Build with VC2013 until text pipe bug is fixed; prepare for pyinstaller on scripts
Refactoring of test suite, use independently of SCons and with Py2.7 or 3.x.
Tifflib support and sleeker binaries on Windows
SCons build system learns about platform architecture
Replaced deprecated Options() with Variables(), tested with SCons 2.4.1
updating SCons
Fixes to MINGW build
SCons now checks for installed auxiliary support files.
Invoke test suite from SCons and installation instructions.
Set default to ray/, so all executables end up in ray/bin/.
SCons build simplifications.
