root/radiance/ray/SConstruct
Revision: 1.16
Committed: Thu Mar 10 01:49:56 2016 UTC (9 years, 3 months ago) by schorsch
Changes since 1.15: +16 -8 lines
SCons build system learns about platform architecture
1
2 import os
3 import sys
4 import string
5
6 OPTFILE = 'rayopts.py'
7 def set_opts(env):
8 # XXX add some caching
9 vars = Variables(OPTFILE, ARGUMENTS)
10 vars.Add('SKIP', 'Skip Display of License terms', 0)
11 vars.Add('RAD_BINDIR', 'Install executables here', env['RAD_BINDIR'])
12 vars.Add('RAD_RLIBDIR', 'Install support files here', env['RAD_RLIBDIR'])
13 vars.Add('RAD_MANDIR', 'Install man pages here', env['RAD_MANDIR'])
14 vars.Add('RAD_DEBUG', 'Build a debug version', 0)
15 vars.Update(env)
16 vars.Save(OPTFILE, env)
17 Help(vars.GenerateHelpText(env, sort=cmp))
18 # where stuff is located in the source tree
19 # the binary target libs are configured by platform
20 env['RAD_BUILDRLIB'] = '#lib'
21 env['RAD_BUILDMAN'] = '#doc/man'
22
23 def allplats_setup(env):
24 from build_utils import find_libs
25 find_libs.find_radlib(env)
26 find_libs.find_x11(env)
27 find_libs.find_gl(env) # OpenGL
28 find_libs.find_libtiff(env)
29
30 def post_common_setup(env):
31 env.Append(CPPPATH = [os.path.join('#src', 'common')])
32 env.Append(LIBPATH=[env['RAD_BUILDLIB']]) # our own libs
33 if not env.has_key('RAD_MLIB'):
34 env['RAD_MLIB'] = [] #['m'] # no seperate mlib on Win
35
36 def shareinstall_setup(env):
37 from build_utils import install
38 # only scan for those files when we actually need them
39 if 'install' in sys.argv or 'rlibinstall' in sys.argv:
40 install.install_rlibfiles(env)
41 if 'install' in sys.argv or 'maninstall' in sys.argv:
42 install.install_manfiles(env)
43
44 _arch = None
45 for item in sys.argv[1:]:
46 if item.startswith('TARGET_ARCH'):
47 res = item.split('=')
48 if len(res) == 2:
49 _arch = res[1].strip()
50
51 # Set up build environment
52 env = Environment(TARGET_ARCH=_arch)
53 env.Decider('timestamp-match')
54
55 if os.name == 'posix':
56 from build_utils import install
57 script_b = Builder(action = install.install_script, suffix = '')
58 env.Append(BUILDERS={'InstallScript': script_b})
59 tclscript_b = Builder(action = install.install_tclscript, suffix = '')
60 env.Append(BUILDERS={'InstallTCLScript': tclscript_b})
61
62 # configure platform-specific stuff
63 from build_utils import load_plat
64 load_plat.load_plat(env, ARGUMENTS, arch=_arch)
65
66 # override options
67 set_opts(env)
68
69 # accept license
70 if ((not env['SKIP']
71 or env['SKIP'].strip().lower() in (0,'0','no','false'))
72 and not '-c' in sys.argv and not 'test' in sys.argv):
73 from build_utils import copyright
74 copyright.show_license()
75
76 # fill in generic config
77 allplats_setup(env)
78
79 # Bring in all the actual things to build
80 Export('env')
81 if 'test' in sys.argv:
82 SConscript(os.path.join('test', 'SConscript'))
83
84 else:
85 SConscript(os.path.join('src', 'common', 'SConscript'),
86 variant_dir=os.path.join(env['RAD_BUILDOBJ'],'common'), duplicate=0)
87 post_common_setup(env)
88 for d in Split('meta cv gen ot rt px hd util cal'):
89 print d
90 SConscript(os.path.join('src', d, 'SConscript'),
91 variant_dir=os.path.join(env['RAD_BUILDOBJ'], d), duplicate=0)
92
93 if string.find(string.join(sys.argv[1:]), 'install') > -1:
94 shareinstall_setup(env)
95
96 Default('.')
97
98 # virtual targets
99 env.Alias('bininstall', '$RAD_BINDIR')
100 env.Alias('rlibinstall', '$RAD_RLIBDIR')
101 env.Alias('maninstall', '$RAD_MANDIR')
102
103 env.Alias('build', ['$RAD_BUILDBIN'])
104 env.Alias('test', ['#test'])
105 env.Alias('install', ['bininstall', 'rlibinstall', 'maninstall'])
106
107 # vim: set syntax=python:
