars = Variables(optfile, ARGUMENTS) |
9 |
vars.Add('SKIP', 'Skip Display of License terms', 0) |
10 |
vars.Add('RAD_DEBUG', 'Build a debug version', 0) |
11 |
if testenv['CFG_PLATSYS'] == 'Windows': |
12 |
# no default, will select the most recent one when empty |
13 |
vars.Add('MSVC_VERSION', 'Microsoft VC Version', ) |
14 |
else: # not yet supported on Windows |
15 |
vars.Add('PMAP_OOC', 'Build Pmap with Out-of-core Data', 1) |
16 |
vars.Update(testenv) |
17 |
return vars |
18 |
19 |
def set_opts(env, pathfile): |
20 |
vars = Variables(pathfile, ARGUMENTS) |
21 |
vars.Add('RAD_BASEDIR', 'Installation base directory', env['RAD_BASEDIR']) |
22 |
vars.Add('RAD_BINDIR', 'Install executables here', env['RAD_BINDIR']) |
23 |
vars.Add('RAD_RLIBDIR', 'Install support files here', env['RAD_RLIBDIR']) |
24 |
vars.Add('RAD_MANDIR', 'Install man pages here', env['RAD_MANDIR']) |
25 |
vars.Update(env) |
26 |
vars.Save(pathfile, env) |
27 |
Help(vars.GenerateHelpText(env)) |
28 |
# where stuff is located in the source tree |
29 |
# the binary target libs are configured by platform |
30 |
env['RAD_BUILDRLIB'] = '#lib' |
31 |
env['RAD_BUILDMAN'] = '#doc/man' |
32 |
33 |
def allplats_setup(env): |
34 |
from build_utils import find_libs |
35 |
find_libs.find_radlib(env) |
36 |
find_libs.find_x11(env) |
37 |
find_libs.find_gl(env) # OpenGL |
38 |
find_libs.find_libtiff(env) |
39 |
find_libs.find_pyinstaller(env) |
40 |
41 |
def post_common_setup(env): |
42 |
env.Append(CPPPATH = [os.path.join('#src', 'common')]) |
43 |
env.Append(LIBPATH=[env['RAD_BUILDLIB']]) # our own libs |
44 |
if not env.has_key('RAD_MLIB'): |
45 |
env['RAD_MLIB'] = [] #['m'] # no seperate mlib on Win |
46 |
47 |
def shareinstall_setup(env): |
48 |
from build_utils import install |
49 |
# only scan for those files when we actually need them |
50 |
if 'install' in sys.argv or 'rlibinstall' in sys.argv: |
51 |
install.install_rlibfiles(env) |
52 |
if 'install' in sys.argv or 'maninstall' in sys.argv: |
53 |
install.install_manfiles(env) |
54 |
55 |
# first figure out the platform |
56 |
from build_utils import load_plat |
57 |
testenv = Environment() |
58 |
load_plat.identify_plat(testenv) |
59 |
60 |
# set stuff before loading platforms |
61 |
prevars = set_pre_opts(testenv) |
62 |
63 |
# Set up build environment |
64 |
env = Environment(variables=prevars) |
65 |
env.Decider('timestamp-match') |
66 |
67 |
if env.get('PMAP_OOC', 0) in (0,'0','','n','no','false',False,None): |
68 |
print('Building Photon-Maps with In-core KD-Tree') |
69 |
else: |
70 |
print('Building Photon-Maps with Out-of-core Octree') |
71 |
72 |
73 |
script_b = Builder(action = install.install_script, suffix = '') |
74 |
env.Append(BUILDERS={'InstallScript': script_b}) |
75 |
if os.name == 'posix': |
76 |
tclscript_b = Builder(action = install.install_tclscript, suffix = '') |
77 |
env.Append(BUILDERS={'InstallTCLScript': tclscript_b}) |
78 |
79 |
# configure platform-specific stuff |
80 |
load_plat.load_plat(env, testenv) |
81 |
82 |
# override options |
83 |
cfg_pathfile = File(testenv['CFG_PATHFILE']).abspath |
84 |
set_opts(env, cfg_pathfile) |
85 |
86 |
load_plat.combine_instpaths(env) |
87 |
88 |
# accept license |
89 |
if ((not env['SKIP'] |
90 |
or env['SKIP'].strip().lower() in (0,'0','n','no','false',None)) |
91 |
and not '-c' in sys.argv and not 'test' in sys.argv): |
92 |
from build_utils import copyright |
93 |
copyright.show_license() |
94 |
testenv['SKIP'] = '1' |
95 |
96 |
# We waited to save this, so that we can add the SKIP |
97 |
prevars.Save(File(testenv['CFG_OPTFILE']).abspath, testenv) |
98 |
99 |
# fill in generic config |
100 |
allplats_setup(env) |
101 |
102 |
print('Installation directories:') |
103 |
print('Base: ', env.subst('$RAD_BASEDIR')) |
104 |
print('Binaries: ', env.subst('$RAD_BINDIR')) |
105 |
print('Library: ', env.subst('$RAD_RLIBDIR')) |
106 |
print('Manpages: ', env.subst('$RAD_MANDIR')) |
107 |
print() |
108 |
109 |
# Bring in all the actual things to build |
110 |
Export('env') |
111 |
if 'test' in sys.argv: |
112 |
SConscript(os.path.join('test', 'SConscript')) |
113 |
114 |
else: |
115 |
SConscript(os.path.join('src', 'common', 'SConscript'), |
116 |
variant_dir=os.path.join(env['RAD_BUILDOBJ'],'common'), duplicate=0) |
117 |
post_common_setup(env) |
118 |
dirs = Split('''meta cv gen ot rt px hd util cal''') |
119 |
if os.path.isfile('src/winimage/SConscript'): |
120 |
dirs.append('winimage') |
121 |
if os.path.isfile('src/winrview/SConscript'): |
122 |
dirs.append('winrview') |
123 |
for d in dirs: |
124 |
print(d) |
125 |
SConscript(os.path.join('src', d, 'SConscript'), |
126 |
variant_dir=os.path.join(env['RAD_BUILDOBJ'], d), duplicate=0) |
127 |
128 |
if ' '.join(sys.argv[1:]).find('install') > -1: |
129 |
shareinstall_setup(env) |
130 |
131 |
Default('.') |
132 |
133 |
# virtual targets |
134 |
env.Alias('bininstall', '$RAD_BINDIR') |
135 |
env.Alias('rlibinstall', '$RAD_RLIBDIR') |
136 |
env.Alias('maninstall', '$RAD_MANDIR') |
137 |
138 |
env.Alias('build', ['$RAD_BUILDBIN']) #, '$RAD_BUILDRLIB']) |
139 |
env.Alias('test', ['#test']) |
140 |
env.Alias('install', ['bininstall', 'rlibinstall', 'maninstall']) |
141 |
142 |
# vi: set ts=4 sw=4 : |
143 |
# vim: set syntax=python : |
