root/radiance/ray/SConstruct
Revision: 1.21
Committed: Tue Jan 9 00:08:57 2018 UTC (6 years, 5 months ago) by schorsch
CVS Tags: rad5R4, rad5R2, rad5R3, HEAD
Changes since 1.20: +8 -0 lines
SCons Option to build Pmap with OOC data on unix
# User Rev Content
1 schorsch 1.20 from __future__ import division, print_function, unicode_literals
2 schorsch 1.1
3     import os
4     import sys
5
6 schorsch 1.20 def set_pre_opts(testenv):
7     optfile = File(testenv['CFG_OPTFILE']).abspath
8     vars = Variables(optfile, ARGUMENTS)
9 schorsch 1.14 vars.Add('SKIP', 'Skip Display of License terms', 0)
10 schorsch 1.19 vars.Add('RAD_DEBUG', 'Build a debug version', 0)
11 schorsch 1.20 if testenv['CFG_PLATSYS'] == 'Windows':
12     # no default, will select the most recent one when empty
13     vars.Add('MSVC_VERSION', 'Microsoft VC Version', )
14 schorsch 1.21 else: # not yet supported on Windows
15     vars.Add('PMAP_OOC', 'Build Pmap with Out-of-core Data', 1)
16 schorsch 1.20 vars.Update(testenv)
17 schorsch 1.19 return vars
18 schorsch 1.17
19 schorsch 1.20 def set_opts(env, pathfile):
20     vars = Variables(pathfile, ARGUMENTS)
21     vars.Add('RAD_BASEDIR', 'Installation base directory', env['RAD_BASEDIR'])
22 schorsch 1.14 vars.Add('RAD_BINDIR', 'Install executables here', env['RAD_BINDIR'])
23     vars.Add('RAD_RLIBDIR', 'Install support files here', env['RAD_RLIBDIR'])
24     vars.Add('RAD_MANDIR', 'Install man pages here', env['RAD_MANDIR'])
25     vars.Update(env)
26 schorsch 1.20 vars.Save(pathfile, env)
27     Help(vars.GenerateHelpText(env))
28 schorsch 1.1 # where stuff is located in the source tree
29 schorsch 1.16 # the binary target libs are configured by platform
30 schorsch 1.8 env['RAD_BUILDRLIB'] = '#lib'
31     env['RAD_BUILDMAN'] = '#doc/man'
32 schorsch 1.1
33     def allplats_setup(env):
34 schorsch 1.8 from build_utils import find_libs
35 schorsch 1.9 find_libs.find_radlib(env)
36 schorsch 1.8 find_libs.find_x11(env)
37     find_libs.find_gl(env) # OpenGL
38     find_libs.find_libtiff(env)
39 schorsch 1.19 find_libs.find_pyinstaller(env)
40 schorsch 1.1
41     def post_common_setup(env):
42 schorsch 1.8 env.Append(CPPPATH = [os.path.join('#src', 'common')])
43 schorsch 1.16 env.Append(LIBPATH=[env['RAD_BUILDLIB']]) # our own libs
44 schorsch 1.8 if not env.has_key('RAD_MLIB'):
45     env['RAD_MLIB'] = [] #['m'] # no seperate mlib on Win
46 schorsch 1.1
47     def shareinstall_setup(env):
48     from build_utils import install
49     # only scan for those files when we actually need them
50     if 'install' in sys.argv or 'rlibinstall' in sys.argv:
51     install.install_rlibfiles(env)
52     if 'install' in sys.argv or 'maninstall' in sys.argv:
53     install.install_manfiles(env)
54
55 schorsch 1.20 # first figure out the platform
56     from build_utils import load_plat
57     testenv = Environment()
58     load_plat.identify_plat(testenv)
59 schorsch 1.16
60 schorsch 1.19 # set stuff before loading platforms
61 schorsch 1.20 prevars = set_pre_opts(testenv)
62
63 schorsch 1.1 # Set up build environment
64 schorsch 1.19 env = Environment(variables=prevars)
65 schorsch 1.7 env.Decider('timestamp-match')
66 schorsch 1.1
