--- ray/SConstruct 2010/06/02 15:58:30 1.11 +++ ray/SConstruct 2016/03/05 14:43:36 1.14 @@ -6,15 +6,15 @@ import string OPTFILE = 'rayopts.py' def set_opts(env): # XXX add some caching - opts = Options(OPTFILE, ARGUMENTS) - opts.Add('SKIP', 'Skip Display of License terms', 0) - opts.Add('RAD_BINDIR', 'Install executables here', env['RAD_BINDIR']) - opts.Add('RAD_RLIBDIR', 'Install support files here', env['RAD_RLIBDIR']) - opts.Add('RAD_MANDIR', 'Install man pages here', env['RAD_MANDIR']) - opts.Add('RAD_DEBUG', 'Build a debug version', 0) - opts.Update(env) - opts.Save(OPTFILE, env) - Help(opts.GenerateHelpText(env, sort=cmp)) + vars = Variables(OPTFILE, ARGUMENTS) + vars.Add('SKIP', 'Skip Display of License terms', 0) + vars.Add('RAD_BINDIR', 'Install executables here', env['RAD_BINDIR']) + vars.Add('RAD_RLIBDIR', 'Install support files here', env['RAD_RLIBDIR']) + vars.Add('RAD_MANDIR', 'Install man pages here', env['RAD_MANDIR']) + vars.Add('RAD_DEBUG', 'Build a debug version', 0) + vars.Update(env) + vars.Save(OPTFILE, env) + Help(vars.GenerateHelpText(env, sort=cmp)) # where stuff is located in the source tree env['RAD_BUILDLIB'] = '#src/lib' env['RAD_BUILDBIN'] = '#bin' @@ -43,14 +43,15 @@ def shareinstall_setup(env): install.install_manfiles(env) # Set up build environment -env = Environment(tools=['mingw']) +env = Environment() env.Decider('timestamp-match') if os.name == 'posix': from build_utils import install - csh_b = Builder(action = install.install_cshscript, - suffix = '', src_suffix = '.csh') - env.Append(BUILDERS={'InstallCsh': csh_b}) + script_b = Builder(action = install.install_script, suffix = '') + env.Append(BUILDERS={'InstallScript': script_b}) + tclscript_b = Builder(action = install.install_tclscript, suffix = '') + env.Append(BUILDERS={'InstallTCLScript': tclscript_b}) # configure platform-specific stuff from build_utils import load_plat @@ -69,7 +70,6 @@ if ((not env['SKIP'] # fill in generic config allplats_setup(env) - # Bring in all the actual things to build Export('env') if 'test' in sys.argv: @@ -96,3 +96,4 @@ env.Alias('build', ['#bin']) env.Alias('test', ['#test']) env.Alias('install', ['bininstall', 'rlibinstall', 'maninstall']) +# vim: set syntax=python:
