root/radiance/ray/SConstruct
Revision: 1.1
Committed: Tue Oct 21 19:27:28 2003 UTC (20 years, 8 months ago) by schorsch
1
2 # Notes to people who come after:
3 #
4 # In general, only use '/' as a path separator in *nix-specific code, use
5 # os.path.join() for everythign else
6
7 import os
8 import sys
9 import string
10
11 OPTFILE = 'rayopts.py'
12
13 def set_opts(env):
14 # XXX add some caching
15 opts = Options(OPTFILE, ARGUMENTS)
16 opts.Add('SKIP', 'Skip Display of License terms', 0)
17 opts.Add('RAD_BINDIR', 'Install executables here', env['RAD_BINDIR'])
18 opts.Add('RAD_RLIBDIR', 'Install support files here', env['RAD_RLIBDIR'])
19 opts.Add('RAD_MANDIR', 'Install man pages here', env['RAD_MANDIR'])
20 opts.Update(env)
21 opts.Save(OPTFILE, env)
22 Help(opts.GenerateHelpText(env, sort=cmp))
23 # where stuff is located in the source tree
24 env['RAD_BUILDLIB'] = '#src/lib'
25 env['RAD_BUILDBIN'] = '#bin'
26 env['RAD_BUILDRLIB'] = '#lib'
27 env['RAD_BUILDMAN'] = '#doc/man'
28
29 def allplats_setup(env):
30 from build_utils import find_libs
31 find_libs.find_x11(env)
32 find_libs.find_gl(env) # OpenGL
33 #find_libs.find_pixar(env) # PIXAR_LIB for src/px/ra_pixar.c
34
35 def post_common_setup(env):
36 env.Append(CPPPATH = [os.path.join('#src', 'common')])
37 env.Append(LIBPATH=['../lib']) # our own libs
38 if not env.has_key('RAD_MLIB'):
39 env['RAD_MLIB'] = [] #['m'] # no seperate mlib on Win
40
41 def shareinstall_setup(env):
42 from build_utils import install
43 # only scan for those files when we actually need them
44 if 'install' in sys.argv or 'rlibinstall' in sys.argv:
45 install.install_rlibfiles(env)
46 if 'install' in sys.argv or 'maninstall' in sys.argv:
47 install.install_manfiles(env)
48
49 # Set up build environment
50 env = Environment()
51
52 # configure platform-specific stuff
53 from build_utils import load_plat
54 load_plat.load_plat(env, platform=None)
55
56 # override options
57 set_opts(env)
58
59 # accept license
60 if not env['SKIP'] and not '-c' in sys.argv:
61 from build_utils import copyright
62 copyright.show_license()
63
64 # fill in generic config
65 allplats_setup(env)
66
67 # Bring in all the actual things to build
68 Export('env')
69 SConscript(os.path.join('src', 'common', 'SConscript'))
70 post_common_setup(env)
71 for d in Split('meta cv gen ot rt px hd util cal'):
72 SConscript(os.path.join('src', d, 'SConscript'))
73
74 if string.find(string.join(sys.argv[1:]), 'install') > -1:
75 shareinstall_setup(env)
76
77 # virtual targets
78 # RAD_XXXINSTALL are filled in by the local scripts
79 env.Alias('bininstall', env.get('RAD_BININSTALL', []))
80 env.Alias('rlibinstall', env.get('RAD_RLIBINSTALL',[]))
81 env.Alias('maninstall', env.get('RAD_MANINSTALL', []))
82
83 env.Alias('build', ['#bin'])
84 env.Alias('test', ['#src/test'])
85 env.Alias('install', ['bininstall', 'rlibinstall', 'maninstall'])
86
87 # Further virtual targets are defined locally:
88
89 # meta_special -> mt1601 okimate imagew mt160 mx80 impress aed5
90 # tcurve tscat tbar mtext libt4014.a plotout t4014
91 # meta_special_install
92
93 # px_special -> ra_im, t4027, paintjet, mt160t, greyscale, colorscale, d48c
94 # px_special_install
95
96 # util_special -> scanner, makedist
97 # util_special_install
98
