1 |
2 |
import os |
3 |
import sys |
4 |
import string |
5 |
6 |
OPTFILE = 'rayopts.py' |
7 |
def set_opts(env): |
8 |
# XXX add some caching |
9 |
vars = Variables(OPTFILE, ARGUMENTS) |
10 |
vars.Add('SKIP', 'Skip Display of License terms', 0) |
11 |
vars.Add('RAD_BINDIR', 'Install executables here', env['RAD_BINDIR']) |
12 |
vars.Add('RAD_RLIBDIR', 'Install support files here', env['RAD_RLIBDIR']) |
13 |
vars.Add('RAD_MANDIR', 'Install man pages here', env['RAD_MANDIR']) |
14 |
vars.Add('RAD_DEBUG', 'Build a debug version', 0) |
15 |
vars.Update(env) |
16 |
vars.Save(OPTFILE, env) |
17 |
Help(vars.GenerateHelpText(env, sort=cmp)) |
18 |
# where stuff is located in the source tree |
19 |
env['RAD_BUILDLIB'] = '#src/lib' |
20 |
env['RAD_BUILDBIN'] = '#bin' |
21 |
env['RAD_BUILDRLIB'] = '#lib' |
22 |
env['RAD_BUILDMAN'] = '#doc/man' |
23 |
24 |
def allplats_setup(env): |
25 |
from build_utils import find_libs |
26 |
find_libs.find_radlib(env) |
27 |
find_libs.find_x11(env) |
28 |
find_libs.find_gl(env) # OpenGL |
29 |
find_libs.find_libtiff(env) |
30 |
31 |
def post_common_setup(env): |
32 |
env.Append(CPPPATH = [os.path.join('#src', 'common')]) |
33 |
env.Append(LIBPATH=['../lib']) # our own libs |
34 |
if not env.has_key('RAD_MLIB'): |
35 |
env['RAD_MLIB'] = [] #['m'] # no seperate mlib on Win |
36 |
37 |
def shareinstall_setup(env): |
38 |
from build_utils import install |
39 |
# only scan for those files when we actually need them |
40 |
if 'install' in sys.argv or 'rlibinstall' in sys.argv: |
41 |
install.install_rlibfiles(env) |
42 |
if 'install' in sys.argv or 'maninstall' in sys.argv: |
43 |
install.install_manfiles(env) |
44 |
45 |
# Set up build environment |
46 |
env = Environment() |
47 |
env.Decider('timestamp-match') |
48 |
49 |
if os.name == 'posix': |
50 |
51 |
script_b = Builder(action = install.install_script, suffix = '') |
52 |
env.Append(BUILDERS={'InstallScript': script_b}) |
53 |
tclscript_b = Builder(action = install.install_tclscript, suffix = '') |
54 |
env.Append(BUILDERS={'InstallTCLScript': tclscript_b}) |
55 |
56 |
# configure platform-specific stuff |
57 |
from build_utils import load_plat |
58 |
load_plat.load_plat(env, ARGUMENTS, ourplat=None) |
59 |
60 |
# override options |
61 |
set_opts(env) |
62 |
63 |
# accept license |
64 |
if ((not env['SKIP'] |
65 |
or env['SKIP'].strip().lower() in (0,'0','no','false')) |
66 |
and not '-c' in sys.argv and not 'test' in sys.argv): |
67 |
from build_utils import copyright |
68 |
copyright.show_license() |
69 |
70 |
# fill in generic config |
71 |
allplats_setup(env) |
72 |
73 |
# Bring in all the actual things to build |
74 |
Export('env') |
75 |
if 'test' in sys.argv: |
76 |
SConscript(os.path.join('test', 'SConscript')) |
77 |
78 |
else: |
79 |
SConscript(os.path.join('src', 'common', 'SConscript')) |
80 |
post_common_setup(env) |
81 |
for d in Split('meta cv gen ot rt px hd util cal'): |
82 |
print d |
83 |
SConscript(os.path.join('src', d, 'SConscript')) |
84 |
85 |
if string.find(string.join(sys.argv[1:]), 'install') > -1: |
86 |
shareinstall_setup(env) |
87 |
88 |
Default('.') |
89 |
90 |
# virtual targets |
91 |
env.Alias('bininstall', '$RAD_BINDIR') |
92 |
env.Alias('rlibinstall', '$RAD_RLIBDIR') |
93 |
env.Alias('maninstall', '$RAD_MANDIR') |
94 |
95 |
env.Alias('build', ['#bin']) |
96 |
env.Alias('test', ['#test']) |
97 |
env.Alias('install', ['bininstall', 'rlibinstall', 'maninstall']) |
98 |
99 |
# vim: set syntax=python: |
