--- ray/SConstruct 2004/11/05 22:15:42 1.5 +++ ray/SConstruct 2016/04/19 21:21:23 1.19 @@ -3,35 +3,42 @@ import os import sys import string -OPTFILE = 'rayopts.py' -SourceSignatures('timestamp') +PATHFILE = 'scbuild/raypaths.py' +OPTFILE = 'scbuild/rayopts.py' +def set_pre_opts(): + vars = Variables(OPTFILE, ARGUMENTS) + vars.Add('SKIP', 'Skip Display of License terms', 0) + vars.Add('RAD_DEBUG', 'Build a debug version', 0) + vars.Add('MSVC_VERSION', 'Microsoft VC Version', '12.0') + vars.Add('TARGET_ARCH', 'Windows only: "x68" or "amd64"', '') + return vars + def set_opts(env): - # XXX add some caching - opts = Options(OPTFILE, ARGUMENTS) - opts.Add('SKIP', 'Skip Display of License terms', 0) - opts.Add('RAD_BINDIR', 'Install executables here', env['RAD_BINDIR']) - opts.Add('RAD_RLIBDIR', 'Install support files here', env['RAD_RLIBDIR']) - opts.Add('RAD_MANDIR', 'Install man pages here', env['RAD_MANDIR']) - opts.Add('RAD_DEBUG', 'Build a debug version', 0) - opts.Update(env) - opts.Save(OPTFILE, env) - Help(opts.GenerateHelpText(env, sort=cmp)) + vars = Variables(PATHFILE, ARGUMENTS) + vars.Add('RAD_BINDIR', 'Install executables here', env['RAD_BINDIR']) + vars.Add('RAD_RLIBDIR', 'Install support files here', env['RAD_RLIBDIR']) + vars.Add('RAD_MANDIR', 'Install man pages here', env['RAD_MANDIR']) + vars.Update(env) + vars.Save(PATHFILE, env) + Help(vars.GenerateHelpText(env, sort=cmp)) # where stuff is located in the source tree - env['RAD_BUILDLIB'] = '#src/lib' - env['RAD_BUILDBIN'] = '#bin' - env['RAD_BUILDRLIB'] = '#lib' - env['RAD_BUILDMAN'] = '#doc/man' + # the binary target libs are configured by platform + env['RAD_BUILDRLIB'] = '#lib' + env['RAD_BUILDMAN'] = '#doc/man' def allplats_setup(env): - from build_utils import find_libs - find_libs.find_x11(env) - find_libs.find_gl(env) # OpenGL + from build_utils import find_libs + find_libs.find_radlib(env) + find_libs.find_x11(env) + find_libs.find_gl(env) # OpenGL + find_libs.find_libtiff(env) + find_libs.find_pyinstaller(env) def post_common_setup(env): - env.Append(CPPPATH = [os.path.join('#src', 'common')]) - env.Append(LIBPATH=['../lib']) # our own libs - if not env.has_key('RAD_MLIB'): - env['RAD_MLIB'] = [] #['m'] # no seperate mlib on Win + env.Append(CPPPATH = [os.path.join('#src', 'common')]) + env.Append(LIBPATH=[env['RAD_BUILDLIB']]) # our own libs + if not env.has_key('RAD_MLIB'): + env['RAD_MLIB'] = [] #['m'] # no seperate mlib on Win def shareinstall_setup(env): from build_utils import install @@ -41,49 +48,70 @@ def shareinstall_setup(env): if 'install' in sys.argv or 'maninstall' in sys.argv: install.install_manfiles(env) + +# set stuff before loading platforms +prevars = set_pre_opts() # Set up build environment -env = Environment() +env = Environment(variables=prevars) +prevars.Save(OPTFILE, env) +env.Decider('timestamp-match') +from build_utils import install +script_b = Builder(action = install.install_script, suffix = '') +env.Append(BUILDERS={'InstallScript': script_b}) if os.name == 'posix': - from build_utils import install - csh_b = Builder(action = install.install_cshscript, - suffix = '', src_suffix = '.csh') - env.Append(BUILDERS={'InstallCsh': csh_b}) + tclscript_b = Builder(action = install.install_tclscript, suffix = '') + env.Append(BUILDERS={'InstallTCLScript': tclscript_b}) + # configure platform-specific stuff from build_utils import load_plat -load_plat.load_plat(env, ARGUMENTS, platform=None) +load_plat.load_plat(env) # override options set_opts(env) # accept license -if not env['SKIP'] and not '-c' in sys.argv: - from build_utils import copyright - copyright.show_license() +if ((not env['SKIP'] + or env['SKIP'].strip().lower() in (0,'0','n','no','false',None)) + and not '-c' in sys.argv and not 'test' in sys.argv): + from build_utils import copyright + copyright.show_license() # fill in generic config allplats_setup(env) - - # Bring in all the actual things to build Export('env') -SConscript(os.path.join('src', 'common', 'SConscript')) -post_common_setup(env) -for d in Split('meta cv gen ot rt px hd util cal'): - print d - SConscript(os.path.join('src', d, 'SConscript')) +if 'test' in sys.argv: + SConscript(os.path.join('test', 'SConscript')) + +else: + SConscript(os.path.join('src', 'common', 'SConscript'), + variant_dir=os.path.join(env['RAD_BUILDOBJ'],'common'), duplicate=0) + post_common_setup(env) + dirs = Split('''meta cv gen ot rt px hd util cal''') + if os.path.isfile('src/winimage/SConscript'): + dirs.append('winimage') + if os.path.isfile('src/winrview/SConscript'): + dirs.append('winrview') + for d in dirs: + print(d) + SConscript(os.path.join('src', d, 'SConscript'), + variant_dir=os.path.join(env['RAD_BUILDOBJ'], d), duplicate=0) -if string.find(string.join(sys.argv[1:]), 'install') > -1: - shareinstall_setup(env) + if string.find(string.join(sys.argv[1:]), 'install') > -1: + shareinstall_setup(env) +Default('.') + # virtual targets env.Alias('bininstall', '$RAD_BINDIR') env.Alias('rlibinstall', '$RAD_RLIBDIR') env.Alias('maninstall', '$RAD_MANDIR') -env.Alias('build', ['#bin']) -env.Alias('test', ['#src/test']) +env.Alias('build', ['$RAD_BUILDBIN', '$RAD_BUILDRLIB']) +env.Alias('test', ['#test']) env.Alias('install', ['bininstall', 'rlibinstall', 'maninstall']) +# vim: set syntax=python:
