root/radiance/ray/SConstruct
Wed Jun 2 15:58:30 2010 UTC (13 years, 10 months ago) by greg
Changes since 1.10: +0 -2 lines
Diff to previous 1.10 , to selected 1.1
Fixes to MINGW build
Thu May 27 19:32:11 2010 UTC (13 years, 10 months ago) by greg
Changes since 1.9: +3 -1 lines
Diff to previous 1.9 , to selected 1.1
Thu Oct 22 21:16:05 2009 UTC (14 years, 6 months ago) by schorsch
Changes since 1.8: +1 -0 lines
Diff to previous 1.8 , to selected 1.1
SCons now checks for installed auxiliary support files.
Fri Dec 26 17:00:32 2008 UTC (15 years, 3 months ago) by schorsch
Changes since 1.7: +39 -34 lines
Diff to previous 1.7 , to selected 1.1
Invoke test suite from SCons and installation instructions.
Tue Dec 23 15:03:58 2008 UTC (15 years, 4 months ago) by schorsch
Diff to previous 1.6 , to selected 1.1
Thu Feb 10 16:42:04 2005 UTC (19 years, 2 months ago) by schorsch
Diff to previous 1.5 , to selected 1.1
Set default to ray/, so all executables end up in ray/bin/.
Fri Nov 5 22:15:42 2004 UTC (19 years, 5 months ago) by schorsch
Changes since 1.4: +0 -10 lines
Diff to previous 1.4 , to selected 1.1
Thu Oct 21 15:47:11 2004 UTC (19 years, 6 months ago) by schorsch
Changes since 1.3: +12 -5 lines
Diff to previous 1.3 , to selected 1.1
SCons build simplifications.
Sun Jul 4 12:08:47 2004 UTC (19 years, 9 months ago) by schorsch
Changes since 1.2: +8 -11 lines
Diff to previous 1.2 , to selected 1.1
Mon Oct 27 10:35:41 2003 UTC (20 years, 5 months ago) by schorsch
Changes since 1.1: +4 -7 lines
Revision 1.1 - (view) (download) (annotate) - [selected]
Tue Oct 21 19:27:28 2003 UTC (20 years, 6 months ago) by schorsch
