--- ray/SConstruct 2004/07/04 12:08:47 1.3 +++ ray/SConstruct 2005/02/10 16:42:04 1.6 @@ -4,7 +4,7 @@ import sys import string OPTFILE = 'rayopts.py' - +SourceSignatures('timestamp') def set_opts(env): # XXX add some caching opts = Options(OPTFILE, ARGUMENTS) @@ -26,7 +26,6 @@ def allplats_setup(env): from build_utils import find_libs find_libs.find_x11(env) find_libs.find_gl(env) # OpenGL - #find_libs.find_pixar(env) # PIXAR_LIB for src/px/ra_pixar.c def post_common_setup(env): env.Append(CPPPATH = [os.path.join('#src', 'common')]) @@ -45,6 +44,12 @@ def shareinstall_setup(env): # Set up build environment env = Environment() +if os.name == 'posix': + from build_utils import install + csh_b = Builder(action = install.install_cshscript, + suffix = '', src_suffix = '.csh') + env.Append(BUILDERS={'InstallCsh': csh_b}) + # configure platform-specific stuff from build_utils import load_plat load_plat.load_plat(env, ARGUMENTS, platform=None) @@ -60,6 +65,8 @@ if not env['SKIP'] and not '-c' in sys.argv: # fill in generic config allplats_setup(env) + + # Bring in all the actual things to build Export('env') SConscript(os.path.join('src', 'common', 'SConscript')) @@ -71,22 +78,14 @@ for d in Split('meta cv gen ot rt px hd util cal'): if string.find(string.join(sys.argv[1:]), 'install') > -1: shareinstall_setup(env) +Default('.') + # virtual targets -# RAD_XXXINSTALL are filled in by the local scripts -env.Alias('bininstall', env.get('RAD_BININSTALL', [])) -env.Alias('rlibinstall', env.get('RAD_RLIBINSTALL',[])) -env.Alias('maninstall', env.get('RAD_MANINSTALL', [])) +env.Alias('bininstall', '$RAD_BINDIR') +env.Alias('rlibinstall', '$RAD_RLIBDIR') +env.Alias('maninstall', '$RAD_MANDIR') env.Alias('build', ['#bin']) env.Alias('test', ['#src/test']) env.Alias('install', ['bininstall', 'rlibinstall', 'maninstall']) - -# Further virtual targets are defined locally: -# meta_special: mt1601 okimate imagew mt160 mx80 impress aed5 -# tcurve tscat tbar mtext libt4014.a plotout t4014 -# px_special: ra_im, t4027, paintjet, mt160t, greyscale, colorscale, d48c -# util_special: scanner, makedist (not for Windows yet) -env.Alias('special', ['meta_special', 'px_special', 'util_special']) -env.Alias('special_install', ['meta_special_install', - 'px_special_install', 'util_special_install'])
