root/radiance/ray/SConstruct
Tue Jan 9 00:08:57 2018 UTC (6 years, 3 months ago) by schorsch
Changes since 1.20: +8 -0 lines
Diff to previous 1.20 , to selected 1.7
SCons Option to build Pmap with OOC data on unix
Mon Jan 8 13:38:37 2018 UTC (6 years, 3 months ago) by schorsch
Changes since 1.19: +38 -20 lines
Diff to previous 1.19 , to selected 1.7
Tue Apr 19 21:21:23 2016 UTC (8 years ago) by schorsch
Changes since 1.18: +13 -16 lines
Diff to previous 1.18 , to selected 1.7
Build with VC2013 until text pipe bug is fixed; prepare for pyinstaller on scripts
Mon Mar 28 17:48:43 2016 UTC (8 years, 1 month ago) by schorsch
Changes since 1.17: +11 -6 lines
Diff to previous 1.17 , to selected 1.7
Refactoring of test suite, use independently of SCons and with Py2.7 or 3.x.
Thu Mar 10 17:36:18 2016 UTC (8 years, 1 month ago) by schorsch
Changes since 1.16: +14 -6 lines
Diff to previous 1.16 , to selected 1.7
Tifflib support and sleeker binaries on Windows
Thu Mar 10 01:49:56 2016 UTC (8 years, 1 month ago) by schorsch
Changes since 1.15: +16 -8 lines
Diff to previous 1.15 , to selected 1.7
SCons build system learns about platform architecture
Sun Mar 6 01:13:17 2016 UTC (8 years, 2 months ago) by schorsch
Diff to previous 1.14 , to selected 1.7
Sat Mar 5 14:43:36 2016 UTC (8 years, 2 months ago) by schorsch
Changes since 1.13: +9 -9 lines
Diff to previous 1.13 , to selected 1.7
Replaced deprecated Options() with Variables(), tested with SCons 2.4.1
Sat Mar 5 13:24:58 2016 UTC (8 years, 2 months ago) by schorsch
Changes since 1.12: +5 -3 lines
Diff to previous 1.12 , to selected 1.7
Sat Mar 5 00:25:21 2016 UTC (8 years, 2 months ago) by schorsch
Changes since 1.11: +3 -4 lines
Diff to previous 1.11 , to selected 1.7
updating SCons
Wed Jun 2 15:58:30 2010 UTC (13 years, 11 months ago) by greg
Changes since 1.10: +0 -2 lines
Diff to previous 1.10 , to selected 1.7
Fixes to MINGW build
Thu May 27 19:32:11 2010 UTC (13 years, 11 months ago) by greg
Changes since 1.9: +3 -1 lines
Diff to previous 1.9 , to selected 1.7
Thu Oct 22 21:16:05 2009 UTC (14 years, 6 months ago) by schorsch
Changes since 1.8: +1 -0 lines
Diff to previous 1.8 , to selected 1.7
SCons now checks for installed auxiliary support files.
Fri Dec 26 17:00:32 2008 UTC (15 years, 4 months ago) by schorsch
Changes since 1.7: +39 -34 lines
Diff to previous 1.7
Invoke test suite from SCons and installation instructions.
Revision 1.7 - (view) (download) (annotate) - [selected]
Tue Dec 23 15:03:58 2008 UTC (15 years, 4 months ago) by schorsch
Diff to previous 1.6
Thu Feb 10 16:42:04 2005 UTC (19 years, 2 months ago) by schorsch
Set default to ray/, so all executables end up in ray/bin/.
Fri Nov 5 22:15:42 2004 UTC (19 years, 6 months ago) by schorsch
Changes since 1.4: +0 -10 lines
Thu Oct 21 15:47:11 2004 UTC (19 years, 6 months ago) by schorsch
Changes since 1.3: +12 -5 lines
SCons build simplifications.
Sun Jul 4 12:08:47 2004 UTC (19 years, 10 months ago) by schorsch
Changes since 1.2: +8 -11 lines
Mon Oct 27 10:35:41 2003 UTC (20 years, 6 months ago) by schorsch
Changes since 1.1: +4 -7 lines
Tue Oct 21 19:27:28 2003 UTC (20 years, 6 months ago) by schorsch
Diff to selected 1.7
