--- ray/SConstruct 2010/05/27 19:32:11 1.10 +++ ray/SConstruct 2016/03/05 00:25:21 1.12 @@ -20,8 +20,6 @@ def set_opts(env): env['RAD_BUILDBIN'] = '#bin' env['RAD_BUILDRLIB'] = '#lib' env['RAD_BUILDMAN'] = '#doc/man' - # compatibility modules - env['RAD_COMPAT'] = 'timegm.o' def allplats_setup(env): from build_utils import find_libs @@ -45,14 +43,14 @@ def shareinstall_setup(env): install.install_manfiles(env) # Set up build environment -env = Environment(tools=['mingw']) +env = Environment() env.Decider('timestamp-match') if os.name == 'posix': from build_utils import install - csh_b = Builder(action = install.install_cshscript, + csh_b = Builder(action = install.install_script, suffix = '', src_suffix = '.csh') - env.Append(BUILDERS={'InstallCsh': csh_b}) + env.Append(BUILDERS={'InstallScript': csh_b}) # configure platform-specific stuff from build_utils import load_plat @@ -70,7 +68,6 @@ if ((not env['SKIP'] # fill in generic config allplats_setup(env) - # Bring in all the actual things to build Export('env')