67 schorsch 1.21 if env.get('PMAP_OOC', 0) in (0,'0','','n','no','false',False,None):
68     print('Building Photon-Maps with In-core KD-Tree')
69     else:
70     print('Building Photon-Maps with Out-of-core Octree')
71
72 schorsch 1.18 from build_utils import install
73     script_b = Builder(action = install.install_script, suffix = '')
74     env.Append(BUILDERS={'InstallScript': script_b})
75 schorsch 1.4 if os.name == 'posix':
76 schorsch 1.13 tclscript_b = Builder(action = install.install_tclscript, suffix = '')
77     env.Append(BUILDERS={'InstallTCLScript': tclscript_b})
78 schorsch 1.4
79 schorsch 1.1 # configure platform-specific stuff
80 schorsch 1.20 load_plat.load_plat(env, testenv)
81 schorsch 1.1
82     # override options
83 schorsch 1.20 cfg_pathfile = File(testenv['CFG_PATHFILE']).abspath
84     set_opts(env, cfg_pathfile)
85
86     load_plat.combine_instpaths(env)
87 schorsch 1.1
88     # accept license
89 schorsch 1.8 if ((not env['SKIP']
90 schorsch 1.17 or env['SKIP'].strip().lower() in (0,'0','n','no','false',None))
91 schorsch 1.8 and not '-c' in sys.argv and not 'test' in sys.argv):
92     from build_utils import copyright
93     copyright.show_license()
94 schorsch 1.20 testenv['SKIP'] = '1'
95
96     # We waited to save this, so that we can add the SKIP
97     prevars.Save(File(testenv['CFG_OPTFILE']).abspath, testenv)
98 schorsch 1.1
99     # fill in generic config
100     allplats_setup(env)
101
102 schorsch 1.20 print('Installation directories:')
103     print('Base: ', env.subst('$RAD_BASEDIR'))
104     print('Binaries: ', env.subst('$RAD_BINDIR'))
105     print('Library: ', env.subst('$RAD_RLIBDIR'))
106     print('Manpages: ', env.subst('$RAD_MANDIR'))
107     print()
108
109 schorsch 1.1 # Bring in all the actual things to build
110     Export('env')
111 schorsch 1.8 if 'test' in sys.argv:
112     SConscript(os.path.join('test', 'SConscript'))
113
114     else:
115 schorsch 1.16 SConscript(os.path.join('src', 'common', 'SConscript'),
116     variant_dir=os.path.join(env['RAD_BUILDOBJ'],'common'), duplicate=0)
117 schorsch 1.8 post_common_setup(env)
118 schorsch 1.18 dirs = Split('''meta cv gen ot rt px hd util cal''')
119     if os.path.isfile('src/winimage/SConscript'):
120     dirs.append('winimage')
121     if os.path.isfile('src/winrview/SConscript'):
122     dirs.append('winrview')
123     for d in dirs:
124     print(d)
125 schorsch 1.16 SConscript(os.path.join('src', d, 'SConscript'),
126     variant_dir=os.path.join(env['RAD_BUILDOBJ'], d), duplicate=0)
127 schorsch 1.1
128 schorsch 1.20 if ' '.join(sys.argv[1:]).find('install') > -1:
129 schorsch 1.8 shareinstall_setup(env)
130 schorsch 1.1
131 schorsch 1.6 Default('.')
132
133 schorsch 1.1 # virtual targets
134 schorsch 1.4 env.Alias('bininstall', '$RAD_BINDIR')
135     env.Alias('rlibinstall', '$RAD_RLIBDIR')
136     env.Alias('maninstall', '$RAD_MANDIR')
137 schorsch 1.1
138 schorsch 1.20 env.Alias('build', ['$RAD_BUILDBIN']) #, '$RAD_BUILDRLIB'])
139 schorsch 1.8 env.Alias('test', ['#test'])
140 schorsch 1.1 env.Alias('install', ['bininstall', 'rlibinstall', 'maninstall'])
141
142 schorsch 1.20 # vi: set ts=4 sw=4 :
143 schorsch 1.21 # vim: set syntax=python :
