--- ray/SConstruct 2010/06/02 15:58:30 1.11 +++ ray/SConstruct 2016/03/10 01:49:56 1.16 @@ -6,18 +6,17 @@ import string OPTFILE = 'rayopts.py' def set_opts(env): # XXX add some caching - opts = Options(OPTFILE, ARGUMENTS) - opts.Add('SKIP', 'Skip Display of License terms', 0) - opts.Add('RAD_BINDIR', 'Install executables here', env['RAD_BINDIR']) - opts.Add('RAD_RLIBDIR', 'Install support files here', env['RAD_RLIBDIR']) - opts.Add('RAD_MANDIR', 'Install man pages here', env['RAD_MANDIR']) - opts.Add('RAD_DEBUG', 'Build a debug version', 0) - opts.Update(env) - opts.Save(OPTFILE, env) - Help(opts.GenerateHelpText(env, sort=cmp)) + vars = Variables(OPTFILE, ARGUMENTS) + vars.Add('SKIP', 'Skip Display of License terms', 0) + vars.Add('RAD_BINDIR', 'Install executables here', env['RAD_BINDIR']) + vars.Add('RAD_RLIBDIR', 'Install support files here', env['RAD_RLIBDIR']) + vars.Add('RAD_MANDIR', 'Install man pages here', env['RAD_MANDIR']) + vars.Add('RAD_DEBUG', 'Build a debug version', 0) + vars.Update(env) + vars.Save(OPTFILE, env) + Help(vars.GenerateHelpText(env, sort=cmp)) # where stuff is located in the source tree - env['RAD_BUILDLIB'] = '#src/lib' - env['RAD_BUILDBIN'] = '#bin' + # the binary target libs are configured by platform env['RAD_BUILDRLIB'] = '#lib' env['RAD_BUILDMAN'] = '#doc/man' @@ -30,7 +29,7 @@ def allplats_setup(env): def post_common_setup(env): env.Append(CPPPATH = [os.path.join('#src', 'common')]) - env.Append(LIBPATH=['../lib']) # our own libs + env.Append(LIBPATH=[env['RAD_BUILDLIB']]) # our own libs if not env.has_key('RAD_MLIB'): env['RAD_MLIB'] = [] #['m'] # no seperate mlib on Win @@ -42,19 +41,27 @@ def shareinstall_setup(env): if 'install' in sys.argv or 'maninstall' in sys.argv: install.install_manfiles(env) +_arch = None +for item in sys.argv[1:]: + if item.startswith('TARGET_ARCH'): + res = item.split('=') + if len(res) == 2: + _arch = res[1].strip() + # Set up build environment -env = Environment(tools=['mingw']) +env = Environment(TARGET_ARCH=_arch) env.Decider('timestamp-match') if os.name == 'posix': from build_utils import install - csh_b = Builder(action = install.install_cshscript, - suffix = '', src_suffix = '.csh') - env.Append(BUILDERS={'InstallCsh': csh_b}) + script_b = Builder(action = install.install_script, suffix = '') + env.Append(BUILDERS={'InstallScript': script_b}) + tclscript_b = Builder(action = install.install_tclscript, suffix = '') + env.Append(BUILDERS={'InstallTCLScript': tclscript_b}) # configure platform-specific stuff from build_utils import load_plat -load_plat.load_plat(env, ARGUMENTS, platform=None) +load_plat.load_plat(env, ARGUMENTS, arch=_arch) # override options set_opts(env) @@ -69,18 +76,19 @@ if ((not env['SKIP'] # fill in generic config allplats_setup(env) - # Bring in all the actual things to build Export('env') if 'test' in sys.argv: SConscript(os.path.join('test', 'SConscript')) else: - SConscript(os.path.join('src', 'common', 'SConscript')) + SConscript(os.path.join('src', 'common', 'SConscript'), + variant_dir=os.path.join(env['RAD_BUILDOBJ'],'common'), duplicate=0) post_common_setup(env) for d in Split('meta cv gen ot rt px hd util cal'): print d - SConscript(os.path.join('src', d, 'SConscript')) + SConscript(os.path.join('src', d, 'SConscript'), + variant_dir=os.path.join(env['RAD_BUILDOBJ'], d), duplicate=0) if string.find(string.join(sys.argv[1:]), 'install') > -1: shareinstall_setup(env) @@ -92,7 +100,8 @@ env.Alias('bininstall', '$RAD_BINDIR') env.Alias('rlibinstall', '$RAD_RLIBDIR') env.Alias('maninstall', '$RAD_MANDIR') -env.Alias('build', ['#bin']) +env.Alias('build', ['$RAD_BUILDBIN']) env.Alias('test', ['#test']) env.Alias('install', ['bininstall', 'rlibinstall', 'maninstall']) +# vim: set syntax=python:
