| 1 |
| 2 |
import os
| 3 |
import sys
| 4 |
import string
| 5 |
| 6 |
PATHFILE = 'raypaths.py'
| 7 |
OPTFILE = 'rayopts.py'
| 8 |
def set_pre_opts(env):
| 9 |
vars = Variables(OPTFILE, ARGUMENTS)
| 10 |
vars.Add('SKIP', 'Skip Display of License terms', 0)
| 11 |
vars.Add('RAD_DEBUG', 'Build a debug version', 0)
| 12 |
vars.Update(env)
| 13 |
vars.Save(OPTFILE, env)
| 14 |
| 15 |
def set_opts(env):
| 16 |
vars = Variables(PATHFILE, ARGUMENTS)
| 17 |
vars.Add('RAD_BINDIR', 'Install executables here', env['RAD_BINDIR'])
| 18 |
vars.Add('RAD_RLIBDIR', 'Install support files here', env['RAD_RLIBDIR'])
| 19 |
vars.Add('RAD_MANDIR', 'Install man pages here', env['RAD_MANDIR'])
| 20 |
vars.Update(env)
| 21 |
vars.Save(PATHFILE, env)
| 22 |
Help(vars.GenerateHelpText(env, sort=cmp))
| 23 |
# where stuff is located in the source tree
| 24 |
# the binary target libs are configured by platform
| 25 |
env['RAD_BUILDRLIB'] = '#lib'
| 26 |
env['RAD_BUILDMAN'] = '#doc/man'
| 27 |
| 28 |
def allplats_setup(env):
| 29 |
from build_utils import find_libs
| 30 |
find_libs.find_radlib(env)
| 31 |
find_libs.find_x11(env)
| 32 |
find_libs.find_gl(env) # OpenGL
| 33 |
find_libs.find_libtiff(env)
| 34 |
| 35 |
def post_common_setup(env):
| 36 |
env.Append(CPPPATH = [os.path.join('#src', 'common')])
| 37 |
env.Append(LIBPATH=[env['RAD_BUILDLIB']]) # our own libs
| 38 |
if not env.has_key('RAD_MLIB'):
| 39 |
env['RAD_MLIB'] = [] #['m'] # no seperate mlib on Win
| 40 |
| 41 |
def shareinstall_setup(env):
| 42 |
from build_utils import install
| 43 |
# only scan for those files when we actually need them
| 44 |
if 'install' in sys.argv or 'rlibinstall' in sys.argv:
| 45 |
install.install_rlibfiles(env)
| 46 |
if 'install' in sys.argv or 'maninstall' in sys.argv:
| 47 |
install.install_manfiles(env)
| 48 |
| 49 |
_arch = None
| 50 |
for item in sys.argv[1:]:
| 51 |
if item.startswith('TARGET_ARCH'):
| 52 |
res = item.split('=')
| 53 |
if len(res) == 2:
| 54 |
_arch = res[1].strip()
| 55 |
| 56 |
# Set up build environment
| 57 |
env = Environment(TARGET_ARCH=_arch)
| 58 |
env.Decider('timestamp-match')
| 59 |
| 60 |
| 61 |
script_b = Builder(action = install.install_script, suffix = '')
| 62 |
env.Append(BUILDERS={'InstallScript': script_b})
| 63 |
if os.name == 'posix':
| 64 |
tclscript_b = Builder(action = install.install_tclscript, suffix = '')
| 65 |
env.Append(BUILDERS={'InstallTCLScript': tclscript_b})
| 66 |
| 67 |
# set debug before loading platforms
| 68 |
set_pre_opts(env)
| 69 |
| 70 |
# configure platform-specific stuff
| 71 |
from build_utils import load_plat
| 72 |
load_plat.load_plat(env, vars, arch=_arch)
| 73 |
| 74 |
# override options
| 75 |
set_opts(env)
| 76 |
| 77 |
# accept license
| 78 |
if ((not env['SKIP']
| 79 |
or env['SKIP'].strip().lower() in (0,'0','n','no','false',None))
| 80 |
and not '-c' in sys.argv and not 'test' in sys.argv):
| 81 |
from build_utils import copyright
| 82 |
copyright.show_license()
| 83 |
| 84 |
# fill in generic config
| 85 |
allplats_setup(env)
| 86 |
| 87 |
# Bring in all the actual things to build
| 88 |
Export('env')
| 89 |
if 'test' in sys.argv:
| 90 |
SConscript(os.path.join('test', 'SConscript'))
| 91 |
| 92 |
else:
| 93 |
SConscript(os.path.join('src', 'common', 'SConscript'),
| 94 |
variant_dir=os.path.join(env['RAD_BUILDOBJ'],'common'), duplicate=0)
| 95 |
| 96 |
dirs = Split('''meta cv gen ot rt px hd util cal''')
| 97 |
if os.path.isfile('src/winimage/SConscript'):
| 98 |
dirs.append('winimage')
| 99 |
if os.path.isfile('src/winrview/SConscript'):
| 100 |
dirs.append('winrview')
| 101 |
for d in dirs:
| 102 |
print(d)
| 103 |
SConscript(os.path.join('src', d, 'SConscript'),
| 104 |
variant_dir=os.path.join(env['RAD_BUILDOBJ'], d), duplicate=0)
| 105 |
| 106 |
if string.find(string.join(sys.argv[1:]), 'install') > -1:
| 107 |
| 108 |
| 109 |
Default('.')
| 110 |
| 111 |
# virtual targets
| 112 |
env.Alias('bininstall', '$RAD_BINDIR')
| 113 |
env.Alias('rlibinstall', '$RAD_RLIBDIR')
| 114 |
env.Alias('maninstall', '$RAD_MANDIR')
| 115 |
| 116 |
env.Alias('build', ['$RAD_BUILDBIN', '$RAD_BUILDRLIB'])
| 117 |
env.Alias('test', ['#test'])
| 118 |
env.Alias('install', ['bininstall', 'rlibinstall', 'maninstall'])
| 119 |
| 120 |
# vim: set syntax=python:
