root/Development/ray/SConstruct
Revision: 1.2
Committed: Mon Oct 27 10:35:41 2003 UTC (22 years, 2 months ago) by schorsch
Changes since 1.1: +4 -7 lines
1
2 import os
3 import sys
4 import string
5
6 OPTFILE = 'rayopts.py'
7
8 def set_opts(env):
9 # XXX add some caching
10 opts = Options(OPTFILE, ARGUMENTS)
11 opts.Add('SKIP', 'Skip Display of License terms', 0)
12 opts.Add('RAD_BINDIR', 'Install executables here', env['RAD_BINDIR'])
13 opts.Add('RAD_RLIBDIR', 'Install support files here', env['RAD_RLIBDIR'])
14 opts.Add('RAD_MANDIR', 'Install man pages here', env['RAD_MANDIR'])
15 opts.Add('RAD_DEBUG', 'Build a debug version', 0)
16 opts.Update(env)
17 opts.Save(OPTFILE, env)
18 Help(opts.GenerateHelpText(env, sort=cmp))
19 # where stuff is located in the source tree
20 env['RAD_BUILDLIB'] = '#src/lib'
21 env['RAD_BUILDBIN'] = '#bin'
22 env['RAD_BUILDRLIB'] = '#lib'
23 env['RAD_BUILDMAN'] = '#doc/man'
24
25 def allplats_setup(env):
26 from build_utils import find_libs
27 find_libs.find_x11(env)
28 find_libs.find_gl(env) # OpenGL
29 #find_libs.find_pixar(env) # PIXAR_LIB for src/px/ra_pixar.c
30
31 def post_common_setup(env):
32 env.Append(CPPPATH = [os.path.join('#src', 'common')])
33 env.Append(LIBPATH=['../lib']) # our own libs
34 if not env.has_key('RAD_MLIB'):
35 env['RAD_MLIB'] = [] #['m'] # no seperate mlib on Win
36
37 def shareinstall_setup(env):
38 from build_utils import install
39 # only scan for those files when we actually need them
40 if 'install' in sys.argv or 'rlibinstall' in sys.argv:
41 install.install_rlibfiles(env)
42 if 'install' in sys.argv or 'maninstall' in sys.argv:
43 install.install_manfiles(env)
44
45 # Set up build environment
46 env = Environment()
47
48 # configure platform-specific stuff
49 from build_utils import load_plat
50 load_plat.load_plat(env, ARGUMENTS, platform=None)
51
52 # override options
53 set_opts(env)
54
55 # accept license
56 if not env['SKIP'] and not '-c' in sys.argv:
57 from build_utils import copyright
58 copyright.show_license()
59
60 # fill in generic config
61 allplats_setup(env)
62
63 # Bring in all the actual things to build
64 Export('env')
65 SConscript(os.path.join('src', 'common', 'SConscript'))
66 post_common_setup(env)
67 for d in Split('meta cv gen ot rt px hd util cal'):
68 SConscript(os.path.join('src', d, 'SConscript'))
69
70 if string.find(string.join(sys.argv[1:]), 'install') > -1:
71 shareinstall_setup(env)
72
73 # virtual targets
74 # RAD_XXXINSTALL are filled in by the local scripts
75 env.Alias('bininstall', env.get('RAD_BININSTALL', []))
76 env.Alias('rlibinstall', env.get('RAD_RLIBINSTALL',[]))
77 env.Alias('maninstall', env.get('RAD_MANINSTALL', []))
78
79 env.Alias('build', ['#bin'])
80 env.Alias('test', ['#src/test'])
81 env.Alias('install', ['bininstall', 'rlibinstall', 'maninstall'])
82
83 # Further virtual targets are defined locally:
84
85 # meta_special -> mt1601 okimate imagew mt160 mx80 impress aed5
86 # tcurve tscat tbar mtext libt4014.a plotout t4014
87 # meta_special_install
88
89 # px_special -> ra_im, t4027, paintjet, mt160t, greyscale, colorscale, d48c
90 # px_special_install
91
92 # util_special -> scanner, makedist (not for Windows yet)
93 # util_special_install
94
95
