--- ray/SConstruct 2016/03/28 17:48:43 1.18 +++ ray/SConstruct 2016/04/19 21:21:23 1.19 @@ -3,14 +3,15 @@ import os import sys import string -PATHFILE = 'raypaths.py' -OPTFILE = 'rayopts.py' -def set_pre_opts(env): +PATHFILE = 'scbuild/raypaths.py' +OPTFILE = 'scbuild/rayopts.py' +def set_pre_opts(): vars = Variables(OPTFILE, ARGUMENTS) vars.Add('SKIP', 'Skip Display of License terms', 0) - vars.Add('RAD_DEBUG', 'Build a debug version', 0) - vars.Update(env) - vars.Save(OPTFILE, env) + vars.Add('RAD_DEBUG', 'Build a debug version', 0) + vars.Add('MSVC_VERSION', 'Microsoft VC Version', '12.0') + vars.Add('TARGET_ARCH', 'Windows only: "x68" or "amd64"', '') + return vars def set_opts(env): vars = Variables(PATHFILE, ARGUMENTS) @@ -31,6 +32,7 @@ def allplats_setup(env): find_libs.find_x11(env) find_libs.find_gl(env) # OpenGL find_libs.find_libtiff(env) + find_libs.find_pyinstaller(env) def post_common_setup(env): env.Append(CPPPATH = [os.path.join('#src', 'common')]) @@ -46,15 +48,12 @@ def shareinstall_setup(env): if 'install' in sys.argv or 'maninstall' in sys.argv: install.install_manfiles(env) -_arch = None -for item in sys.argv[1:]: - if item.startswith('TARGET_ARCH'): - res = item.split('=') - if len(res) == 2: - _arch = res[1].strip() +# set stuff before loading platforms +prevars = set_pre_opts() # Set up build environment -env = Environment(TARGET_ARCH=_arch) +env = Environment(variables=prevars) +prevars.Save(OPTFILE, env) env.Decider('timestamp-match') from build_utils import install @@ -64,12 +63,10 @@ if os.name == 'posix': tclscript_b = Builder(action = install.install_tclscript, suffix = '') env.Append(BUILDERS={'InstallTCLScript': tclscript_b}) -# set debug before loading platforms -set_pre_opts(env) # configure platform-specific stuff from build_utils import load_plat -load_plat.load_plat(env, vars, arch=_arch) +load_plat.load_plat(env) # override options set_opts(env)
